FSC-BT1035 programming user guide
This design guide is suitable for engineers to develop FSC-BT1035 series Bluetooth modules, also suitable for BT806、BT802 series modules
Module Default Settings
FSC-BT1035
FSC-BT1035-LE
ON
Hardware Description
Pin Diagram
FSC-BT1035 as an example:
_images/BT1035_pin_map.png
I2S_CLK
I2S BCLK
I2S_IN
I2S DATA IN
I2S_OUT
I2S SYNC
External reset input: active Low
UART TX
UART RX
UART CTS
UART RTS(default: PA mute pin)
Output square wave in pairing mode,
output high level when bluetooth is connected
Power supply for I/O ports, DC 3.3V
SYS_CTRL
Delay 100ms, pull high
VDD_IO
pio supply
37
USB_DP
USB D+
38
USB_DN
USB D-
48
Change the 0 ohm resistance near the antenna,
you can connect an external Bluetooth antenna
Hardware Design Notes
  • The simple test of the module only needs to connect VDD/VDD_IO/VREG_IN/GND/UART_RX/UART_TX to use
  • After drawing the schematic diagram,
  • please send it to Feasycom for review,so as to avoid the Bluetooth distance not reaching the best effect
GATT Default service and characteristic
Characteristic
throughput services
app send to module
module send to app
Command Description
Terms
  • Throughout this specification:
  • Content between { } is optional
  • Content behind << represents a COMMAND from Host
  • Content behind >> represents a RESPONSE/EVENT to Host
  • All commands start with “AT”, end with <CR><LF>
  • <CR> means “carriage return”, corresponds to hex value 0x0D
  • <LF> means “line feed”, corresponds to hex value 0x0A
  • If Command has Parameter, Parameter follows behind ‘=’
  • If Command has multiple Parameters, Parameter must be separated by ‘,’
  • If Command has Response, Response starts with <CR><LF>, ends with <CR><LF>
  • Module will always report command’s execution result by using “OK” for success or “ERROR” for failure
Example:Read module’s BR/EDR local name
>> +NAME=FSC-BT1035XXXX
Example:Pick up an incoming call when no call incoming actually
  • All Events start with <CR><LF>, end with <CR><LF>
  • If Event has Parameter, Parameter follow behind ‘=’
  • If Event has multiple Parameters, Parameter must be separated by ‘,’
Example: Received “1234567890” from mobile phone via SPP profile
AT+HELP - Firmware Function/Command Summary
Using help command to get the basic summary information
AT+VER - Get Firmware Version
Module type
Firmware version
Firmware Compile time
>> +VER=BT1035,V2.6.1,20220922
9600/19200/38400/57600/115200(default)/230400/460800/921600
Module will change baudrate to target value immediately or after reboot depending on firmware
Example:Read module’s baudrate
<< AT+BAUD=921600
Module switch baudrate to 921600 immediately, host change baudrate as well, query module’s name at new baudrate
>> +NAME=FSC-BT1035-1F26
AT+I2SCFG - Get/Set I2S Settings
A base-10 representation of a bit field, default:0, for each bit
0:disable; 1:enable
0:master; 1:slave
0:FS=48000Hz;1:FS=44100Hz
0:left justified; 1:right justified
0:data 1 bit delay; 1:data no delay
BIT[5-6]
01: bit depth=24bits
10: bit depth=32bits
Example:usual configuration and description
65
67
AT+MICGAIN - Get/Set Analog Input Gain
AT+MICGAIN{=Param}
Microphone input gain (0~15, default:10)
AT+SPKVOL - Get/Set Analog Output Volume
AT+SPKVOL{=Param}
audio speaker volume (0~15, default:10)
AT+REBOOT - Soft Reboot
Module release all Bluetooth connections with remote device then reboot
AT+BTEN - Bluetooth On/Off
0-Power off 1-Power on
AT+PROFILE - Bluetooth Profile Selection
A base-10 representation of a bit field, for each bit:
BT1035、BT806 not support HFP-HF、 A2DP Sink、AVRCP Controller、HID Keyboard、PBAP
Example:Read current profile selection
>> +PROFILE=341
Example:Enable SPP, GATT Server, HFP Source, A2DP Source profile, disable the others
<< AT+PROFILE=83
AT+AUTOCONN - Turn On/Off Power On Auto Reconnect
(0~15, default:3)
(0) Turn Off
(1-15) Turn on and reconnect times
Module will attempt to connect last device after power on if set.
