FSC-BT1026 General Audio AT Command Set
This design guide is suitable for engineers to develop FSC-BT1026 series Bluetooth modules, also suitable for BT806、BT802、BT1006 series modules
Module Default Settings
FSC-BT1026-XXXX
FSC-BT1026-LE-XXXX
ON
Command Description
Terms
  • Throughout this specification:
  • Content between { } is optional
  • Content behind << represents a COMMAND from Host
  • Content behind >> represents a RESPONSE/EVENT to Host
  • All commands start with “AT”, end with <CR><LF>
  • <CR> means “carriage return”, corresponds to hex value 0x0D
  • <LF> means “line feed”, corresponds to hex value 0x0A
  • If Command has Parameter, Parameter follows behind ‘=’
  • If Command has multiple Parameters, Parameter must be separated by ‘,’
  • If Command has Response, Response starts with <CR><LF>, ends with <CR><LF>
  • Module will always report command’s execution result by using “OK” for success or “ERROR” for failure
Example:Read module’s BR/EDR local name
>> +NAME=FSC-BT1026-XXXX
Example:Pick up an incoming call when no call incoming actually
  • All Events start with <CR><LF>, end with <CR><LF>
  • If Event has Parameter, Parameter follow behind ‘=’
  • If Event has multiple Parameters, Parameter must be separated by ‘,’
Example: Received “1234567890” from mobile phone via SPP profile
Example: Dial number “10086” using a mobile phone when HFP connected
>> +HFPSTAT=4
>> +HFPAUDIO=1
>> +HFPCID=10086
>> +HFPSTAT=6
AT+HELP - Firmware Function/Command Summary
Using help command to get the basic summary information
AT+VER - Get Firmware Version
Module type
Firmware version
Firmware Compile time
>> +VER=BT1036,V2.6.1,20220922
9600/19200/38400/57600/115200(default)/230400/460800/921600
Module will change baudrate to target value immediately or
after reboot depending on firmware
Example:Read module’s baudrate
<< AT+BAUD=921600
Module switch baudrate to 921600 immediately, host change baudrate as well, query module’s name at new baudrate
>> +NAME=FSC-BT1036-1F26
AT+I2SCFG - Get/Set I2S Settings
A base-10 representation of a bit field, default:0, for each bit
0:disable; 1:enable
0:master; 1:slave
0:FS=48000Hz;1:FS=44100Hz
0:left justified; 1:right justified
0:data 1 bit delay; 1:data no delay
BIT[5-6]
01: bit depth=24bits
10: bit depth=32bits
Example:usual configuration and description
65
67
AT+SPDIFCFG - SPDIF Format Configuration
AT+SPDIFCFG{=Param}
0-Disable SPDIF for audio output 1-Enable SPDIF for audio output
SPDIF output only support: BT802、BT806、BT1026A、BT1026C、BT1026E
If the audio output is spdif, the I2S configuration is invalid.
AT+MICGAIN - Get/Set Analog Input Gain
AT+MICGAIN{=Param}
Gain (‘+’ / ‘-‘)
Adjust input gain
AT+SPKVOL - Get/Set Analog Output Volume
AT+SPKVOL{=Param}
Volume (‘+’ / ‘-’, default:15)
Adjust Output volume, Adjust A2DP volume when play music,adjust HFP volume when talking
AT+REBOOT - Soft Reboot
Module release all Bluetooth connections with remote device then reboot
AT+BTEN - Bluetooth On/Off
0-Power off 1-Power on
AT+PROFILE - Bluetooth Profile Selection
A base-10 representation of a bit field, for each bit:
SPP (Serial Port Profile)
GATT Server and Client, HFP Sink and Source, A2DP Sink and Source, AVRCP Controller
and Target cannot be enabled simultaneously because of mutual exclusion.
Example:Read current profile selection
>> +PROFILE=1195
Example:Enable SPP, GATT Server, HFP Source, A2DP Source profile, disable the others
<< AT+PROFILE=83
Example:Enable SPP, A2DP Sink, disable the others
<< AT+PROFILE=33
AT+AUTOCONN - Turn On/Off Power On Auto Reconnect
(0~15, default:3)
(0) Turn Off
(1-15) Turn on and reconnect times
Module will attempt to connect last device after power on if set.
