FSC-BT1058 Audio Transmit & Receive AT Command Set
[中文]
Release Note
序号
版本
日期
说明
V1.0.0
2024/05/23
1. Initial version
V1.0.1
2024/07/09
1. Added some LE Audio related commands and Events
2. Added some GATTS related commands and Events
3. Fix known issues
V1.0.2
2025/01/07
1. Fix known issues
2. Added some commands and events
V2.0.0
2026/01/08
1. Added audio source-sink integrated mode
This design guide is suitable for engineers to develop FSC-BT1058 series bluetooth modules
Module Default Settings
BR/EDR Name
FSC-BT1058
BLE Name
FSC-BT1058-LE
UART configuration
Hardware description
Pin diagram
FSC-BT1058 as an example:
_images/BT1058_pin_map.png
Pin description
PIN
Descriptions
I2S_CLK
I2S BCLK
I2S_IN
I2S DATA IN
I2S_OUT
I2S SYNC
Low-level reset
SPDIF_OUT
SPDIF audio output
UART flow control pin (default PA)
Outputs square wave in pairing mode,
Outputs high level when Bluetooth is connected
Outputs low level when BLE is disconnected,
Outputs high level when connected
3.3V power supply,
LDO power supply is recommended
VREG_IN
Power on/off pin
VDD_IO
Pio supply
48
Change the 0-ohm resistor near the antenna to connect an external Bluetooth antenna
Hardware design notes
  • The simple test of the module only needs to connect VDD/VDD_IO/VBUS/GND/UART_RX/UART_TX to use
  • After drawing, please send it to feasy.com for review so as not to have the best bluetooth distance
Functional Notes
  • GATTS (Generic Attribute Profile LE-Peripheral)
  • GATTC (Generic Attribute Profile LE-Central)
  • A2DP-SINK (Advanced Audio Distribution Profile, Sink)
  • A2DP-SOURCE (Advanced Audio Distribution Profile, Source)
  • AVRCP-CONTROLLER (Audio/Video Remote Control Profile, Controller)
  • AVRCP-TARGET (Audio/Video Remote Control Profile, Target)
  • LE-AUDIO (Le Audio Profile)
GATT Service
Characteristic
Throughout Service
Write,
Write Without Response
From APP to Module
From Module to APP
Command Description
Terms
Applicable to the entire document.
  • {}: Content within {…} is optional.
  • <<: COMMAND sent from the Host to the Module.
  • >>: RESPONSE/EVENT replied from the Module to the Host.
  • All commands start with AT+, end with <CR><LF>
  • <CR> means "carriage return", corresponds to hex value 0x0D
  • <LF> means "line feed", corresponds to hex value 0x0A
  • If command has param, param follows behind =
  • If command has multiple params, param must be separated by ,
  • If command has response, response starts with <CR><LF>, ends with <CR><LF>
  • Module will always report command's execution result by using OK for success or ERROR for failure
Example: Read module's BR/EDR name
>> +NAME=FSC-BT1058
Example: Pick up an incoming call when no call incoming actually
<CR><LF>+Event{=Param1{,Param2{,Param3...}}}<CR><LF>
  • All events start with <CR><LF>, end with <CR><LF>
  • If event has param, param follow behind =
  • If event has multiple params, param must be separated by ,
Example: Received "1234567890" from mobile phone via SPP profile
Commands table
AT+HELP - List firmware information and all support command
<COMMAND SUMMARY:DESCRIPTION:PROFILE CATEGORY>
AT+VER - Get firmware version information
+VER - Frmware version information
AT+BAUD - Get/Set uart baudrate
9600/ 19200/ 38400/ 57600/ 115200/ 230400/ 460800
500000/ 921600/ 1000000/ 1382400/ 1500000/ 2000000
Current baudrate
It takes effect immediately and does not need to be restarted
AT+MODCFG - Set Device Source-Sink Mode
AT+MODCFG{=Param}
0-Sink mode for audio reception
1-Source mode for audio transmission
+DEVMOD - Device Mode Information
AT+I2SCFG - Get/Set I2S Configuration
A base-10 representation of a bit field, for each bit
Bit[0]
0: Disable
1: Enable
Bit[1]
0: Master mode
1: Slave mode
Bit[2]
0: 48000Hz sampling rate
1: 44100Hz sampling rate
Bit[3]
0: Data left-aligned
1: Data right-aligned
Bit[4]
0: Data delayed by 1 bit
1: No data delay
Bit[6-5]
00: 16-bit sampling depth
01: 24-bit sampling depth
Current I2S configuration, formatted as above
Takes effect after restart
AT+SPDIFCFG - SPDIF Format Configuration (Valid for audio sink)
AT+SPDIFCFG{=Param}
0-Disable audio output in SPDIF format
1-Enable audio output in SPDIF format
If audio output is SPDIF, the I2S configuration will be invalid.
