FSC-BT910x
2.0
Contents:
  • FSC-BT910x Printer Multi-link AT Command Set
    • Introduction
      • Description
      • Module Default Settings
    • Command Description
      • Terms
      • Command
      • Command Format
    • Commands Table
      • General Command
        • AT+HELP - Get firmware function and command description
        • AT - UART Communication Test
        • AT+REBOOT - Soft Reboot
        • AT+RESTORE - Restore Factory Settings
        • AT+NAME - Get/Set BR/EDR Local Name
        • AT+LENAME - Get/Set BLE Local Name
        • AT+PIN - Get/Set BR/EDR Pin Code
        • AT+ADDR - Get BR/EDR MAC Address
        • AT+LEADDR - Get BLE MAC Address
        • AT+PLIST - Read/clear paired records
        • AT+BAUD - Get/Set UART Baudrate
        • AT+SAMEADDR - Whether EDR and BLE use the same address
        • AT+VER - Get Firmware Version
        • AT+COD - Get/Set Device Class
        • AT+INITDLY - Initialization delay of a Bluetooth device after it is powered on
        • AT+FLOWCTL - Open/close serial port flow control
        • AT+SSP - Get/Set BR/EDR Pairing Mode
        • AT+MODE - Get/Set Bluetooth mode
        • AT+SECURITY - Open/Close security validation
        • AT+TXPOWER - Get/Set TXPOWER
        • AT+ADVADDR - Open/Close the broadcast address
        • AT+HSM - Enable/Disable high speed mode
        • AT+SCM - Enable/Disable short connections
        • AT+CONNMODE - Get/Set whether multiple apps can connect
        • AT+STATE - Get/Set status of Bluetooth device
        • AT+MSC - Get/Set the maximum number of SPP connections
        • AT+PIOCFG - Enable/Disable the IO Port Control Module
        • AT+CLOSEAT - Disable in-flight instructions
        • AT+IBEACON - Enable/Disable ibeacon broadcasting
        • AT+ADVDATA - Get/Set BLE broadcast 0xFF data
        • AT+PCPT - Get/Set printer channel unlock time
    • Application and Development
    • Contact Information
    • Appendix
      • PDF Download
FSC-BT910x
FSC-BT910x Printer Multi-link AT Command Set
Introduction
Description
This design guide is suitable for engineers to develop FSC-BT910x Series Bluetooth module
Module Default Settings
<Model_Number>
Example: FSC-BT9101
<Model_Number>
Example: FSC-BT9101
OFF
Service UUID
18F0
Write UUID
2AF1
Notify UUID
2AF0
Command Description
Terms
This applies to the entire document
  • This version of the instructions is suitable for printer multi-Link application.
  • {} : This includes a link with {…} is optional.
  • << : From the host to the module COMMAND .
  • >> : The module replies to the host RESPONSE/EVENT .
Command
Commands are control instructions actively sent by the host to the module; after receiving the commands, the module shall respond with <CR><LF>OK<CR><LF> as reply.
Command Format
  • All instructions start with AT and end with <CR><LF>
  • <CR> stands for carriage return, corresponding to HEX 0x0D
  • <LF> represents a newline character, corresponding to HEX 0x0A
  • If the instruction contains parameters, the parameters should be separated from the instruction using =
  • If the instruction contains multiple subparameters, the parameters should be separated by ,
  • If a response is returned, the response starts with <CR><LF> and ends with <CR><LF>
  • Module will always report command’s execution result by using OK for success or ERROR for failure
Example:Read the module Bluetooth name
Send: <<AT+NAME<CR><LF>
Response: >><CR><LF>+NAME=FSC-BT9101<CR><LF>
Response:>><CR><LF>OK<CR><LF>
Write an unsupported baud rate
Send: <<AT+BAUD=0<CR><LF>
Response: >><CR><LF>ERROR<CR><LF>
Commands Table
General Command
AT+HELP - Get firmware function and command description
[General]:Main instructions.
[Misc]:reset instruction.
Use the help command to get all the instructions
AT - UART Communication Test
Test the UART communication between the host and the module when the power
is on or the baud rate is changed.If you reply OK, it means that the communication
is normal. If you do not reply, you need to find out the reason.
AT+REBOOT - Soft Reboot
The module will undergo a software reset
AT+RESTORE - Restore Factory Settings
AT+NAME - Get/Set BR/EDR Local Name
AT+NAME{=Param{,Param1}}
BR/EDR Bluetooth name(1~31 Bytes ASCII)
Enable MAC address suffix(0~1,default:0)
1: Enable suffix“XXXX”(lower 4 bytes of MAC address)
Bluetooth name
Write local name if parameter exist, otherwise read current local name
Read the BR/EDR Bluetooth name:
>> +NAME=FSC-BT9101
Change module’s BR/EDR local name to “ABC” and enable suffix
Change module’s BR/EDR local name to “ABC”,and disable suffix
AT+LENAME - Get/Set BLE Local Name
AT+LENAME{=Param{,Param1}}
BLE local name(1~31 Bytes ASCII)
BLE local name
This command temporarily cannot be used to set the BLE local name independently.