AT+STAT - Get All Profile State
DEVSTAT
SPPSTAT
GATTSTAT
HFPSTAT
A2DPSTAT
AVRCPSTAT
HIDSTAT
Param8
PBSTAT
AT+DEVSTAT - Read Device State
Example:usual combination and description
AT+ADDR - Get BR/EDR MAC Address
Module’s BR/EDR MAC address (12 Bytes ASCII)
Module’s LE MAC address (12 Bytes ASCII)
BR/EDR local name(1~31 Bytes ASCII)
1: Enable suffix “-XXXX” (lower 4 bytes of MAC address) after local name
Write local name if parameter exist, otherwise read current local name
Example:Read current BR/EDR local name
>> +NAME=FSC-BT1036-XXXX
Example:Change module’s BR/EDR local name to “ABC”,and disable suffix
Example:Change module’s BR/EDR local name to “ABC” and enable suffix
BLE local name(1~25 Bytes ASCII)
0-Disable suffix
AT+SSP - Get/Set BR/EDR Pairing Mode
Pairing mode (0~3, default:2)
need reboot
AT+PIN - Get/Set BR/EDR Pin Code
Pin code only work in legacy pairing mode, see AT+SSP
Example:Read module’s pin code
Example: Change module’s pin code to “1234”
AT+COD: Get/Set Device Class
Class of device(6 bytes ASCII, default:240408 Handsfree device)
Related configuration reference: COD.
AT+PAIR: Get/Set BR/EDR/BLE Visibility
1: Enter BR/EDR/BLE discoverable mode (start advertising/broadcasting)
Module will always be discoverable if no device connected (BR/EDR or BLE),
and be undiscoverable if connected with remote device, unless received this command
AT+SCAN - Scan Nearby Devices
AT+SCAN=Param
scan type(0~1)
0: Stop scan
1: Scan nearby BR/EDR devices
Format description reference: +SCAN - Scan Result
(0) Clear all paired record
(1~8) Clear specific paired record with index
(MAC) Clear specific paired record with MAC address
(1~8) Paired device’s index
(MAC) Paired device’s MAC address
(UTF8) Paired device’s name
+PLIST=E End of the paired record
Example:Read module’s paired record
>> +PLIST=1,1C5CF226D773, iPhone12
+PLIST=2, A0BC30075421, Samsung S8
Example:Clear module’s paired record
AT+TPMODE - Turn On/Off Throughput Mode
Throughput mode(0~1,default:0) 0: Turn Off 1: Turn On
When SPP/GATT profile connected and throughput mode is on,
every byte received via physical UART will be sent to air, vice visa
AT+AUXCFG - Audio Input Mode Configuration
AT+AUXCFG=Param1
mode(0-3,default:)
0: BT Mode
1: LineIn Mode
2: Spdif Mode
3: I2S Mode
This command is used to configure the input mode of the module,
BT1006A, BT1026C, BT1026D do not support spdif
After BT1026A, BT1026B,are set to spdif, PA_MUTE pin will be modified to 20 pin
Example:Set LineIn mode input
<< AT+AUXCFG=1
Some old firmware use AT+LINECFG=1 command to set
AT+PRINT - Turn on/off reporting data
AT+PRINT{=Param}
0-off 1-on 。 default: Open report data
AT+TONEPLAY - play tone
AT+TONEPLAY{=Param}
tone(0-94)
AT+MUTEPIO - Set PA_MUTE pin
AT+MUTEPIO{=Param}
PIO(0-63, 1026C default:PIO23)
AT+MICMUTE - mute MIC
AT+MICMUTE=Param
0-unmute 1-mute
mute mic when call active
AT+SPKMUTE - mute Speaker
AT+MICMUTE=Param
0-unmute 1-mute
HFP Commands
AT+HFPSTAT - Read HFP State
+HFPSTAT=Param
Format description reference: +HFPSTAT - HFP State
AT+HFPRES - Get/Set HFP Sample Rate
AT+HFPRES{=Param}
Sample rate (Hz) for HFP voice call, 0:16k 1-48K
+HFPRES=Param
AT+HFPCONN - Establish HFP Connection
MAC address of target device (12 Bytes ASCII)
Reconnect to last HFP device if parameter not exist
Example:Connect to last HFP device
<< AT+HFPCONN
Example:Connect to specific HFP device with MAC address
<< AT+HFPCONN=1C5CF226D773
AT+HFPDISC - Release HFP Connection
Release current HFP connection with remote device
AT+HFPDIAL - Dial/Redial Phone Number