AT+SPKVOL - Set Speaker Volume (Valid for audio sink)
AT+SPKVOL{=Param}
Volume ('+' / '-'/ 0-15, default:15)
Adjust output volume,
Adjust A2DP volume during music playback,
Adjust HFP volume during calls,
And also support volume adjustment in LEA mode.
AT+MICGAIN - Get/Set input gain (Valid for audio source)
AT+MICGAIN{=Param}
0 ~ 10: Set target value
+: Increase gain
-: Decrease gain
+MICGAIN=Param
Current input gain
In USB input mode, the param only be +/-, and get the param is invalid
In I2S/SPDIF input mode, this command is invalid
AT+REBOOT - Soft reboot
Module will disconnect all profiles then reboot
AT+RESTORE - Restore factory settings
AT+BTEN - Get/Set bluetooth state
0: Bluetooth off
1: Bluetooth on
+BTEN=Param
Current bluetooth state
AT+LECFG - Get/Set random BLE address state
AT+LECFG{=Param}
0: Disable
1: Enable
+LECFG=Param
Current state
AT+PROFILE - Get/Set Bluetooth profile
A base-10 representation of a bit field, for each bit:
HID-DEVICE (Human Interface Device Profile)
BIT[11]
MAP (Message Access Profile)
BIT[12]
LE AUDIO BIS-SINK (Low Energy Audio Broadcast Isochronous Stream Sink)
BIT[13]
LE AUDIO BIS-SOURCE (Low Energy Audio Broadcast Isochronous Stream Source)
BIT[14]
LE AUDIO CIS-SINK (Low Energy Audio Connected Isochronous Stream Sink)
BIT[15]
LE AUDIO CIS-SOURCE (Low Energy Audio Connected Isochronous Stream Source)
Currently used profiles
Modify the configuration, the module restarts automatically
Audio sink uses configurations: SPP, GATTS, HFP-HF, A2DP-SINK, AVRCP-CONTROLLER, LE AUDIO BIS-SINK, LE AUDIO CIS-SINK
Audio source uses configurations: SPP, GATTS, GATTC, HFP-AG, A2DP-SOURCE, AVRCP-TARGET, LE AUDIO BIS-SOURCE, LE AUDIO CIS-SOURCE
HID, PBAP, MAP are currently reserved and their functions are not yet implemented
AT+AUTOCONN - Get/Set the count of auto-reconnection on power-on
0: Disable
1 ~ 15: Reconnect times
Current auto reconnect configuration
In Le Audio, the setting will be invalidated
AT+STAT - Get all state
+STAT=Param1,Param2,Param3,Param4,Param5,Param6,Param7,Param8
+DEVSTAT - Device state
+SPPSTAT - SPP state
+GATTSTAT - GATT state
+HFPSTAT - HFP state
+A2DPSTAT - A2DP State
+AVRCPSTAT - AVRCP state
+BISSTAT - Le Audio Broadcast state
Param8
+CISSTAT - Le Audio Unicast state
AT+DEVSTAT - Get device state
AT+ADDR - Get BR/EDR MAC address
Module's BR/EDR MAC address(12 bytes ASCII)
AT+LEADDR - Get BLE MAC address
Module's LE MAC address(12 bytes ASCII)
AT+NAME - Get/Set BR/EDR name
BR/EDR name
1: Enable suffix“XXXX”(lower 4 bytes of MAC address) after name
BR/EDR name
The configured name shall not exceed 31 bytes in maximum.