If you need to enable this function, please contact FEASYCOM: Contact Information
AT+PIN - Get/Set BR/EDR Pin Code
When + SSP = 0 and open security verification, pairing password is effective
Reference AT+SSP
Querying pairing passwords
Change the pairing password to 1234
AT+ADDR - Get BR/EDR MAC Address
Module’s BR/EDR MAC address (12 Bytes ASCII)
AT+LEADDR - Get BLE MAC Address
Module’s LE MAC address (12 Bytes ASCII)
The default BLE bluetooth address consistent with BR/EDR bluetooth address
If you need to change the BLE address to be inconsistent with BR/EDR Bluetooth
please refer to AT+SAMEADDR
AT+PLIST - Read/clear paired records
(0 / 1~8)
(0) Clear all paired record
(1~8) Clears the matched records for the specified index
+PLIST=Param, Param1
(1~8) Paired device’s index
(MAC)Paired device’s MAC address
If parameters exist, delete the corresponding pairing information;
otherwise, just read the pairing list.
Example:Read module’s paired record
>> +PLIST=1,1C5CF226D773
+PLIST=2,A0BC30075421
Example:Clear all the matching module
AT+BAUD - Get/Set UART Baudrate
Baud rate(9600/19200/38400/57600/115200/
230400/460800/921600/128000/256000/512000, default:115200)
Baud rate
The module will switch the baud rate as soon as it receives this instruction.
After sending command to set the baud rate,
please switch the set baud rate and then communicate with the module.
Read baud rate
Set baud rate
<< AT+BAUD=230400
AT+SAMEADDR - Whether EDR and BLE use the same address
AT+SAMEADDR{=Param}
(0/1, default: 1)
0: use a different address
1: use the same address
+SAMEADDR=Param
parm
Whether to use the same address
Set/query whether SPP·BLE uses the same address
AT+VER - Get Firmware Version
+VER{=Param,Param1}
firmware version
module model
Get the version number and module model
>> +VER=8.6.5,FSC-BT9101
AT+COD - Get/Set Device Class
Class of device(6 bytes ASCII, default:040680 printer device)
The module needs to be restarted for it to take effect.
Related Configuration References COD.
AT+INITDLY - Initialization delay of a Bluetooth device after it is powered on
AT+INITDLY{=Param}
Initialization delay after power on (default: 0)
+INITDLY=Param
Time delay after power on
This directive can set and query the delay time, the default is no delay.
AT+FLOWCTL - Open/close serial port flow control
AT+FLOWCTL{=Param1}
parameter(0~1,default:1)
0:close the flow control
1: Open the flow control
+FLOWCTL=Param
<< AT+FLOWCTL
>> +FLOWCTL=1
AT+SSP - Get/Set BR/EDR Pairing Mode
Pairing mode (0~1, default:0) 0: close SSP 1: open SSP
Default is to close the safe simple pairing
Restart takes effect
AT+MODE - Get/Set Bluetooth mode
AT+MODE{=Param}
Pairing mode (1~3, default:3)
(1) EDR PROFILE
(2) BLE PROFILE
(3) EDR/BLE PROFILE
+MODE=Param
AT+SECURITY - Open/Close security validation
AT+SECURITY{=Param}
Mode(0~3,default:0)
0: Security validation is not enabled
1: Enable EDR security validation
2: Enable BLE security validation
3: Enable EDR/BLE security validation
+SECURITY=Param
Turn on/off security validation
<< AT+SECURITY=1
Obtain security verification information
<< AT+SECURITY
>> +SECURITY=1
AT+TXPOWER - Get/Set TXPOWER
AT+TXPOWER{=Param}
TXPOWER(0~6,default:3)
0: -12dBm
1: -8dBm
2: -4dBm
3: 0dBm
4: 4dBm
5: 8dBm
6: 10dBm
+TXPOWER=Param
TXPOWER
GET TXPOWER
<< AT+TXPOWER
>> +TXPOWER=3
SET TXPOWER to 10dbm
<< AT+TXPOWER=6
AT+ADVADDR - Open/Close the broadcast address
AT+ADVADDR{=Param}
Mode (0 to 1, default:0);0: Off broadcast address;1: On broadcast address
+ADVADDR=Param
Turn on/off the broadcast module address
AT+HSM - Enable/Disable high speed mode
AT+HSM{=Param}
Mode (0-1; default:0)
0: Bluetooth communication uses standard speed.
