BT1058 programming user guide
This design guide is suitable for engineers to develop BT1058 series Bluetooth modules
Module Default Settings
FSC-BT1058-XXXX |
FSC-BT1058-LE-XXXX |
ON |
Hardware Description
Pin Diagram
FSC-BT1058 as an example:
I2S_CLK |
I2S BCLK |
I2S_IN |
I2S DATA IN |
I2S_OUT |
I2S DATA OUT |
I2S_WS |
I2S SYNC |
External reset input: active Low |
UART TX |
14 |
UART RX |
UART CTS |
UART RTS(default: PA mute pin) |
Output square wave in pairing mode,
output high level when bluetooth is connected
BIS is not connected to output low level,
connected to output high level
Power supply for I/O ports, DC 3.3V |
34 |
VREG_IN |
Typically connected to an ON/OFF push button |
VDD_IO |
pio supply |
43 |
MIC_LP |
Audio |
MIC0/Line_IN differential L input, positive |
44 |
MIC_LN |
Audio |
MIC0/Line_IN differential L input, negative |
45 |
MIC_BIAS |
Audio |
MIC Power Supplies |
46 |
SPK_RN |
Audio |
Headphone/speaker differential R output, negative |
47 |
SPK_RP |
Audio |
Headphone/speaker differential R output, positive |
48 |
SPK_LN |
Audio |
Headphone/speaker differential L output, negative |
49 |
SPK_LP |
Audio |
Headphone/speaker differential L output, positive |
51 |
Change the 0 ohm resistance near the antenna,
you can connect an external Bluetooth antenna
Hardware Design Notes
The simple test of the module only needs to connect VDD/VDD_IO/VREG_IN/GND/UART_RX/UART_TX to use
After drawing the schematic diagram, please send it to Feasycom for review,so as to avoid the Bluetooth distance not reaching the best effect
SPP (Serial Port Profile)
GATTS (Generic Attribute Profile LE-Peripheral role)
GATTC (Generic Attribute Profile LE-Central role)
HFP-HF (Hands-Free Profile)
HFP-AG (Hands-Free-AG Profile)
A2DP-Sink (Advanced Audio Distribution Profile)
A2DP-Source (Advanced Audio Distribution Profile)
AVRCP-Controller (Audio/Video remote controller Profile)
AVRCP-Target (Audio/Video remote controller Profile)
HID-DEVICE (Human Interface Profile)
PBAP (Phonebook Access Profile)
MAP (Message Access Profile)
LEA (LE Audio)
GATT Default service and characteristic
UUID |
Characteristic |
Service |
0xFFF0 |
throughput services |
Write |
0xFFF2 |
Write,Write Without Response |
app send to module |
Notify |
0xFFF1 |
Notify |
module send to app |
Command Description
Terms
Throughout this specification:
Content between { } is optional
Content behind << represents a COMMAND from Host
Content behind >> represents a RESPONSE/EVENT to Host
All commands start with “AT”, end with <CR><LF>
<CR> means “carriage return”, corresponds to hex value 0x0D
<LF> means “line feed”, corresponds to hex value 0x0A
If Command has Parameter, Parameter follows behind ‘=’
If Command has multiple Parameters, Parameter must be separated by ‘,’
If Command has Response, Response starts with <CR><LF>, ends with <CR><LF>
Module will always report command’s execution result by using “OK” for success or “ERROR” for failure
All Events start with <CR><LF>, end with <CR><LF>
If Event has Parameter, Parameter follow behind ‘=’
