FSC-BT909C programming user guide
[中文]
This design guide is suitable for engineers to develop FSC-BT909C series Bluetooth modules, also suitable for BT909 series modules
Module Default Settings
FSC-BT909C-XXXX
FSC-BT909C-LE-XXXX
ON
Hardware Description
Pin Diagram
FSC-BT909C as an example:
_images/BT909C_pin_map.png
UART TX
UART RX
UART CTS
UART RTS
External reset input: active Low
Power supply for I/O ports, DC 3.3V
Output square wave in pairing mode,
output high level when bluetooth is connected
bluetooth is not connected to output low level,
connected to output high level
Change the 0 ohm resistance near the antenna,
you can connect an external Bluetooth antenna
Hardware Design Notes
  • The simple test of the module only needs to connect VDD/GND/UART_RX/UART_TX to use
  • After drawing the schematic diagram, please send it to Feasycom for review,so as to avoid the Bluetooth distance not reaching the best effect
GATT Default service and characteristic
Characteristic
throughput services
app send to module
module send to app
Command Description
Terms
  • Throughout this specification:
  • Content between { } is optional
  • Content behind << represents a COMMAND from Host
  • Content behind >> represents a RESPONSE/EVENT to Host
  • All commands start with “AT”, end with <CR><LF>
  • <CR> means “carriage return”, corresponds to hex value 0x0D
  • <LF> means “line feed”, corresponds to hex value 0x0A
  • If Command has Parameter, Parameter follows behind ‘=’
  • If Command has multiple Parameters, Parameter must be separated by ‘,’
  • If Command has Response, Response starts with <CR><LF>, ends with <CR><LF>
  • Module will always report command’s execution result by using “OK” for success or “ERR<code>” for failure
Example:Read module’s BR/EDR local name
>> +VER=FSC-BT1036-XXXX
  • All Events start with <CR><LF>, end with <CR><LF>
  • If Event has Parameter, Parameter follow behind ‘=’
  • If Event has multiple Parameters, Parameter must be separated by ‘,’
  • Use command AT+SEP to replace default separator for conflict prevention
Example: Received “1234567890” from mobile phone via SPP profile
AT+HELP - Firmware Function/Command Summary
Using help command to get the basic summary information
AT+SEP - Get/Set Event/Response Separator
AT+SEP{=Param}
hex value 0x01~0xFF, default: ‘,’ , specially, using ‘0’ instead of ‘xFF’ for convenience
+SEP=Param
The parameter of events/responses may contain value same to the default separator,
using this command to replace default separator for conflict prevention
(replace the default separator ‘,’ to hex value ‘xFF’ typically)
Example:Read module’s paired record (device name contains ‘,’ already)
>> +PLIST=1,32808,1C5CF226D773, Tony, iPhone12
>> +PLIST=2,40, A0BC30075421, Samsung S8
>> +PLIST=E
Example: Replace separator to ‘0xFF’
<< AT+SEP=0
Example: Read module’s paired record again
>> +PLIST=1<FF>32808<FF>1C5CF226D773<FF>Tony, iPhone12
>> +PLIST=2<FF>40<FF> A0BC30075421<FF>Samsung S8
>> +PLIST=E
AT+VER - Get Firmware Version
Module type
Firmware version
Data of production
The date of production in response will not be changed after firmware upgrade
>> +VER=BT1036,V2.6.1,20220922
230400/256000/460800/512000/921600/1382400
+BAUD=Param1,Param2,Param3
All baudrates supported by current module
Module will change baudrate to target value immediately or
after reboot depending on firmware,BT1036、BT955、BT909C not support 2400
Example:Query baudrates supported by current module then change baudrate from 115200 bps to 921600 bps
>> +BAUD=2400,4800,9600,19200,38400,57600,115200,128000,230400,256000,
460800,512000,921600,1382400
<< AT+BAUD=921600
Module switch baudrate to 921600 immediately, host change baudrate as well, query module’s name at new baudrate
>> +NAME=FSC-BT91036-1F26
AT+REBOOT - Soft Reboot
Module release all Bluetooth connections with remote device then reboot
AT+BTEN - Bluetooth On/Off
0-Power off 1-Power on
AT+PROFILE - Bluetooth Profile Selection
A base-10 representation of a bit field, for each bit:
BIT[15]
iAP2 (For iOS devices)
GATT Server and Client, HFP Sink and Source, A2DP Sink and Source, AVRCP Controller
and Target cannot be enabled simultaneously because of mutual exclusion.