AT+LENAME - Get/Set BLE name
BLE name
BLE name
AT+SSP - Read/Write BR/EDR Pairing Mode (Valid for sink)
Pairing mode (0~2, default:1)
BT1058 features Bluetooth 5.4 + LEA. BT1038 & BT1058 series do not support SSP=0 parameter.
Need reboot.
AT+COD - Get/Set class of device
Class of device(6 bytes ASCII)
Current class of device
Class of device reference COD
AT+PAIR - Get/Set Bluetooth Discoverability
0: Exit BR/EDR discoverable mode
1: Enter BR/EDR discoverable mode
+PAIR=Param
Current Bluetooth Discoverability
AT+SCAN - Scan Nearby Devices
AT+SCAN=Param1{,Param2}{,Param3}
0: Stop scanning
1: Scan BR/EDR devices
2: Scan LE devices
3: Scan Le Audio Broadcast audio
Scanning time, maximum 255 (Unit: second)
When Param1 is 2 and 3: 0: LE report format is the same as BR/EDR
When Param1 is 2 and 3: 1: LE reports original broadcast data
When Param1 is 2 and 3: 2: Only report devices that support Le Audio
When Parameter1 is 1: Parameter3 is the filtered scanned device name
+SCAN - Scan result
AT+PLIST - Get/Delete paired list
0: Clear all paired record
1 ~ 8: Clear specific paired record with index
MAC(12 bytes ASCII): Clear specific paired record with MAC address
+PLIST=Param1, Param2{,Param3}
Paired device's index
Paired device's MAC address
Paired device's name(UTF8)
If param not exist then list all paired devices
AT+DSCA - Release all connections
This command only initiates a disconnect request
The actual status depends on the query
AT+TPMODE - Get/Set throughput mode
0: Disable
1: Enable
Current throughput mode
When SPP/GATT profile connected and throughput mode is on
The command will be de-active, every byte received via physical UART will be sent to air
AT+AUXCFG - Get/Set audio input mode
AT+AUXCFG{=Param}
0: USB
1: Analog
2: SPDIF
3: I2S
+AUXCFG=Param
Current audio input mode
It takes effect after the restart
In le audio only support usb and analog
AT+RSSI - Get remote device rssi
AT+RSSI=Param
MAC address of target device(12 bytes ASCII)
+RSSI=Param1,Param2
Target device's RSSI
If 0 is response, the acquisition failed
AT+LINKCFG - Get/Set Auto Scan and Connection (Valid for source)
AT+LINKCFG{=Param1{,Param2}}
0: Disable
1: Enable
0: Scan all devices
1: Only scan devices with audio as the primary service
AT+AUDMODE - Get/Set Bluetooth Audio Mode (Valid for source)
AT+AUDMODE{=Param}
0: BR/EDR mode
1: Le Audio Broadcast mode
2: Le Audio Unicast mode
Change this setting module will reboot
AT+PRINT - Get/Set report mode
AT+PRINT{=Param}
0: Disable
1: Enable
On/Off module actively report a message
AT+MICMUTE - Mute MIC (Valid for sink)
AT+MICMUTE=Param
0-Unmute
1-Mute
Mute the local mic during a call
AT+SPKMUTE - Mute Speaker (Valid for sink)
AT+SPKMUTE=Param
0-Unmute
1-Mute
HFP Commands
AT+HFPSTAT - Get HFP state
+HFPSTAT=Param
AT+HFPCONN - Establish HFP connection
Reconnect to last HFP device if param not exist
AT+HFPDISC - Release HFP connection
AT+HFPRING - Simulate incoming call (Valid for source)
AT+HFPRING{=Param}
Phone number(ASCII)
The phone number contains a maximum of 15 bytes
Dial specific number if parameter exist, otherwise redial
AT+HFPANSW - Pick up incoming call
AT+HFPCHUP - Reject/Hung up call
AT+HFPAUDIO - Establish/Release voice audio(Valid for source)
AT+HFPAUDIO=Param
0: Release voice audio connection with remote hfp sink device
1: Establish voice audio connection with remote hfp sink device
AT+HFPWBS - Get/Set HFP codec negotiation(Valid for source)
AT+HFPWBS{=Param}
0: Disable HFP codec negotiation
1: Enable HFP codec negotiation
+HFPWBS=Param
Current state
AT+HFPNREC - Get/Set HFP CVC
AT+HFPNREC{=Param}
0: Disable HFP CVC
1: Enable HFP CVC
+HFPNREC=Param
Current state
AT+HFPDIAL - Redial/Dial Phone Number (Valid for sink)
AT+HFPDIAL{=Param}
Phone number (1~25 Bytes ASCII)
If the parameter exists, dial the specified number, otherwise, redial.