1: Bluetooth communication uses higher speed.
+HSM=Param
Turn on/off high speed mode
The high-speed mode supports one BLE connection and one SPP connection.
AT+SCM - Enable/Disable short connections
AT+SCM{=Param}
Mode (0-1, default :0)
0: Disable short connections
1: Enable short connections.
+SCM=Param
Turn on/off short connections
Short connection supports 1 SPP connection.
AT+CONNMODE - Get/Set whether multiple apps can connect
AT+CONNMODE{=Param}
Mode(0~1,default:0)
+CONNMODE=Param
0: Enable multiple phones to be connected, and multiple
applications can be connected in one phone.
1: Only enable connecting multiple phones, not connecting
multiple applications within a phone.
AT+STATE - Get/Set status of Bluetooth device
AT+STATE{=Param}
Mode (0-3, default :3)
+STATE=Param
0:Device cannot be found by other devices, nor can it be connected by other devices
1:Device cannot be found by other devices, but it can be connected by other devices
2:Devices can be found by other devices and cannot be connected by other devices
3:Devices can be discovered and connected by other devices
AT+MSC - Get/Set the maximum number of SPP connections
AT+MSC{=Param}
Mode (1-7, default :7)
+MSC=Param
Get/Set the maximum number of SPP connections,
the maximum is no more than 7, the minimum is 1.
AT+PIOCFG - Enable/Disable the IO Port Control Module
AT+PIOCFG{=Param,Param1}
Mode (0/1, default: 1) Switching pin for command and transparent
Parameter (0/1, default: 1) Disconnecting connection pin
+PIOCFG=Param,Param1
Enable the functions of the relevant pins
Obtain whether the IO port is enabled
<< AT+PIOCFG
>> +PIOCFG=1,1
SET IO port
<< AT+PIOCFG=0,0
AT+CLOSEAT - Disable in-flight instructions
AT+CLOSEAT
NULL
Turn off the airborne command mode.
AT+IBEACON - Enable/Disable ibeacon broadcasting
AT+IBEACON{=Param}
Mode (0-1, default 1)
0: Turn off the ibeacon broadcast
1: Enable ibeacon broadcasting.
+IBEACON=Param
Turn on/off ibeacon broadcasting
Broadcast length limit: After enabling iBeacon broadcast,
other broadcasts will not be visible.
Turn off IBEACON broadcasting
<< AT+IBEACON=1
Query broadcast-related information of iBeacon, including UUID, Major, Minor, and measured power value.
<< AT+IBEACON
>> +IBEACON=FDA50693A4E24FB1AFCFC6EB07647825,10065,26049,-58
AT+ADVDATA - Get/Set BLE broadcast 0xFF data
AT+ADVDATA{=Param}
Vendor-defined broadcast data (data length up to 26)
+ADVDATA=Param
Broadcast data with tag 0xFF
The vendor defines the broadcast data tag as 0xFF
If you need to broadcast custom data through the module,
please set AT+IBEACON=1 and then set the custom broadcast number.
Query manufacturer custom broadcast data content, x is hexadecimal data
<< AT+ADVDATA
>> +ADVDATA=\x03\x01\x02
Set vendor-defined broadcast data content, x is hexadecimal data
<< AT+ADVDATA=\x03\x01\x02
AT+PCPT - Get/Set printer channel unlock time
AT+PCPT{=Param}
Unlock time (default :1500ms)
+PCPT=Param
The time interval during which the data module of the mobile phone receives
data when multiple mobile phones are connected
Query unlock time
<< AT+PCPT
>> +PCPT=1500
Changed the unlock time to 3 seconds
<< AT+PCPT=3000
Application and Development
Please refer to:
  • FSC-BT910x User Guide
This guide is intended to provide technical support and resource references for the product development and mass production based on FSC-BT910x series modules. It includes hardware design references, functional description, quick development kits, quick start, obtain firmware version, typical application development examples, and firmware upgrade methods, etc.
Contact Information
Shenzhen Feasycom Co.,Ltd.
Address : Rm 508, Building, Fenghuang Zhigu, NO.50, Tiezai Road, Xixiang, Baoan Dist, Shenzhen, 518100, China.
Telphone : 86-755-23062695
Sales Service : sales@feasycom.com
Support : support@feasycom.com
Home Page : www.feasycom.com
Support Forum : forum.feasycom.com
Appendix
PDF Download
PDF Download
Previous
Copyright © 2015 - 2025 Shenzhen Feasycom Co.,Ltd.
Address:Rm 508, Building, Fenghuang Zhigu, NO.50, Tiezai Road, Xixiang, Baoan Dist, Shenzhen, 518100, China.
Home Page : www.feasycom.com | Support Forum : forum.feasycom.com
