FSC-BT2064 General AT Command Set
This Guide is intended for engineers developing the FSC-BT2064 series of Bluetooth modules.
Module default configuration
FSC-BT2064
FSC-BT2064-LE
PIN Code
Off
Service UUID
FFF0
Write UUID
FFF2
Notify UUID
FFF1
AT Command Description
Applicable to the entire document
  • {} : Including content in {…} is optional
  • << : COMMAND sent by the host to the module
  • >> : Module responds to the host’s RESPONSE/EVENT
  • All instructions start with AT,and end with <CR><LF>
  • <CR> represents carriage return, corresponding to HEX as 0x0D
  • <LF> represents a line break, corresponding to HEX as 0x0A
  • If the instruction contains parameters, the parameters should be separated by =
  • If the instruction contains multiple parameters, the parameters should be separated by ,
  • If the instruction returns a response, the response starts with <CR><LF>, ends with <CR><LF>
  • The module should always return the result of instruction execution (success returns OK,failure returns ERROR)
Example:Read module Bluetooth name
Send: <<AT+NAME<CR><LF>
Response: >><CR><LF>+NAME=FSC-BT2064<CR><LF>
Response:>><CR><LF>OK<CR><LF>
Write unsupported Baud rate
Send: <<AT+BAUD=0<CR><LF>
Response: >><CR><LF>ERROR<CR><LF>
  • All events start with <CR><LF> and end with <CR><LF>
  • If an event contains parameters, they shall follow the “=” sign
  • If an event contains multiple parameters, they shall be separated by “,”
Example: Returns current SPP connection status in command mode
Response: >><CR><LF>+SPPSTAT=3<CR><LF>
AT+HELP - Query firmware functions and command descriptions
<MODULE DEFAULT PARAMETER>
Use the help command to get basic summary information
Test UART communication between host and module upon power-up or Baud rate change
AT+REBOOT - Software Reset
The module will perform a reset
The module will restore to factory default settings
AT+BTEN - Read/Write Current Bluetooth Operation Mode
Enable Bluetooth (0/1, default: 0)
0: Disconnect all connections, disable discoverable/connectable mode
1: Enable discoverable/connectable mode
+BTEN=Param
Read/write current Bluetooth operation mode
AT+NAME - Read/Write BR/EDR Bluetooth Name
AT+NAME{=Param{,Param1}}
BR/EDR Bluetooth name (1~29 Bytes ASCII)
Enable MAC address suffix (0~2, default: 0)
1: Enable suffix “XXXX” (last 4 bytes of MAC address)
2: Enable suffix “XXXXXX” (last 6 bytes of MAC address)
Bluetooth name
Set the BR/EDR Bluetooth name; use sub-parameters to display the address suffix
Set BR/EDR Bluetooth name and disable suffix
Set BR/EDR Bluetooth name to “ABC” and automatically add address suffix
<< AT+NAME=ABC-,1
Read BR/EDR Bluetooth name
>> +NAME=ABC-XXXX
AT+LENAME - Read/Write BLE Bluetooth Name
AT+LENAME{=Param{,Param1}}
BLE Bluetooth name (1~29 Bytes ASCII)
1: Enable suffix “-XXXX” (last 4 bytes of MAC address)
2: Enable suffix “-XXXXXX” (last 6 bytes of MAC address)
Bluetooth name
Set the BLE Bluetooth name, use sub-parameters to display the address suffix
AT+PIN - Read/Write Pairing PIN Code
Pairing PIN code (4~15 Bytes ASCII, default: 0000)
The pairing PIN code is valid when +SSP=0
Query pairing PIN code
Modify pairing PIN code to 1234
AT+PLIST - Read/Clear Pairing Records
(0 / 1~8)
(0) Clear all pairing records
(1~8) Clear pairing record at specified index
+PLIST=Param, Param1
(1~8) Pairing device index
(MAC) MAC address of paired device
+PLIST= Pairing record query completed
If a parameter is provided, delete the corresponding pairing information; otherwise, only read the pairing list
Example: Read module pairing records
>> +PLIST=1,1C5CF226D773
+PLIST=2,A0BC30075421
Example: Clear all module pairing records
AT+BAUD - Read/Write UART Baud Rate
Baud rate (9600/19200/38400/57600/115200/
230400/460800/921600/256000/512000/1000000, default: 115200)
Baud rate
The module will switch the Baud rate after receiving this command
After sending the Baud rate setting command, please switch to the set UART Baud rate before communicating with the module
Read Baud rate
Set Baud rate
<< AT+BAUD=230400
AT+VER - Read Firmware Version
+VER{=Param,Param1}
Firmware version
Module model
>> +VER=8.0.0,FSC-BT2064
AT+ADDR - Read BR/EDR Bluetooth MAC Address
Module’s BR/EDR Bluetooth MAC address (12 Bytes ASCII)
AT+LEADDR - Read BLE Bluetooth MAC Address
Module’s BLE Bluetooth MAC address (12 Bytes ASCII)
AT+COD - Read/Write Device Class of Device (COD)
Device class (6 bytes ASCII, default: 240404 Handsfree device)
After modifying COD, the module needs to be restarted to reset the COD
For related configuration, refer to COD.