Example: Redial
<< AT+HFPDIAL
Example: Dial the number "075527924639"
<< AT+HFPDIAL=075527924639
AT+HFPDTMF - Send DTMF (Valid for sink)
AT+HFPDTMF{=Param}
DTMF (0~9/#/*)
Example: Send DTMF "#" during a call
<< AT+HFPDTMF=#
AT+HFPADTS - Voice Switch (Valid for sink)
AT+HFPADTS=Param
0: Transfer voice audio from the module to the remote device
1: Transfer voice audio from the remote device to the module
If the parameter is omitted, switch alternately
AT+HFPVR - Start/Stop Voice Recognition of Remote Device (Valid for sink)
AT+HFPVR=Param
0-Stop
1-Start
Start/Stop voice recognition of the remote device (e.g., Siri on iOS devices)
AT+HFPSCO - SCO Configuration (Valid for sink)
AT+HFPSCO=Param
0-default
1-always to HF
2-always to AG
AT+HFPBATT - Send Device Battery Level (Valid for sink)
AT+HFPBATT=Param
level(0-9)
A2DP/AVRCP Commands
AT+A2DPSTAT - Get A2DP state
AT+A2DPCONN - Establish A2DP connection
Reconnect to last A2DP device if parameter not exist
AT+A2DPDISC - Release A2DP connection
AT+A2DPCFG - Get/Set A2DP configuration
AT+A2DPCFG{=Param}
0: Disable AAC
1: Enable AAC
0: Disable APTX
1: Enable APTX
0: Disable APTX-LL
1: Enable APTX-LL
0: Disable APTX-HD
1: Enable APTX-HD
0: Disable APTX-AD
1: Enable APTX-AD
0: Disable LDAC
1: Enable LDAC
Current A2DP configuration
BT1058 only support AAC,SBC,APTX, APTX-AD, APTX-HD,LDAC
Audio sink supports decoding, while the source does not support encoding
AT+A2DPENC - Get the current encoding method used by A2DP (Valid for source)
AT+A2DPENC
+A2DPENC=Param
+A2DPENC - A2DP Encoder
AT+A2DPDEC - Read A2DP decoding (Valid for sink)
AT+A2DPDEC
+A2DPDEC=Param
Parameter
1:SBC
2:AAC
3:LDAC
4:APTX
5:APTX-HD
6:APTX-AD
AT+A2DPRES - Set Resampling Enable (Valid for sink)
AT+A2DPRES
+A2DPRES=Param
0:Disable resampling
1:Enable resampling
This command is used to set the I2S audio output to fix LRCLK at 44.1K or 48K output
Enabled by default
AT+A2DPAUDIO - Establish/Release A2DP audio connection(Valid for source)
AT+A2DPAUDIO=Param
0: Release A2DP audio connection with remote a2dp sink device
1: Establish A2DP audio connection with remote a2dp sink device
AT+AVRCPSTAT - Get AVRCP state
AT+AVRCPCONN - Establish AVRCP connection
AT+AVRCPCONN{=Param}
Reconnect to last device if parameter not exist
AT+AVRCPDISC - Release AVRCP connection
AT+AVRCPDISC
This command only initiates a disconnect request The actual status depends on the query
AT+AVRCPCFG - Get/Set AVRCP Configuration (Valid for sink)
AT+AVRCPCFG{=Param}
Parameter
Represented as a decimal bit field, default:9, each bit indicates:
Automatically obtain music ID3 information (Title, Artist, Album). Default:1
BIT[1-4]
If greater than 0, automatically obtain music status (playback progress). Default:5(second)
Enable volume synchronization setting. Default:1
Example: Get AVRCP Configuration
<< AT+AVRCPCFG
>> +AVRCPCFG=1
Example: Set to report playback progress every 1 second
<< AT+AVRCPCFG=3