AT+HFPDIAL{=Param}
Phone number (1~25 Bytes ASCII)
Dial specific number if parameter exist, otherwise redial
Example:Redial
<< AT+HFPDIAL
Example:Dial number “075527924639”
<< AT+HFPDIAL=075527924639
AT+HFPDTMF - Send DTMF code
AT+HFPDTMF{=Param}
DTMF (0~9/#/*)
Example:Send DTMF code “#” while talking
<< AT+HFPDTMF=#
AT+HFPANSW - Pick Up Incoming Call
AT+HFPCHUP - Reject/Hung up Call
Reject incoming call or hung up outgoing/active call
AT+HFPADTS - Transfer Voice Audio Between Local and Remote Device
AT+HFPADTS=Param
0: Transfer voice audio from module to remote device
1: Transfer voice audio from remote device to module
Transfer voice audio between module and remote device by default if no parameter set
AT+HFPVR - Start/Stop Voice Recognition of Remote Device
AT+HFPVR=Param
0-Stop 1-Start
Start/Stop Voice Recognition of Remote Device (such as Siri for iOS devices)
AT+HFPSCO - HFP SCO Configuration
AT+HFPSCO=Param
0-default 1-always to HF 2-always to AG
AT+HFPBATT - Send device battery level
AT+HFPBATT=Param
level(0-9)
A2DP/AVRCP Commands
AT+A2DPSTAT - Read A2DP State
Format description reference: +A2DPSTAT - A2DP State
AT+A2DPCONN - Establish A2DP Connection
Reconnect to last A2DP device if parameter not exist
AT+A2DPDISC - Release A2DP Connection
Release current A2DP connection with remote device
AT+A2DPCFG - Read/Write A2DP Configuration
AT+A2DPCFG=Param
0: Disable AAC Codec 1: Enable AAC Codec
0: Disable APTX Codec 1: Enable APTX Codec
0: Disable APTX-LL Codec 1: Enable APTX-LL Codec
0: Disable APTX-HD Codec 1: Enable APTX-HD Codec
0: Disable APTX-AD Codec 1: Enable APTX-AD Codec
0: Disable LDAC Codec 1: Enable LDAC Codec
Example:Read current A2DP configuration
<< AT+A2DPCFG
>> +A2DPCFG=0
Example::Set A2DP configuration to: Only enable AAC Codec
<< AT+A2DPCFG=1
AT+A2DPDEC - Read A2DP Decoder
AT+A2DPDEC
+A2DPDEC=Param
1:SBC 3:AAC 5:APTX 7:APTX-HD 8:APTX-LL 9:APTX-AD 10:LDAC
AT+A2DPENC - Read A2DP Encoder
AT+A2DPENC
+A2DPENC=Param
AT+A2DPAUDIO - Establish/Release A2DP Audio Connection
AT+A2DPAUDIO{=Param}
0-Release A2DP audio connection with remote a2dp sink device
1-Establish A2DP audio connection with remote a2dp sink device
A2DP SOURCE only supported
AT+AVRCPSTAT - Read AVRCP State
Format description reference: +AVRCPSTAT - AVRCP State
AT+AVRCPCFG - Get/Set AVRCP Configuration
AT+AVRCPCFG{=Param}
A base-10 representation of a bit field, default:3, for each bit:
Auto get track ID3 information (title, artist, album) on track changed.default:1
BIT[1-3]
Auto get track play progress if value > 0. default:5 second
Example: Read AVRCP configuration
<< AT+AVRCPCFG
>> +AVRCPCFG=1
Example: Get track play progress every 1 second
<< AT+AVRCPCFG=3
AT+PLAYPAUSE - Track Play/Pause
AT+PLAYPAUSE
Send play or pause command to remote media player according to current play status
AT+PLAY - Track Play
AT+PLAY
Send play command to remote media player
AT+PAUSE - Track Pause
AT+PAUSE
Send pause command to remote media player
AT+STOP - Track Stop
AT+STOP
Send stop command to remote media player
AT+FORWARD - Track Forward
AT+FORWARD
Send forward command to remote media player
AT+BACKWARD - Track Backward
AT+BACKWARD
Send backward command to remote media player
AT+FFWD - Track FastForward
AT+FFWD=Param
0-Fast Forward Release, 1-Fast Forward Press
Send fast forward command to remote media player
AT+RWD - Track Rewind
AT+RWD=Param
0-Rewind Release, 1-Rewind Press
Send rewind command to remote media player
PBAP Commands
AT+PBSTAT - Read PBAP state
AT+PBSTAT
+PBATAT=Param
Format description reference: +PBSTAT - PBAP State