AT+STAT - Get All Profile State
DEVSTAT
SPPSTAT
GATTSTAT
HFPSTAT
A2DPSTAT
AVRCPSTAT
AT+DEVSTAT - Read Device State
Example:usual combination and description
AT+ADDR - Get BR/EDR MAC Address
Module’s BR/EDR MAC address (12 Bytes ASCII)
Module’s LE MAC address (12 Bytes ASCII)
BR/EDR local name(1~31 Bytes ASCII)
MAC address suffix(0/1,default:0)
1: Enable suffix “XXXX” (lower 4 bytes of MAC address) after local name
Write local name if parameter exist, otherwise read current local name
Example:Read current BR/EDR local name
Example:Change module’s BR/EDR local name to “ABC”,and disable suffix
Example:Change module’s BR/EDR local name to “ABC” and enable suffix
BLE local name(1~31 Bytes ASCII)
0-Disable suffix
1-Enable suffix “XXXX” (lower 4 bytes of MAC address) after local name
AT+PIN - Get/Set BR/EDR Pin Code
Pin code only work in legacy pairing mode, see AT+SSP
Example:Read module’s pin code
Example: Change module’s pin code to “1234”
AT+COD - Get/Set Device Class
Class of device(6 bytes ASCII, default:5A020C Handsfree device)
Related configuration reference: COD.
AT+PAIR - Get/Set BR/EDR/BLE Visibility
Mode(0-1),default:0
1: Enter BR/EDR/BLE discoverable mode (start advertising/broadcasting)
Module will always be discoverable if no device connected (BR/EDR or BLE),
and be undiscoverable if connected with remote device, unless received this command
AT+SCAN - Scan Nearby Devices
AT+SCAN=Param1{,Param2}}
scan type(0~2)
0: Stop scan
1: Scan nearby BR/EDR devices
2: Scan nearby BLE devices
BLE SCAN report type or BR/EDR scan time
BLE Sacn 0: Report like BR/EDR, 1: Report advertising data
BR/EDR Sacn 0 - 255
Format description reference: +SCAN - Scan Result
(0) Clear all paired record
(1~8) Clear specific paired record with index
(MAC) Clear specific paired record with MAC address
+PLIST=Param1, Param2{,Param3}
(1~8) Paired device’s index
(MAC) Paired device’s MAC address
(UTF8) Paired device’s name
+PLIST=E End of the paired record
Example:Read module’s paired record
>> +PLIST=1,1C5CF226D773, iPhone12
+PLIST=2, A0BC30075421, Samsung S8
Example:Clear module’s paired record
AT+TPMODE - Turn On/Off Throughput Mode
Throughput mode(0~1,default:0) 0: Turn Off 1: Turn On
When SPP/GATT profile connected and throughput mode is on,
every byte received via physical UART will be sent to air, vice visa
AT+AUXCFG - Audio Input Mode Configuration
AT+AUXCFG{=Param}
mode(0-3,default:0)
0: USB Mode
1: LineIn Mode
2: Spdif Mode
3: I2S Mode
This command is used to configure the input mode of the module,
BT1035、BT806 does not support spdif
Example:Set LineIn mode input
<< AT+AUXCFG=1
AT+PRINT - Turn on/off reporting data
AT+PRINT{=Param}
0-off 1-on 。 default: Open report data
AT+MUTEPIO - Set PA_MUTE pin
AT+MUTEPIO{=Param}
PIO(0 ~ 63, default:PIO2)
AT+RSSI - Get RSSI
AT+RSSI=Param
MAC address of target device (12 Bytes ASCII)
+RSSI=Param1,Param2
Device’s RSSI
Get Paired Device’s RSSI
AT+MUTEDELAY - Get/Set Mute Delay
AT+MUTEDELAY{=Param}
Mute Delay(0 ~ 60, default:20) Units:50ms
AT+LINEPIO - Get/Set Analog intput detect PIO
AT+LINEPIO{=Param}
Analog input detect PIO(0 ~ 63, default:PIO44)
HFP Commands
AT+HFPSTAT - Read HFP State
+HFPSTAT=Param
Format description reference: +HFPSTAT - HFP State