AT+PLAYPAUSE - Play/Pause (Valid for sink)
AT+PLAYPAUSE
Send play or pause command to the remote media player according to the current playback status
AT+PLAY - Play (Valid for sink)
AT+PLAY
Send play command to the remote media player
AT+PAUSE - Pause (Valid for sink)
AT+PAUSE
Send pause command to the remote media player
AT+FORWARD - Next Track (Valid for sink)
AT+FORWARD
Send next track command to the remote media player
AT+BACKWARD - Previous Track (Valid for sink)
AT+BACKWARD
Send previous track command to the remote media player
AT+FFWD - Fast Forward (Valid for sink)
AT+FFWD=Param
0-Send release fast forward command
1-Send press fast forward command
Send fast forward command to the remote media player
AT+RWD - Rewind (Valid for sink)
AT+RWD=Param
0-Send release rewind command
1-Send press rewind command
Send rewind command to the remote media player
GATT Commands
AT+GATTSTAT - Get GATT state
AT+GATTSEND - Send data via GATT
Payload length(1 ~ 236)
Payload(1~236 bytes)
SPP Commands
AT+SPPSTAT - Get SPP state
AT+SPPDISC - Release SPP connection
AT+SPPSEND - Send data via SPP
LE Audio Commands
AT+BISSTAT - Get Le Audio state
AT+BISSTAT
+BISSTAT=Param
AT+BISADD - BIS Add Synchronized Broadcast Source (Valid for sink)
AT+BISADD=Param1,Param2
Broadcast advertising_sid
Broadcast broadcast_id
Example: Add the synchronized and discovered BIS broadcast source via AT+BISADD=15,62640
+BISADD=15,62640
AT+BISREMOVE - BIS Remove Added Synchronized Broadcast Source (Valid for sink)
AT+BISREMOVE
NULL (No parameter)
AT+BISPLAY - BIS Play (Valid for sink)
AT+BISPLAY=Param
NULL (No parameter)
AT+BISPAUSE - BIS Pause (Valid for sink)
AT+BISPAUSE=Param
NULL (No parameter)
AT+CISDISC - Release Le Audio Unicast connection
AT+CISDISC
Only In Le Audio unicast mode support
AT+CISCONN - Establish Le Audio Unicast connection
AT+CISCONN=Param1,Param2
Address type
0:public address
1:random address
Only In Le Audio Unicast mode support
Events table
General Events
Event
Module type
Firmware version
Firmware compile time
Event
+DEVMOD=Param
Sick: Audio Reception
Source: Audio Transmission
Event
0: Power off
1: Power on
0: BR/EDR not discoverable
1: BR/EDR discoverable
0: BLE not advertising
1: BLE advertising
0: BR/EDR not scanning
1: BR/EDR scanning
0: BLE not scanning
1: BLE scanning
+SCAN - Scan result
Event1
+SCAN =Param1,Param2,Param3, Param4,Param5{,Param6{,Param7}}
Index
0: LE public address
1: LE random address
2: BR/EDR address
RSSI(-127 ~ -1)
Size of Param6 if exist
Device name for BR/EDR devices or advertising data for LE devices
Class of device
Event2
Scan finsh
+BIS - Broadcast Source Scan Result
Event 1
+BIS =Param1,Param2,Param3, Param4,Param5{,Param6}
Sequence number
Signal strength
Broadcast SID
Broadcast Broadcast
Broadcast address
Device name/Broadcast data
Event 2
Scan completed
+PAIRED - Pair result
Event
+PAIRED=Param
MAC address(12 bytes ASCII) of current pairing device
+I2SSR - I2S sample rate