Example:Read current profile selection
>> +PROFILE=3
Example:Enable SPP profile, disable the others
<< AT+PROFILE=1
Note: Only support spp、gatt、hid
AT+AUTOCONN - Power On Auto Reconnect Profile Selection
A base-10 representation of a bit field, format same with AT+PROFILE
Module will attempt to establish connection to devices in paired list after power on.
AT+STAT - Get All Profile State
Query all current enabled profile’s state
Example: Read current profile selection
>> +PROFILE=83
Example:Read profile state
<< AT+STAT
+STAT=3,1,2,5
_images/profile_state.png
AT+DEVSTAT - Read Device State
Example:usual combination and description
AT+ADDR - Get BR/EDR MAC Address
Module’s BR/EDR MAC address (12 Bytes ASCII)
Module’s LE MAC address (12 Bytes ASCII)
BR/EDR local name(1~31 Bytes ASCII)
1: Enable suffix “-XXXX” (lower 4 bytes of MAC address) after local name
Write local name if parameter exist, otherwise read current local name
Example:Read current BR/EDR local name
>> +NAME=FSC-BT1036-XXXX
Example:Change module’s BR/EDR local name to “ABC”,and disable suffix
Example:Change module’s BR/EDR local name to “ABC” and enable suffix
BLE local name(1~25 Bytes ASCII)
0-Disable suffix
AT+SSP - Get/Set BR/EDR Pairing Mode
Pairing mode (0~3, default:2)
need reboot
AT+PIN - Get/Set BR/EDR Pin Code
Pin code only work in legacy pairing mode, see AT+SSP
Example:Read module’s pin code
Example: Change module’s pin code to “1234”
AT+CFM - Accept/Reject Remote Pairing Request
AT+CFM=Param1, Param2
12 Bytes MAC address of remote device
0-Reject remote pairing request
1-Accept remote pairing request
Only used for pairing request in pairing mode 3, see AT+SSP
AT+COD: Get/Set Device Class
Class of device(6 bytes ASCII, default:240408 Handsfree device)
Related configuration reference: COD.
AT+PAIR: Get/Set BR/EDR/BLE Visibility
Module will always be discoverable if no device connected (BR/EDR or BLE),
and be undiscoverable if connected with remote device, unless received this command
AT+PAGE: Get/Set BR/EDR Connectability
AT+PAGE=Param
Module will always be connectable mode if no device connected,
and be unconnectable if connected with remote device, unless received this command
AT+SCAN - Scan Nearby Devices
AT+SCAN=Param1{,Param2{,Param3}}
scan type(0~3)
0: Stop scan
1: Scan nearby BR/EDR devices
2: Scan nearby BLE devices
3: Scan nearby BR/EDR/BLE devices
(1~48)Scan period. unit:1.28s, default:12.8s
(1~25 Bytes ASCII)Name filter. Filter scan results with name if set
Format description reference: +SCAN - Scan Result
(0) Clear all paired record
(1~8) Clear specific paired record with index
(MAC) Clear specific paired record with MAC address
(1~8) Paired device’s index
A base-10 representation of a bit field, support profiles of device, see AT+PROFILE
(MAC) Paired device’s MAC address
(UTF8) Paired device’s name
+PLIST=E End of the paired record
>> +PLIST=1,32808,1C5CF226D773, iPhone12
Example:Clear module’s paired record
AT+TPMODE - Turn On/Off Throughput Mode
Throughput mode(0~1,default:0) 0: Turn Off 1: Turn On
When SPP/GATT profile connected and throughput mode is on,
every byte received via physical UART will be sent to air, vice visa
AT+SECCFG: Get/Set Security Level
Mode(0-1),default:0
0: Level 0
1: Level 2
SPP Commands
AT+SPPSTAT - Read SPP State
Format description reference: +SPPSTAT - SPP State
MAC address of target device (12 Bytes ASCII)
Release current SPP connection with remote device
Payload (1~492 Bytes UTF8)
Example: Send data “1234567890” to remote device via SPP
GATT Commands
AT+GATTSTAT - Read GATT State
Format description reference: +GATTSTAT - GATT State