AT+TPMODE - Enable/Disable Transparent Transmission Mode
Mode (0~1, default: 0) 0: Command mode 1: Transparent transmission mode
When connected under SPP/GATT protocol and transparent transmission mode is enabled, AT commands will be disabled,
and every byte received through UART will be sent to the remote end
AT+FLOWCTL - Enable/Disable UART Flow Control
AT+FLOWCTL{=Param}
Param (0~1, default: 0) 0: Disable flow control 1: Enable flow control
+FLOWCTL=Param
Enable/disable UART flow control
AT+SSP - Enable/Disable Simple Pairing
Mode (0~1, default: 0) 0: Disable SSP 1: Enable SSP
Takes effect after restart
AT+MODE - Read/Write Bluetooth PROFILE
AT+MODE{=Param}
Pairing mode (0~4, default: 4)
(0) NONE PROFILE
(1) SPP PROFILE
(2) HID PROFILE
(3) BLE PROFILE
(4) ALL PROFILE
+MODE=Param
AT+AUTOCONN - Set Bluetooth Power-On Reconnection
0: Disable automatic reconnection
1: Enable automatic reconnection
After power-on, the module will attempt to establish connections with devices in the pairing list according to the set PROFILE
AT+PIOCFG - Enable/Disable IO Port Control Module
AT+PIOCFG{=Param,Param1}
0: Disable command/transmission mode switching function
1: Enable command/transmission mode switching function
0: Disable Bluetooth disconnection function
1: Enable Bluetooth disconnection function
+PIOCFG=Param
Use pins to control transmission mode and connection status
Changes take effect after restart
AT+DSCA - Disconnect All Connections
The module disconnects all Bluetooth connections with remote devices and is used in command mode
AT+SCAN - Search for Nearby Devices
AT+SCAN{=Param{,Param1}}
Scanning mode (0~2)
0: Stop scanning
1: Scan for nearby BR/EDR devices
2: Scan for nearby BLE devices
(1~48) Scanning time. Unit: 1.28s, default: 12.8s
For format description, refer to: +SCAN - Scan Results
AT+SECURITY - Enable/Disable Security Verification
AT+SECURITY{=Param}
Mode (0~1, default: 0) 0: Security verification not enabled 1: Enable security verification
+SECURITY=Param
Enable/disable security verification
Set to enable security verification
<< AT+SECURITY=1
Get security verification information
<< AT+SECURITY
>> +SECURITY=1
AT+TXPOWER - Read/Write Transmit Power
AT+TXPOWER{=Param}
Transmit power (0~6, default: 3)
0: -12dBm
1: -8dBm
2: -4dBm
3: 0dBm
4: 4dBm
5: 8dBm
6: 10dBm
+TXPOWER=Param
Transmit power
Modify the transmit power; the setting takes effect after restart
Read transmit power
<< AT+TXPOWER
>> +TXPOWER=3
Set transmit power to 10dBm
<< AT+TXPOWER=6
AT+UARTCFG - Read/Write UART Configuration
AT+UARTCFG{=Param}
Configuration (0~5, default: 0)
bit0:
0 - 1 stop bit
1 - 2 stop bits
bit2~bit1:
00 - None
01 - Odd
10 - Even
+UARTCFG=Param
Configuration (0~5)
Modify UART configuration (stop bit and parity bit)
Get current UART configuration
<< AT+UARTCFG=0
Set UART to odd parity
<< AT+UARTCFG=2