AT+PBCONN - Establish PBAP Connection
AT+PBCONN{=Param}
Module will use current HFP device’ MAC address if parameter not exist
For some firmware release, module will establish PBAP connection
automatically on received command AT+PBDOWN
AT+PBDISC - Release PBAP Connection
AT+PBDISC
Release current PBAP connection with remote device
AT+PBDOWN - Download Phonebook
Param1{,Param2}
Phonebook type(0-5)
Max items (1~65535, default:3000 for phonebook; 50 for call log)
For some phones (e.g. iPhone), the contact download permission
must be turned on in phone’s Bluetooth settting
for more description, refer to: Phonebook Download
SPP Commands
AT+SPPSTAT - Read SPP State
Format description reference: +SPPSTAT - SPP State
Release current SPP connection with remote device
Payload (1~492 Bytes UTF8)
Example: Send data “1234567890” to remote device via SPP
GATT Commands
AT+GATTSTAT - Read GATT State
Format description reference: +GATTSTAT - GATT State
Release current GATT connection with remote device
Example: Send data “1234567890” to remote device via GATT
HID Commands
AT+HIDSTAT - Read HID State
AT+HIDSTAT
+HIDATAT=Param
Format description reference: +HIDSTAT - HID State
AT+HIDCONN - Establish HID Connection
AT+HIDCONN{=Param}
AT+HIDDISC - Release HID Connection
AT+HIDDISC
Release current HID connection with remote device
AT+HIDMODE - Get/Set HID Input Mode
AT+HIDMODE{=Param}
HID keyboard input mode (0~1), default 1
(0) Hex key code
(1) Ascii key code (English)
Module can support various keyboard language with specify firmware,
such as:TURKEY SPAIN PORTUGAL FRANCE GERMANY ITALY CZECH JAPAN
AT+HIDREL - Read/write HID key value auto release
AT+HIDREL{=Param}
HID Key value auto release(0~1), default 1
(0) manual release
(1) auto release
If HIDREL=0, the user needs to send \x00 \x00 to manually send the bounce key
AT+HIDDLY - Get/Set HID Report Period
AT+HIDDLY{=Param}
AT+HIDSEND - Send HID Keyboard Report
AT+HIDSEND=Param1,Param2
Report length
Report payload
Example: Send key code ‘A’ to remote device (on AT+HIDMODE=1)
>> AT+HIDSEND=1,A
<< OK
Example: Send key code ‘A’ to remote device (on AT+HIDMODE=0)
<< AT+HIDSEND=4, x00 x04
Note: As payload is hex value, hence actual command is:
41 54 2B 48 49 44 53 45 4E 44 3D 34 2C 00 04 0d 0a
Where:
00 : modifier
04 : key code
Module will auto send debounce key code by itself
AT+HIDCMD - Send HID User Report
AT+HIDCMD=Param
2 bytes hid user report
e.g., for iPhone:
Play/Pause: 00 CD
Stop: 00 B7
Forward: 00 B5
Backward: 00 B6
Fast Forward: 00 B3
Rewind:00 B4
Record:00 B2
VolumpUp:00 E9
VolumpDn:00 EA
Mute:00 E2
On screen keyboard Toggle:01 AE
Example: Send Volume Up to iPhone
<< AT+HIDCMD= x00 xE9
Note: As the payload is hex value, hence actual command is:
41 54 2B 48 49 44 43 4D 44 3D 00 E9 0D 0A
Events Table
General Events
+SCAN - Scan Result
Index
Device address type (0~2)
(0) LE public address
(1) LE random address
(2) BR/EDR address
Size of Param6 if exist
Device Name for BR/EDR devices or advertising data for LE devices
+SCAN=E: Scan stopped
Example: Scan BR/EDR nearby devices
>> +SCAN=1,-32,3,B019C66209FA,wt-iphone,7A020C
>> +SCAN=2,-74,0,DC0D30000053,BW226,040680
>> +SCAN=3,-43,0,00158354F994,LAPTOP-3L,120104
>> +SCAN=E
+PAIRED - Pair Result
+PAIRED=Param
MAC address (12 Bytes ASCII) of current pairing device
HFP Events
+HFPSTAT=Param
(0~6)
+HFPDEV - HFP Remote Device Information
(12 Bytes ASCII), Remote MAC address of current HFP connection
(UTF8), Remote device name of current HFP connection
Example: HFP connect success with device