Event
+I2SSR=Param
I2S sample rate
HFP Events
Event
+HFPSTAT=Param
0: Unsupported
1: Standby
2: Connecting
3: Connected
4: Outgoing call
5: Incoming call
6: Active call
+HFPDEV - HFP remote device information
Event
Remote MAC address(12 bytes ASCII) of current HFP connection
Remote device name(UTF8) of current HFP connection
+HFPCID - Incoming/Outgoing Call Phone Number
Event
+HFPCID=Param
(1~25 Bytes ASCII), Phone number
Example: Dial 10086
<< AT+HFPDIAL=10086
>> +HFPSTAT=4
>> +HFPCID=10086
>> +HFPCIE=China Mobile
>> +HFPAUDIO=1
Example: Incoming call number 13265463800
>> +HFPSTAT=5
>> +HFPCID=13265463800
>> +HFPCIE=Jerry
>> +HFPAUDIO=1
+HFPCIE - Incoming/Outgoing Call Name
Event
+HFPCIE=Param
(UTF8), Phone name
This event is supported by Apple phones, while most Android phones do not support it
+HFPCONN - HFP connecting
Event
+HFCONN=Param
Remote MAC address(12 bytes ASCII) of current HFP connecting
+HFPAUDIO - HFP voice audio State
Event
0: HFP voice audio disconnected, audio input/output routed to remote device
1: HFP voice audio connected, audio input/output routed to module
+HFPSIG - HFP Remote Device Network Signal Strength
Event
+HFPSIG=Param
(0~5) Network signal strength of the remote device
+HFPROAM - HFP Remote Device Roaming Status
Event
+HFPROAM=Param
(0/1) Roaming status of the remote device
Event
(0~5) Battery level of the remote device
+HFPNET - HFP Remote Device Network Operator
Event
+HFPNET=Param
(UTF8) Network operator selection of the remote device
+HFPMANU - HFP Remote Device Manufacturer
Event
+HFPMANU=Param
(UTF8) Remote device manufacturer
+HFPIBR - HFP Remote Device Supports Incoming Call Ringtone
Event
+HFPIBR=Param
0-Not supported
1-Supported
Indicates whether the currently connected mobile phone supports incoming call ringtones
+HFPNUM - HFP Remote Device Own Phone Number
Event
+HFPNUM=Param
(ASCII) Own phone number of the remote device
+HFPSR - HFP sample rate
Event
Sample rate
+HFPHUNG - HFP remote device reject an incoming call or end an ongoing call
Event
+HFPHUNG
+HFPVGS - HFP remote device spker gian
Event
+HFPVGS=Param
Remote device spker gain
+HFPVGM - HFP remote device microphone gian
Event
+HFPVGM=Param
Remote device microphone gain
A2DP/AVRCP Events
Event
0: Unsupported
1: Standby
2: Connecting
3: Connected
4: Streaming
5: Paused
Event
+A2DPENC=Param
1:SBC
2:APTX
3:APTX-HD
4:APTX-AD
+A2DPDEV - A2DP remote device information
Event
Remote device's MAC address(12 bytes ASCII) of current A2DP connection
Remote device's name(UTF8) of current A2DP connection
+A2DPCONN - A2DP connecting
Event
+A2DPCONN=Param
Remote MAC address(12 bytes ASCII) of current A2DP connecting
+A2DPSR - A2DP codec sample rate
Event
+A2DPSR=Param
Event
0: Unsupported
1: Standby
2: Connecting
3: Connected
+PLAYSTAT - Media Player Playback Status
Event
+TRACKSTAT - Media Player Playback Progress
Event
(0~4), Media player status
(Decimal ASCII), Current music playback time (milliseconds)