AT+RSSICFG - Read/Write RSSI Configuration
AT+RSSICFG{=Param{,Param1}}
High RSSI value
Low RSSI value
When the signal strength is greater than Param, PIN34 is set low
When the signal strength is less than Param1, PIN34 is set high
When the signal strength is between Param and Param1, the level remains unchanged
Example: Configure -30~-60 signal strength indication
<< AT+RSSICFG=30,60
SPP Commands
AT+SPPSTAT - Read SPP Status
For format description, refer to: +SPPSTAT - SPP Status
AT+SPPCFG - Read/Write SPP Configuration
AT+SPPCFG{=Param}
Configuration (0~1, default: 0)
0: Disable SPP dynamic registration
0: Enable SPP dynamic registration
+SPPCFG=Param
After enabling dynamic registration, the module will register the SPP service during connection
Deregister the SPP service when disconnected
Target device MAC address (12 Bytes ASCII)
Example: Initiate a connection to the Bluetooth device with address 112233445566
<< AT+SPPCONN=112233445566
AT+SPPDISC - Disconnect SPP Connection
Disconnect the current SPP connection with the remote device
AT+SPPSEND - Send Data via SPP
AT+SPPSEND{=Param{,Param1}}
Payload length (1~236)
Payload (1~236 Bytes UTF8)
This command will be disabled if transparent transmission mode is enabled
Example: Send data “1234567890” to the remote device via SPP
GATT Commands
AT+GATTSTAT - Read GATT Status
For format description, refer to: +GATTSTAT - Connection Status Report
AT+ADVADDR - Enable/Disable Broadcast Address
AT+ADVADDR{=Param}
Mode (0~1, default: 1) 0: Disable Broadcast address 1: Enable Broadcast address
+ADVADDR=Param
Enable/disable Broadcast address
AT+IBEACON - Enable/Disable iBeacon Broadcast
AT+IBEACON{=Param}
Mode (0~1, default: 0) 0: Disable iBeacon Broadcast 1: Enable iBeacon Broadcast
+IBEACON=Param
Enable/disable iBeacon Broadcast
AT+ADVDATA - Read/Write BLE Broadcast Data with Tag 0xFF
AT+ADVDATA{=Param}
Vendor-customized Broadcast data (data length not exceeding 26)
+ADVDATA=Param
Broadcast data with tag 0xFF
The tag of vendor-customized Broadcast data is 0xFF
To enable the module to broadcast customized data, set AT+IBEACON=1 first, then configure the customized Broadcast data
Query the content of vendor-customized Broadcast data; \x represents hexadecimal data
<< AT+ADVDATA
>> +ADVDATA=\x03\x01\x02
Set vendor-customized Broadcast data; \x represents hexadecimal data
<< AT+ADVDATA=\x03\x01\x02
AT+ADBLE - Enable/Disable AndroidBLE
AT+ADBLE{=Param}
Mode (0~1, default: 1) 0: Disable AndroidBLE 1: Enable AndroidBLE
+ADBLE=Param
When enabled, SPP and BLE will have two different addresses | When disabled, SPP and BLE will share one address
AT+UUIDCFG - Read/Write UUID
AT+UUIDCFG{=Param{,Param1}{,Param2}}
Service UUID (default: 0000)
Write UUID (default: 0000)
Notify UUID (default: 0000)
+UUIDCFG=Param,Param1,Param2
Customize the UUID for data transmission; supports 32-bit/128-bit UUID.