+HFPCID - Incoming/Outgoing Call Number
+HFPCID=Param
(1~25 Bytes ASCII), Call number
Example: Dial number 10086
<< AT+HFPDIAL=10086
>> +HFPSTAT=4
>> +HFPCID=10086
>> +HFPCIE=China Mobile
>> +HFPAUDIO=1
Example: Incoming call with number 13265463800
>> +HFPSTAT=5
>> +HFPCID=13265463800
>> +HFPCIE=Jerry
>> +HFPAUDIO=1
+HFPCIE - Incoming/Outgoing Call Name
+HFPCIE=Param
(UTF8), Call name
This event is supported by IOS mobile phones, but not supported by most Android phones
+HFPAUDIO - HFP Voice Audio State
(0) HFP voice audio disconnected, audio input/output routed to remote device
(1) HFP voice audio connected, audio input/output routed to module
+HFPSIG - HFP Remote Device Network Signal Strength
+HFPSIG=Param
(0~5)Network signal strength of remote device
+HFPROAM - HFP Remote Device Roaming State
+HFPROAM=Param
(0/1) Roaming state of remote device
(0~5) Battery level of remote device
+HFPNET - HFP Remote Device Network Operator Selection
+HFPNET=Param
(UTF8)Network operator selection of remote device
+HFPMANU - HFP Remote Device Manufacture
+HFPMANU=Param
(UTF8)Manufacture name of remote device
+HFPNUM - HFP Remote Device Phone Subscriber Number
+HFPNUM=Param
(ASCII)Phone subscriber number of remote device
+HFPIBR - HFP Remote Device In-band-ring Support
+HFPIBR=Param
(0/1) In-band-ring support
Report whether the current connected phone support in-band-ring
A2DP/AVRCP Events
(4) Streaming
+A2DPDEV - A2DP Remote Device Information
(12 Bytes ASCII), Remote device’s MAC address of current A2DP connection
(UTF8), Remote device’s name of current A2DP connection
+PLAYSTAT - Media Player State
+TRACKSTAT - Media Player Play Progress
(0~4), Media Player State, see +PLAYSTAT
(Decimal ASCII),Elapsed time of current track in millisecond
(Decimal ASCII),Total time of current track in millisecond
Example: Read media player play progress every 1s
>> +TRACKSTAT=1,54000,322000
>> +TRACKSTAT=1,55000,322000
>> +TRACKSTAT=1,56000,322000
+TRACKINFO - Media Track Information
title
artist
album
Example: Phone playing song “Creep-Radio Head”
Phonebook Access Events
+PBSTAT=Param
+PBCNT - Phonebook Entries of Remote Device
+PBCNT=Param
Phonebook entries of remote device
+PBDATA - Phonebook Data
+PBDATA=Param1<FF>Param2<FF>Param3{<FF>Param4}
Number
(15 Bytes ASCII), Call time if current download type is call log
+PBDATA=E: Download complete
Call time may not exist for some mobile phones
Example: Download all phonebook
<< AT+PBDOWN=1
>> +PBCNT=234
+PBDATA=1<FF>Jack<FF>18219146201
+PBDATA=1<FF>kenan<FF>8613771972680
+PBDATA=E
Example: Download 10 dialed call log
<< AT+PBDOWN=3,10
>> +PBDATA=3<FF>China Mobile<FF>10086<FF>20171013T103516
+PBDATA=3<FF>Jerry<FF>18688967507<FF>20171012T152826
+PBDATA=E
SPP Events
Example: Received data “1234567890” from remote device via SPP
GATT Events
Example: Received data “1234567890” from remote device via GATT
HID Events
+HIDSTAT=Param
Development and Application
Please refer to FSC-BT1026x User Guide
This guide details the hardware design description, functional description, rapid development kit, quick testing, typical application development examples, firmware update methods, and FAQs of the FSC-BT1026x Series modules.
Contact Information
Shenzhen Feasycom Co.,Ltd.
Address : Rm 508, Building, Fenghuang Zhigu, NO.50, Tiezai Road, Xixiang, Baoan Dist, Shenzhen, 518100, China.
Telephone : 86-755-23062695
Support : support@feasycom.com
Sales Service : sales@feasycom.com
Home Page : www.feasycom.com
Support Forum : forum.feasycom.com
PDF Download
PDF Download