(Decimal ASCII), Total duration of the current music (milliseconds)
+TRACKINFO - Media Music Information
Event
Title
Artist
Album
Example: Mobile phone plays the song "Creep-Radio Head"
+AVRCPCONN - AVRCP connecting
Event
+AVRCPCONN=Param
Remote MAC address(12 bytes ASCII) of current AVRCP connecting
+SPKVOL - Remote spker volume change
Event
+SPKVOL=Param
Remote spker volume
+CTVOLUP - volume up
Event
+CTVOLUP
Receive volume up command
+CTVOLDN - volume down
Event
+CTVOLDN
Receive volume down command
+CTPLAY - Track play
Event
+CTPLAY
Receive play command
+CTPAUSE - Track pause
Event
+CTPAUSE
Receive pause command
+CTSTOP - Track stop
Event
+CTSTOP
Receive stop command
+CTFWD - Track forward
Event
+CTFWD
Receive forward command
+CTBACK - Track backward
Event
+CTBACK
Receive backward command
LE Audio Events
Event
+BISSTAT=Param
0: Unsupported
1: Standby
2: Connecting
3: Connected
4: Streaming
5: Pause
Event
+CISSTAT=Param
0: Unsupported
1: Standby
2: Connecting
3: Connected
4: Streaming
5: Pause
+LEASR - LE Audio sample rate
Event
+LEASR=Param
Sample rate
GATT Events
Event
0: Unsupported
1: Standby
2: Connecting
3: Connected
+GATTDATA - GATT received incoming data
Event
+GATTDATA=Param1,Param2
SPP Events
Event
0: Unsupported
1: Standby
2: Connecting
3: Connected
+SPPDATA - SPP received incoming data
Event
+SPPDEV - SPP remote device information
Event
+SPPDEV=Param1
Remote device's MAC address(12 bytes ASCII) of current SPP connection
Application Scenarios
Profile Initialization and Set Device Name
box #LightBlue
bt -> host: +VER=FSC-BT1058,V2.0.4,20260109
rnote over host, bt: Send AT+PAIR=1, enter discoverable
host -> bt: AT+PAIR=1
bt -> host: +DEVSTAT=7 (enter discoverable,phone can find and spp/gatt connect to us)
rnote over host, bt: Set name to "CARKIT",disable suffix. and verify readback
bt -> host: AT+NAME=FSC-BT1058
 8            uart_send("AT+NAME=CARKIT,0\r\n");  // disable MAC address suffix
 9            uart_send("AT+NAME\r\n");   // read bt name
备注
modify any parameters, it is recommended to query first and then modify the final verification
A2DP/HFP Examples (Valid for audio source)
box #LightBlue
rnote over host, bt: scan nearby BR/EDR devices
host -> bt: AT+SCAN=1
bt -> host: +SCAN=1,2,DC0D30000057,-42,11,FSC-BT1026C,240408
bt -> host: +SCAN=2,2,DC0D30000012,-70,16,FSC-BT1006A-0012,240404
host -> bt: AT+A2DPCONN=DC0D30000057 (connect FSC-BT1026C))
bt -> host: +A2DPSTAT=3 (A2DP connected)
bt -> host: +A2DPDEV=DC0D30000057,FSC-BT1026C
bt -> host: +HFPSTAT=3 (HFP connected)
bt -> host: +AVRCPSTAT=3 (AVRCP connected)
bt -> host: +A2DPENC=1 (SBC encoder)
bt -> host: +A2DPSTAT=4 (auto enter A2DP Streaming)
rnote over host, bt: stop Streaming
host -> bt: AT+A2DPAUDIO=0
bt -> host: +A2DPSTAT=5 (A2DP pause)
rnote over host, bt: Establish HFP audio
host -> bt: AT+HFPAUDIO=1
bt -> host: +HFPSTAT=4
bt -> host: +HFPAUDIO=1
bt -> host: +HFPSTAT=6
bt -> host: +HFPSR=16000 (Sample rate : 16000)