When using default parameters:
service UUID = 0xFFF0
write UUID = 0xFFF2
notify UUID = 0xFFF1
AT+GATTSEND - Send Data via GATT
AT+GATTSEND{=Param{,Param1}}
Example: Send data “1234567890” to the remote device via GATT
<< AT+GATTSEND=10,1234567890
AT+LESTAT - Read LE Status
AT+LESTAT
+LEATAT=Param
For format description, refer to: +LESTAT - Connection Status Report
AT+LECCONN - Initiate Connection to Specified Address
AT+LECCONN{=Param{,Param1}{,Param2}{,Param3}}
12-byte device address + 1-byte address type
Communication service UUID
Communication write permission characteristic UUID
Communication notification permission characteristic UUID
Initiate a connection to the specified device. The parameter consists of 12 bytes (device address) and 1 byte
(address type). Generally, the address type is “0” or “1”. How to obtain the address type:
Use the second parameter returned by AT+SCAN, for example:
+SCAN=0,0,DC0D30001ED4,-65,10,FSC-BT946
Connection command:
AT+LECCONN=DC0D30001ED40
Connect to the specified device, 0 is the address type
<< AT+LECCONN=DC0D3000039E0
Initiate a connection to the specified address, using FFF0, FFF2, FFF1 for communication
<< AT+LECCONN=DC0D3000039E0,FFF0,FFF2,FFF1
AT+LESEND - Send Data to Remote Device
AT+LESEND=Param1,Param2
Send data “1234567890” to the remote BLE device
<< AT+LESEND=10,1234567890
HID Commands
AT+HIDSTAT - Read HID Status
AT+HIDSTAT
+HIDATAT=Param
For format description, refer to: +HIDSTAT - HID Status
AT+HIDCONN - Establish HID Connection
AT+HIDCONN{=Param}
AT+HIDDISC - Disconnect HID Connection
AT+HIDDISC
Disconnect the current HID connection with the remote device
AT+HIDOSK - Show/Hide Keyboard
AT+HIDOSK
Show/hide keyboard (iOS only)
AT+HIDMODE - Read/Write HID Mode
AT+HIDMODE{=Param}
HID keyboard input mode (0~1), default 1
(0) HEX key code
(1) ASCII key code (English)
The module can support various keyboard languages through specific firmware, such as:
AT+HIDDLY - Read/Write HID Transmission Interval
AT+HIDDLY{=Param}
AT+HIDSEND - Send Data via HID
AT+HIDSEND{=Param{,Param1}}
Report length
Report payload
Example: Send character ‘A’ to the remote device (on AT+HIDMODE=1)
>> AT+HIDSEND=1,A
<< OK
Example: Send character ‘A’ to the remote device (on AT+HIDMODE=0)
<< AT+HIDSEND=4, xA1 x01 x00 x04
Note: Data is in hex format; the corresponding actual data is as follows:
41 54 2B 48 49 44 53 45 4E 44 3D 34 2C A1 01 00 04 0d 0a
Where:
A1 : report start
01 : page id 1
00 : modifier
04 : key code
The module will automatically send the key release signal
Notification List
+SCAN={ : Start scanning
+SCAN =Param,Param1,Param2,Param3,Param4,Param5
List index
Address type (1 byte)
Address (12 bytes)
RSSI
Device name length
Device name
Format3
+SCAN=} : Stop scanning
Search for devices
>> +SCAN={
>> +SCAN=0,1,70CFC9A98840,-43,24,LE-Bose QuietControl 30
>> +SCAN=1,1,DC0D30001ED4,-65,10,WEWQ-45AE
>> +SCAN=}
Indication
In command mode, when the module’s connection status changes, it is actively reported via +GATTSTAT
Connection successful
>> +GATTSTAT=3
Indication
+LESTAT=Param
In command mode, when the module’s connection status changes, it is actively reported via +LESTAT
>> +LESTAT=3
+HIDSTAT=Param
Contact Information
Shenzhen Feasycom Co.,Ltd.
Address : Rm 508, Building, Fenghuang Zhigu, NO.50, Tiezai Road, Xixiang, Baoan Dist, Shenzhen, 518100, China.
Telphone : 86-755-23062695
Sales Service : sales@feasycom.com
Support : support@feasycom.com
Home Page : www.feasycom.com
Support Forum : forum.feasycom.com
PDF Download
PDF Download