If Event has multiple Parameters, Parameter must be separated by ‘,’
AT+HELP - Firmware Function/Command Summary
AT+HELP |
Using help command to get the basic summary information |
AT+VER - Get Firmware Version
+VER=Param1,Param2,Param3 |
Module type |
Firmware version |
Firmware Compile time |
9600/19200/38400/57600/115200(default)/230400/460800/921600 |
Module will change baudrate to target value immediately or
after reboot depending on firmware
AT+I2SCFG - Get/Set I2S Settings
AT+I2SCFG{=Param} |
A base-10 representation of a bit field, default:0, for each bit |
0:disable; 1:enable |
0:master; 1:slave |
0:FS=48000Hz;1:FS=44100Hz |
0:left justified; 1:right justified |
0:data 1 bit delay; 1:data no delay |
01: bit depth=24bits
10: bit depth=32bits
0:WS at high level,SD data is right channel 1:WS at high level,SD data is left channel |
+I2SCFG=Param |
BIT[4] is valid only at the condition of BIT[3]=0. BIT[7] Partial firmware support |
Example:usual configuration and description
I2S Master; Sample rate=48000Hz; Resolution=16bits; Bit clock= 48000*16*2ch=1.536Mhz |
I2S Slave; Sample rate=48000Hz; Resolution=16bits; Bit clock= 48000*16*2ch=1.536Mhz |
65 |
I2S Master; Sample rate=48000Hz; Resolution=32bits; Bit clock= 48000*32*2ch=3.072Mhz |
67 |
I2S Slave; Sample rate=48000Hz; Resolution=32bits; Bit clock= 48000*32*2ch=3.072Mhz |
AT+SPDIFCFG - SPDIF Format Configuration
AT+SPDIFCFG{=Param} |
0-Disable SPDIF for audio output 1-Enable SPDIF for audio output |
SPDIF output only support: BT1058、BT806、BT1026A、BT1026B、BT1026E
If the audio output is spdif, the I2S configuration is invalid.
AT+SPKVOL - Get/Set Analog Output Volume
AT+SPKVOL{=Param} |
Volume (‘+’ / ‘-’/ 0-15, default:15) |
Adjust Output volume, Adjust A2DP volume when play music,adjust HFP volume when talking |
AT+REBOOT - Soft Reboot
Module release all Bluetooth connections with remote device then reboot |
Module restore all factory settings then reboot |
AT+BTEN - Bluetooth On/Off
AT+BTEN{=Param} |
0-Power off 1-Power on |
AT+PROFILE - Bluetooth Profile Selection
AT+PROFILE{=Param} |
A base-10 representation of a bit field, for each bit: |
SPP (Serial Port Profile) |
GATT Server (Generic Attribute Profile) |
GATT Client (Generic Attribute Profile) |
HFP-HF (Hands-Free Profile Handsfree) |
HFP-AG (Hands-Free Profile Audio Gateway) |
A2DP Sink (Advanced Audio Distribution Profile) |
A2DP Source (Advanced Audio Distribution Profile) |
AVRCP Controller (Audio/Video remote controller Profile) |
AVRCP Target (Audio/Video remote controller Profile) |
HID Keyboard (Human Interface Profile) |
PBAP Server (Phonebook Access Profile) |
Map Server (Message Access Profile) |
Bis Source (Le audio broadcast source) |
Bis Sink (Le audio broadcast sink) |
CIS Source (Le audio unicast source) |
CIS Sink (Le audio unicast sink) |
+PROFILE=Param |
GATT Server and Client, HFP Sink and Source, A2DP Sink and Source, AVRCP Controller
and Target cannot be enabled simultaneously because of mutual exclusion.