AT+HFPCONN - Establish HFP Connection
Reconnect to last HFP device if parameter not exist
Example:Connect to last HFP device
<< AT+HFPCONN
Example:Connect to specific HFP device with MAC address
<< AT+HFPCONN=1C5CF226D773
AT+HFPDISC - Release HFP Connection
Release current HFP connection with remote device
AT+HFPRING - Simulate Incoming Call
AT+HFPRING{=Param}
Phone number (1~15 Bytes ASCII)
Dial specific number if parameter exist, otherwise redial
Example:Redial
<< AT+HFPRING
Example:Simulate Incoming Call number “075527924639”
<< AT+HFPRING=075527924639
AT+HFPANSW - Pick Up Incoming Call
AT+HFPCHUP - Reject/Hung up Call
Reject incoming call or hung up outgoing/active call
AT+HFPAUDIO - Establish/Release Voice Audio
AT+HFPAUDIO{=Param}
0-Release voice audio connection with remote hfp sink device
1-stablish voice audio connection with remote hfp sink device
A2DP/AVRCP Commands
AT+A2DPSTAT - Read A2DP State
Format description reference: +A2DPSTAT - A2DP State
AT+A2DPCONN - Establish A2DP Connection
Reconnect to last A2DP device if parameter not exist
AT+A2DPDISC - Release A2DP Connection
Release current A2DP connection with remote device
AT+A2DPCFG - Read/Write A2DP Configuration
AT+A2DPCFG{=Param}
0: Disable AAC Codec 1: Enable AAC Codec
0: Disable APTX Codec 1: Enable APTX Codec
0: Disable APTX-LL Codec 1: Enable APTX-LL Codec
0: Disable APTX-HD Codec 1: Enable APTX-HD Codec
0: Disable APTX-AD Codec 1: Enable APTX-AD Codec
0: Disable LDAC Codec 1: Enable LDAC Codec
Example:Read current A2DP configuration
<< AT+A2DPCFG
>> +A2DPCFG=0
Example::Set A2DP configuration to: Only enable AAC Codec
<< AT+A2DPCFG=1
AT+A2DPENC - Read A2DP Encoder
AT+A2DPENC
+A2DPENC=Param
BT1035: 1:SBC 2:APTX 3:APTX-HD 4:APTX-LL 5:APTX-AD
BT806: 1:SBC 2:FASTSTREAM 3:APTX 4:APTX-LL
AT+A2DPAUDIO - Establish/Release A2DP Audio Connection
AT+A2DPAUDIO{=Param}
0-Release A2DP audio connection with remote a2dp sink device
1-Establish A2DP audio connection with remote a2dp sink device
AT+AVRCPSTAT - Read AVRCP State
Format description reference: +AVRCPSTAT - AVRCP State
AT+AVRCPCONN - Establish AVRCP Connection
AT+AVRCPCONN{=Param}
Reconnect to last device if parameter not exist
AT+AVRCPDISC - Release AVRCP Connection
AT+AVRCPDISC
Release current AVRCP connection with remote device
SPP Commands
AT+SPPSTAT - Read SPP State
Format description reference: +SPPSTAT - SPP State
Release current SPP connection with remote device
Payload (1~492 Bytes UTF8)
BT1035 max payload length only support 236
Example: Send data “1234567890” to remote device via SPP
GATT Commands
AT+GATTSTAT - Read GATT State
Format description reference: +GATTSTAT - GATT State
Release current GATT connection with remote device
AT+GATTCONN - Establish GATT Central Connection
AT+GATTCONN=Param1{,Param2,Param3,Param4}
MAC address of target device & MAC address type (13 Bytes ASCII)
Service-UUID, Support 16 Bit and 128 Bit(4 Bytes/32 Bytes ASCII)
Write-UUID, Support 16 Bit and 128 Bit(4 Bytes/32 Bytes ASCII)
Notify-UUID, Support 16 Bit and 128 Bit(4 Bytes/32 Bytes ASCII)
GATT Client enable is valid
Example: Specified remote device service connections
<< AT+GATTCONN=123456ABCDEF0,FFF0,FFF2,FFF1
Example: Send data “1234567890” to remote device via GATT
<< AT+GATTSEND=10,1234567890