rnote over host, bt: Release HFP audio
host -> bt: AT+HFPAUDIO=0
bt -> host: +HFPAUDIO=0
BR/EDR Bluetooth Receive Mode Connection (Valid for audio sink)
rnote over host, bt: Mobile phone scan BT and initiates the connection
bt -> host: +HFPSIG=3
bt -> host: +HFPBATT=4
host -> bt: +HFPDIAL=10086 (Dial "10086")
bt -> host: +HFPSTAT=4,10086
bt -> host: +HFPAUDIO=1 (Establish voice audio)
host -> bt: AT+HFPCHUP(End Call)
bt -> host: +HFPAUDIO=0 (Disconnect voice audio)
host -> bt: AT+PLAY(Play Music)
bt -> host: +PLAYSTAT=1
bt -> host: +TRACKSTAT=1,1000,240000
bt -> host: +TRACKSTAT=1,2000,240000
host -> bt: AT+PAUSE(Pause Music)
Le Audio Broadcast Mode(Valid for audio source)
box #LightBlue
rnote over host, bt: Set Audio mode
host -> bt: AT+AUDMODE=1
bt -> host: +BISSTAT=5 (auto enter Le Aduio Streaming)
bt -> host: +BISSR=48000 (Sample rate : 48000)
备注
Now scan broadcast data using other sink devices that support le audio,such as FSC-BT1038A
Le Audio Unicast Mode(Valid for audio source)
box #LightBlue
rnote over host, bt: change Audio mode
host -> bt: AT+AUDMODE=2
rnote over host, bt: scan nearby devices
host -> bt: AT+SCAN=2,10,2 (only scan le audio)
bt -> host: +SCAN=1,0,00025B00FF02,-52,23,FSC-BT1038A-LE-FF02
rnote over host, bt: Connect device
host -> bt: AT+CSICONN=0,00025B00FF02 (connect FSC-BT1038A-LE-FF02)
bt -> host: +CISSTAT=3
bt -> host: +CISSTAT=4 (auto enter Le Audio Streaming)
bt -> host: +CISSR=48000 (Sample rate : 48000)
LE Audio Broadcast Scan and Connect(Valid for audio sink)
bt -> host: +PROFILE=20651
rnote over host, bt: The module initiates broadcast source scanning
bt -> host: AT+SCAN=3,5
bt -> host: +BIS=1,-61,15,98,DC0D30000062,FSC-BP410-0062
bt -> host: +BIS=2,-48,15,43356,00025B00FF0E,FSC-BP415-ff0e
rnote over host, bt: The command for the module to initiate connection to the broadcast source
bt -> host: AT+BISADD=15,43356
bt -> host: +BISADD=15,43356
bt -> host: +BISSTAT=4
SPP Data Transfer
rnote over host, bt: enter discoverable
rnote over host, bt: phone connect module
bt -> host: +PAIRED=594171484D07
bt -> host: +SPPDEV=594171484D07
bt -> host: +SPPSTAT=3
bt -> host: +DEVSTAT=5
rnote over host, bt: send data to phone
host -> bt: AT+SPPSEND=10,0123456789
rnote over host, bt: received data from phone
bt -> host: +SPPDATA=10,0123456789
rnote over host, bt: disconnect
host -> bt: AT+SPPDISC
备注
SPP connect is not supported iphone
GATT Data Transfer
bt -> host: +GATTSTAT=3
bt -> host: +GATTDEV=594171484D07
host -> bt: AT+GATTSEND=10,0123456789
bt -> host: +GATTDATA=10,0123456789
host -> bt: AT+GATTDISC
Contact Information
Shenzhen Feasycom Co.,Ltd.
Address : Rm 508, Building, Fenghuang Zhigu, NO.50, Tiezai Road, Xixiang, Baoan Dist, Shenzhen, 518100, China.
Telphone : 86-755-23062695
Sales Service : sales@feasycom.com
Support : support@feasycom.com
Home Page : www.feasycom.com
Support Forum : forum.feasycom.com
PDF Download
PDF Download