AT+AUTOCONN - Turn On/Off Power On Auto Reconnect
AT+AUTOCONN{=Param} |
(0~15, default:3)
(0) Turn Off
(1-15) Turn on and reconnect times
+AUTOCONN=Param |
Module will attempt to connect last device after power on if set. |
AT+STAT - Get All Profile State
AT+STAT |
+STAT=Param1, Param2, Param3… |
DEVSTAT |
SPPSTAT |
GATTSTAT |
HFPSTAT |
A2DPSTAT |
AVRCPSTAT |
CISSTAT |
PBSTAT |
BISSTAT |
AT+DEVSTAT - Read Device State
AT+DEVSTAT |
+DEVSTAT=Param |
0: Power Off; 1: Power On |
0: BR/EDR Not Discoverable; 1: BR/EDR Discoverable |
0: BLE Not Advertising; 1: BLE Advertising |
0: BR/EDR Not Scanning; 1: BR/EDR Scanning |
0: BLE Not Scanning; 1: BLE Scanning |
Example:usual combination and description
0 |
Device power off |
Device power on |
Device power on, BR/EDR Discoverable |
Device power on, BR/EDR Not Discoverable, BLE Advertising |
Device power on, BR/EDR Discoverable, BLE Advertising |
Device power on, BR/EDR Not Discoverable, BLE Advertising, Scanning nearby BR/EDR devices |
AT+ADDR - Get BR/EDR MAC Address
Module’s BR/EDR MAC address (12 Bytes ASCII) |
AT+LEADDR |
+LEADDR=Param |
Module’s LE MAC address (12 Bytes ASCII) |
AT+NAME{=Param1{,Param2}} |
BR/EDR local name(1~31 Bytes ASCII) |
1: Enable suffix “-XXXX” (lower 4 bytes of MAC address) after local name
Write local name if parameter exist, otherwise read current local name |
AT+LENAME{=Param1{,Param2}} |
BLE local name(1~25 Bytes ASCII) |
0-Disable suffix
+LENAME=Param |
AT+SSP - Get/Set BR/EDR Pairing Mode
Pairing mode (0~1, default:0)
Because BT1058 Bluetooth 5.4 with LEA function. BT1058 BT1038 series does not support ssp 0 parameters |
+SSP=Param |
need reboot. |
AT+COD: Get/Set Device Class
AT+COD=Param |
Class of device(6 bytes ASCII, default:240408 Handsfree device) |
+COD=Param |
Related configuration reference: COD.
AT+PAIR: Get/Set BR/EDR/BLE Visibility
AT+PAIR=Param |
1: Enter BR/EDR/BLE discoverable mode (start advertising/broadcasting)
Module will always be discoverable if no device connected (BR/EDR or BLE),
and be undiscoverable if connected with remote device, unless received this command
AT+PLIST{=Param} |
(0/1~6/12 Bytes MAC address)
(0) Clear all paired record
(1~6) Clear specific paired record with index
(MAC) Clear specific paired record with MAC address
Response1 |
+PLIST=Param1, Param2, Param3{,Param4} |
(1~6) Paired device’s index |
(MAC) Paired device’s MAC address |
(UTF8) Paired device’s name |
Response2 |
+PLIST=E End of the paired record |
AT+DSCA |
Module release all Bluetooth connections with remote device |
AT+TPMODE - Turn On/Off Throughput Mode
AT+TPMODE{=Param} |
Throughput mode(0~1,default:0) 0: Turn Off 1: Turn On |
+TPMODE=Param |
When SPP/GATT profile connected and throughput mode is on,
every byte received via physical UART will be sent to air, vice visa
AT+AUXCFG - Audio Input Mode Configuration
AT+AUXCFG=Param1 |
mode(0-4,default:0)
0: BT Mode
1: LineIn Mode
2: Spdif Mode
3: I2S Mode
4: USB Mode
This command is used to configure the input mode of the module,
BT1006A, BT1026C, BT1026D do not support spdif
After BT1026A, BT1026B,are set to spdif, PA_MUTE pin will be modified to 20 pin
BT1058 V1.0.7 does not support spdif, I2S input
AT+MUTEPIO - Set PA_MUTE pin
AT+MUTEPIO{=Param} |
PIO(0-63, 1026C default:PIO23, BT1058 default:PIO2) |
AT+LINEPIO - Set LineIn Pin
AT+LINEPIO{=Param} |
PIO(0-63, BT1058 default:PIO26) |
Active low |
AT+MICMUTE - mute MIC
AT+MICMUTE=Param |
0-unmute 1-mute |
mute mic when call active |