Events Table
General Events
+SCAN - Scan Result
+SCAN =Param1,Param2,Param3, Param4,Param5,Param6,Param7
Index
Device address type (0~2)
(0) LE public address
(1) LE random address
(2) BR/EDR address
Size of Param6 if exist
Device Name for BR/EDR devices or advertising data for LE devices
Class of device
Example: Scan BR/EDR nearby devices
>> +SCAN=1,2,DC0D30000057,-42,11,FSC-BT1026C,240408
>> +SCAN=2,2,DC0D30000012,-70,16,FSC-BT1006A-0012,240404
>> +SCAN=3,2,DC0D300011B9,-70,14,222qqqqqqqqqqq,240404
>> +SCAN=E
+PAIRED - Pair Result
+PAIRED=Param
MAC address (12 Bytes ASCII) of current pairing device
HFP Events
+HFPSTAT=Param
+HFPDEV - HFP Remote Device Information
(12 Bytes ASCII), Remote MAC address of current HFP connection
(UTF8), Remote device name of current HFP connection
Example: HFP connect success with device
+HFPAUDIO - HFP Voice Audio State
(0) HFP voice audio disconnected, audio input/output routed to remote device
(1) HFP voice audio connected, audio input/output routed to module
(0~9) Battery level of remote device
+HFPSR - HFP Sample rate
Sample rate: 8000/16000/32000
A2DP/AVRCP Events
(4) Streaming
(5) Paused
+A2DPDEV - A2DP Remote Device Information
(12 Bytes ASCII), Remote device’s MAC address of current A2DP connection
(UTF8), Remote device’s name of current A2DP connection
+PLAYSTAT - Media Player State
+CTPLAY - Track Play
+CTPLAY
Receive play command
+CTPAUSE - Track PAUSE
+CTPAUSE
Receive pause command
+CTSTOP - Track STOP
+CTSTOP
Receive stop command
+CTFWD - Track Forward
+CTSTOP
Receive forward command
+CTBACK - Track Backward
+CTBACK
Receive backward command
SPP Events
Example: Received data “1234567890” from remote device via SPP
GATT Events
Example: Received data “1234567890” from remote device via GATT
Application scenarios
profiles initializing and change parameter
The following figure shows Profile initialization and name modification
bt -> host: +VER=FSC-BT1035,V6.0.1,20210922
rnote over host, bt: send AT+PAIR=1, enter discoverable
host -> bt: AT+PAIR=1
bt -> host: +DEVSTAT=7 (enter discoverable,phone can find and spp/gatt connect to us)
rnote over host, bt: change name to "CARKIT",disable suffix. and verify readback
bt -> host: AT+NAME=FSC-BT1035
modify any parameters, it is recommended to query first and then modify the final verification
Source mode connection
rnote over host, bt: scan nearby devices
host -> bt: AT+SCAN=1
bt -> host: +SCAN=1,2,DC0D30000057,-42,11,FSC-BT1026C,240408
bt -> host: +SCAN=2,2,DC0D30000012,-70,16,FSC-BT1006A-0012,240404
host -> bt: AT+A2DPCONN=DC0D30000057 (connect FSC-BT1026C)
bt -> host: +A2DPSTAT=3 (A2DP connected)
bt -> host: +A2DPDEV=DC0D30000057,FSC-BT1026C
bt -> host: +HFPSTAT=3 (HFP connected)
bt -> host: +AVRCPSTAT=3 (AVRCP connected)
bt -> host: +A2DPENC=1 (sbc encoder)
bt -> host: +A2DPSTAT=4 (auto enter A2DP Streaming)
rnote over host, bt: stop Streaming
host -> bt: AT+A2DPAUDIO=0
bt -> host: +A2DPSTAT=5 (A2DP pause)
rnote over host, bt: Establish hfp audio
host -> bt: AT+HFPAUDIO=1
bt -> host: +HFPSTAT=4
bt -> host: +HFPAUDIO=1
bt -> host: +HFPSTAT=6
bt -> host: +HFPSR=16000 (Sample rate : 16000)
rnote over host, bt: Release hfp audio
host -> bt: AT+HFPAUDIO=0
bt -> host: +HFPAUDIO=0
Download PDF Document