Release current GATT connection with remote device
Example: Send data “1234567890” to remote device via GATT
HID Commands
AT+HIDSTAT - Read HID State
AT+HIDSTAT
+HIDATAT=Param
Format description reference: +HIDSTAT - HID State
AT+HIDCONN - Establish HID Connection
AT+HIDCONN{=Param}
AT+HIDDISC - Release HID Connection
AT+HIDDISC
Release current HID connection with remote device
AT+HIDMODE - Get/Set HID Input Mode
AT+HIDMODE{=Param}
HID keyboard input mode (0~1), default 1
(0) Hex key code
(1) Ascii key code (English)
Module can support various keyboard language with specify firmware,
such as:TURKEY SPAIN PORTUGAL FRANCE GERMANY ITALY CZECH JAPAN
AT+HIDDLY - Get/Set HID Report Period
AT+HIDDLY{=Param}
AT+HIDSEND - Send HID Keyboard Report
AT+HIDSEND=Param1,Param2
Report length
Report payload
Example: Send key code ‘A’ to remote device (on AT+HIDMODE=1)
>> AT+HIDSEND=1,A
<< OK
Example: Send key code ‘A’ to remote device (on AT+HIDMODE=0)
<< AT+HIDSEND=2, x00 x04
Note: As payload is hex value, hence actual command is:
41 54 2B 48 49 44 53 45 4E 44 3D 32 2C 00 04 0d 0a
Where:
00 : modifier
04 : key code
Module will auto send debounce key code by itself
AT+HIDCMD - Send HID User Report
AT+HIDCMD=Param
2 bytes hid user report
e.g., for iPhone:
Play/Pause: 00 CD
Stop: 00 B7
Forward: 00 B5
Backward: 00 B6
Fast Forward: 00 B3
Rewind:00 B4
Record:00 B2
VolumpUp:00 E9
VolumpDn:00 EA
Mute:00 E2
On screen keyboard Toggle:01 AE
Example: Send Volume Up to iPhone
<< AT+HIDCMD= x00 xE9
Note: As the payload is hex value, hence actual command is:
41 54 2B 48 49 44 43 4D 44 3D 00 E9 0D 0A
Events Table
General Events
+PWRSTAT - Powering State
+PWRSTAT=Param
0-Powering off 1-Powering on(booting)
AT Command is not recommended to be used while powering on/off state
+SCAN - Scan Result
Index
Device address type (0~3)
(0) BR/EDR address
(1) LE public address
(2) LE random address
Device Name for BR/EDR devices or advertising data for LE devices
Class of device(6 Bytes ASCII)
+SCAN=E: Scan stopped
Example: Scan BR/EDR nearby devices
>> +SCAN=1,-32,3,B019C66209FA,wt-iphone,7A020C
>> +SCAN=2,-74,0,DC0D30000053,BW226,040680
>> +SCAN=3,-43,0,00158354F994,LAPTOP-3L,120104
>> +SCAN=E
+PAIRREQ - Pair Request
+PAIRREQ=Param1,Param2{,Param3}
Passkey (000000~999999)
MAC address (12 Bytes ASCII) of current pairing device
Name of current pairing device
+PAIRED - Pair Result
+PAIRED=Param1,Param2
Pair result (0)-Success (1~255)-Failed reason
SPP Events
Events for iAP2 (Apple Accessory Protocol) and AAP (Android Auto Protocol) are almost the same with SPP, which are:
  • +IAPSTAT, +IAPDATA for iAP2 profile
  • +AAPSTAT, +AAPDATA for AAP profile
Document will omit these events.
Example: Received data “1234567890” from remote device via SPP
GATT Events
Example: Received data “1234567890” from remote device via GATT
HID Events
+HIDSTAT=Param
Application scenarios
Read/Write Parameters
_images/read_write.png
modify any parameters, it is recommended to query first and then modify the final verification
Data Throughput
  • Typical SPP Slave Data Throughput Interaction:
_images/throughput.png
SPP Master-Slave
  • One of the standard firmwares of the module simultaneously supports SPP master and SPP slave features, when the user use the AT commands for the SPP master feature, the module will act as master role, otherwise, it acts as slave role.
  • The list of AT commands for the SPP master feature:
Commands
AT+SCAN
Scan nearby devices
AT+SPPCONN
Establish SPP connection
Read SPP state
Release SPP connection
AT+SPPSEND
Send data via SPP
  • Typical AT-Command Mode SPP Master Interaction:
_images/SPP.png
Download PDF Document