AT+SPKMUTE - mute Speaker
AT+MICMUTE=Param |
0-unmute 1-mute |
HFP Commands
AT+HFPSTAT - Read HFP State
AT+HFPSTAT |
+HFPSTAT=Param |
Format description reference: +HFPSTAT - HFP State |
AT+HFPRES - Get/Set HFP Sample Rate
AT+HFPRES{=Param} |
Sample rate (Hz) for HFP voice call, 0:16k 1-48K |
+HFPRES=Param |
BT1058 V1.0.1 does not support this command function |
AT+HFPCONN - Establish HFP Connection
AT+HFPCONN{=Param} |
MAC address of target device (12 Bytes ASCII) |
Reconnect to last HFP device if parameter not exist |
AT+HFPDISC - Release HFP Connection
AT+HFPDISC |
Release current HFP connection with remote device |
AT+HFPDIAL - Dial/Redial Phone Number
AT+HFPDIAL{=Param} |
Phone number (1~25 Bytes ASCII) |
Dial specific number if parameter exist, otherwise redial |
AT+HFPDTMF - Send DTMF code
AT+HFPDTMF{=Param} |
DTMF (0~9/#/*) |
AT+HFPANSW - Pick Up Incoming Call
AT+HFPANSW |
Pick up an incoming call |
AT+HFPCHUP - Reject/Hung up Call
AT+HFPCHUP |
Reject incoming call or hung up outgoing/active call |
AT+HFPADTS - Transfer Voice Audio Between Local and Remote Device
AT+HFPADTS=Param |
0: Transfer voice audio from module to remote device
1: Transfer voice audio from remote device to module
Transfer voice audio between module and remote device by default if no parameter set |
AT+HFPVR - Start/Stop Voice Recognition of Remote Device
AT+HFPVR=Param |
0-Stop 1-Start |
Start/Stop Voice Recognition of Remote Device (such as Siri for iOS devices) |
AT+HFPSCO - HFP SCO Configuration
AT+HFPSCO=Param |
0-default 1-always to HF 2-always to AG |
AT+HFPBATT - Send device battery level
AT+HFPBATT=Param |
level(0-9) |
A2DP/AVRCP Commands
AT+A2DPSTAT - Read A2DP State
AT+A2DPSTAT |
+A2DPSTAT=Param |
Format description reference: +A2DPSTAT - A2DP State |
AT+A2DPCONN - Establish A2DP Connection
AT+A2DPCONN{=Param} |
Reconnect to last A2DP device if parameter not exist |
AT+A2DPDISC - Release A2DP Connection
AT+A2DPDISC |
Release current A2DP connection with remote device |
AT+A2DPCFG - Read/Write A2DP Configuration
AT+A2DPCFG=Param |
A base-10 representation of a bit field, for each bit |
0: Disable AAC Codec 1: Enable AAC Codec |
0: Disable APTX Codec 1: Enable APTX Codec |
0: Disable APTX-LL Codec 1: Enable APTX-LL Codec |
0: Disable APTX-HD Codec 1: Enable APTX-HD Codec |
0: Disable APTX-AD Codec 1: Enable APTX-AD Codec |
0: Disable LDAC Codec 1: Enable LDAC Codec |
AT+A2DPDEC - Read A2DP Decoder
AT+A2DPDEC |
+A2DPDEC=Param |
1:SBC 2:AAC 3:APTX 4:APTX-HD 5:APTX-AD |
AT+A2DPRES - The resampling function is enabled
AT+A2DPRES |
+A2DPRES=Param |
0:disable 1:enable |
AT+A2DPBIS - Classic Bluetooth to BIS broadcast stream
AT+A2DPBIS |
0:close 1:open |
AT+AVRCPSTAT - Read AVRCP State
AT+AVRCPSTAT |
+AVRCPSTAT=Param |
Format description reference: +AVRCPSTAT - AVRCP State |
AT+AVRCPCFG - Get/Set AVRCP Configuration
AT+AVRCPCFG{=Param} |
A base-10 representation of a bit field, default:11, for each bit: |
Auto get track ID3 information (title, artist, album) on track changed.default:1 |
Auto get track play progress if value > 0. default:5 second |
Enable volume synchronization Settings. Default :0 |
AT+PLAYPAUSE - Track Play/Pause
AT+PLAYPAUSE |
Send play or pause command to remote media player according to current play status |
AT+PLAY - Track Play
AT+PLAY |
Send play command to remote media player |
AT+PAUSE - Track Pause
AT+PAUSE |
Send pause command to remote media player |
AT+STOP - Track Stop
AT+STOP |
Send stop command to remote media player |
AT+FORWARD - Track Forward
AT+FORWARD |
Send forward command to remote media player |
AT+BACKWARD - Track Backward
AT+BACKWARD |
Send backward command to remote media player |
AT+FFWD - Track FastForward
AT+FFWD=Param |
0-Fast Forward Release, 1-Fast Forward Press |
Send fast forward command to remote media player |
AT+RWD - Track Rewind
AT+RWD=Param |
0-Rewind Release, 1-Rewind Press |
Send rewind command to remote media player |
PBAP Commands
AT+PBSTAT - Read PBAP state
AT+PBSTAT |
+PBATAT=Param |
Format description reference: +PBSTAT - PBAP State |
AT+PBCONN - Establish PBAP Connection
AT+PBCONN{=Param} |
Module will use current HFP device’ MAC address if parameter not exist
For some firmware release, module will establish PBAP connection
automatically on received command AT+PBDOWN
AT+PBDISC - Release PBAP Connection
AT+PBDISC |
Release current PBAP connection with remote device |
AT+PBDOWN - Download Phonebook
Param1{,Param2} |
Phonebook type(0-5)
Max items (1~65535, default:3000 for phonebook; 50 for call log) |
For some phones (e.g. iPhone), the contact download permission
must be turned on in phone’s Bluetooth settting
refer to application note for more description: Phonebook downloading
SPP Commands
AT+SPPSTAT - Read SPP State
AT+SPPSTAT |
+SPPATAT=Param |
Format description reference: +SPPSTAT - SPP State |
AT+SPPCONN{=Param} |
BT1058 V1.0.7 does not support this command function |
AT+SPPDISC |
Release current SPP connection with remote device |
AT+SPPSEND=Param1,Param2 |
Payload length (1~492) |
Payload (1~492 Bytes) |
If throughput mode is on, this command is de-active |
GATT Commands
AT+GATTSTAT - Read GATT State
AT+GATTSTAT |
+GATTATAT=Param |
Format description reference: +GATTSTAT - GATT State |
AT+GATTDISC |
Release current GATT connection with remote device |
AT+GATTSEND=Param1,Param2 |
BIS Commands
AT+BISSTAT - Read BIS State
AT+BISSTAT |
+BISATAT=Param |
Format description reference: +BISSTAT - BIS State |
AT+BISSCAN - Scan BIS-Source devices
AT+BISSCAN{=Param} |
Scan timeout |
AT+BISADD - Add a synchronous broadcast source
AT+BISID{=Param1,Param2} |
adv_sid |
broadcast_id |
AT+BISREMOVE - BIS Remove broadcast source
Format |
AT+BISREMOVE |
NULL |
AT+BISPLAYPAUSE - BIS Play pause control
Format |
AT+BISPLAYPAUSE=Param1 |
NULL |
AT+BISPLAY - BIS play
Format |
AT+BISPLAY=Param1 |
NULL |
AT+BISPAUSE - BIS pause
Format |
AT+BISPAUSE=Param1 |
NULL |
CIS Commands
AT+CISSTAT - Read CIS State
AT+CISSTAT |
+CISSTAT=Param |
GAME Command
AT+GAMEENABLE - Game mode enabled
Format |
AT+GAMEENABLE=Param |
NULL |
AT+GAMEDISABLE - disable
Format |
AT+GAMEDISABLE=Param |
NULL |
Device mode Command
AT+MODCFG - Device mode setting
Format |
AT+MODCFG=Param |
0-slave 1-master |
AT+AUDMODE - Device Bluetooth audio mode Settings
Format |
AT+AUDMODE=Param |
0-bredr 1-bis 2-cis |
Events Table
General Events
+PAIRED - Pair Result
Format |
+PAIRED=Param |
MAC address (12 Bytes ASCII) of current pairing device |
HFP Events
Format |
+HFPSTAT=Param |
(0~6)
+HFPDEV - HFP Remote Device Information
Format |
+HFPDEV=Param1{,Param2} |
(12 Bytes ASCII), Remote MAC address of current HFP connection |
(UTF8), Remote device name of current HFP connection |
+HFPCID - Incoming/Outgoing Call Number
Format |
+HFPCID=Param |
(1~25 Bytes ASCII), Call number |
+HFPCIE - Incoming/Outgoing Call Name
Format |
+HFPCIE=Param |
(UTF8), Call name |
This event is supported by IOS mobile phones, but not supported by most Android phones |
+HFPAUDIO - HFP Voice Audio State
Format |
+HFPAUDIO=Param |
(0) HFP voice audio disconnected, audio input/output routed to remote device
(1) HFP voice audio connected, audio input/output routed to module
+HFPSIG - HFP Remote Device Network Signal Strength
Format |
+HFPSIG=Param |
(0~5)Network signal strength of remote device |
+HFPROAM - HFP Remote Device Roaming State
Format |
+HFPROAM=Param |
(0/1) Roaming state of remote device |
Format |
+HFPBATT=Param |
(0~5) Battery level of remote device |
+HFPNET - HFP Remote Device Network Operator Selection
Format |
+HFPNET=Param |
(UTF8)Network operator selection of remote device |
+HFPMANU - HFP Remote Device Manufacture
Format |
+HFPMANU=Param |
(UTF8)Manufacture name of remote device |
+HFPNUM - HFP Remote Device Phone Subscriber Number
Format |
+HFPNUM=Param |
(ASCII)Phone subscriber number of remote device |
+HFPIBR - HFP Remote Device In-band-ring Support
Format |
+HFPIBR=Param |
(0/1) In-band-ring support |
Report whether the current connected phone support in-band-ring |
A2DP/AVRCP Events
Format |
+A2DPSTAT=Param |
+A2DPDEV - A2DP Remote Device Information
Format |
+A2DPDEV=Param1{,Param2} |
(12 Bytes ASCII), Remote device’s MAC address of current A2DP connection |
(UTF8), Remote device’s name of current A2DP connection |
Format |
+AVRCPSTAT=Param |
+PLAYSTAT - Media Player State
Format |
+PLAYSTAT=Param |
+TRACKSTAT - Media Player Play Progress
Format |
+TRACKSTAT=Param1,Param2,Param3 |
(0~4), Media Player State, see +PLAYSTAT |
(Decimal ASCII),Elapsed time of current track in millisecond |
(Decimal ASCII),Total time of current track in millisecond |
+TRACKINFO - Media Track Information
Format |
+TRACKINFO=Param1,Param2,Param3 |
title |
artist |
album |
Phonebook Access Events
Format |
+PBSTAT=Param |
+PBCNT - Phonebook Entries of Remote Device
Format |
+PBCNT=Param |
Phonebook entries of remote device |
+PBDATA - Phonebook Data
Format1 |
+PBDATA=Param1<FF>Param2<FF>Param3{<FF>Param4} |
Number |
(15 Bytes ASCII), Call time if current download type is call log
Format2 |
+PBDATA=E: Download complete |
Call time may not exist for some mobile phones |
SPP Events
Format |
+SPPSTAT=Param |
Format |
+SPPDATA=Param1,Param2 |
Payload length |
Payload |
GATT Events
Format |
+GATTSTAT=Param |
Format |
+GATTDATA=Param1,Param2 |
Payload length |
Payload |
BIS Events
Format |
+BISSTAT=Param |
(2) Scanning
+BIS - BIS The scanning result
Format |
+BIS=Param1,Param2,Param3,Param4,Param5,Param6 |
index value |
RSSI |
broadcast sid |
broadcast id |
mac address |
device name |
CIS Events
+CISSTAT - CIS State
Format |
+BISSTAT=Param |
(1) LeaUnicasSink_idle
(2) LeaUnicasSink_disconnected
(3) LeaUnicasSink_ase_enabling
(4) LeaUnicasSink_ase_streamming
Application scenarios
profiles initializing and change parameter
The following figure shows Profile initialization and name modification
3 uart_send("AT+NAME\r\n");
4 if(uart_read("+NAME",name_buf))
5 {
6 if(memcmp(name_buf,"CARKIT",6))
7 {
8 uart_send("AT+NAME=CARKIT,0\r\n"); //defalut disable MAC address suffix
9 uart_send("AT+NAME\r\n"); // read bt name
10 if(uart_read("+NAME",name_buf))
11 {
12 if(memcmp(name_buf,"CARKIT",6))
13 {
14 //change name fail
15 }
16 else
17 {
18 //change name success
19 }
20 }
21 }
22 }
modify any parameters, it is recommended to query first and then modify the final verification
Classic BT Receive mode connection
LE Audio Broadcast Scan connection
设备模式切换
