FSC-BT6038A programming user guide
Release note
Index
Version
Date
V1.0.0
2024/05/23
First edition
V1.0.1
2024/07/09
Add le audio description
Add GATT description
Fix known issues
V1.0.2
2025/01/07
Fix known issues
Add some command and event descriptions
This design guide is suitable for engineers to develop FSC-BT6038A series bluetooth modules
Module default settings
BR/EDR Name
FSC-BT6038A
BLE Name
FSC-BT6038A-LE
UART configuration
Hardware description
Pin diagram
FSC-BT6038A as an example:
_images/BT6038A_pin_map.png
Pin description
Descriptions
SYS_CTRL
Typically connected to an ON/OFF push button
Also usable as a digital input in normal operation
A
Microphone differential 1 input, positive
Differential audio line input 1, positive
A
Microphone differential 1 input, negative
Differential audio line input 1, negative
MIC_RN
A
Microphone differential 2 input, negative
Differential audio line input 2, negative
MIC_RP
A
Microphone differential 2 input, positive
Differential audio line input 2, positive
A
Mic bias output
NC
N
Not connect
NC
N
Not connect
VDD_IO
P
I/O port supply
PIN34
I2C_SDA
Programmable I/O
Alternative funciton I2C_SDA
PIN35
I2S_SCL
Programmable I/O
Alternative funciton I2C_SCL
NC
N
Not connect
NC
N
Not connect
PIO18
I2S_DOUT
Programmable I/O
Alternative funciton I2S_DOUT
PIO16
I2S_BCLK
Programmable I/O
Alternative funciton I2S_BCLK
PIO19
I2S_DIN
Programmable I/O
Alternative funciton I2S_DIN
PIO17
Programmable I/O
Alternative funciton I2S_WS
PIO15
I2S_MCLK
Programmable I/O
Alternative funciton I2S_MCLK
19
P
Power supply
20
P
Power ground
AIO0
General-purpose analog/digital input or OD LED output
AIO1
23
External reset input
24
VBUS
P
USB power
25
P
Power ground
26
USB_DP
USB data positive
27
USB_DN
USB data negative
28
PIN7
TRBI_MISO
Programmable I/O
TRBI_MISO
29
PIN6
TRBI_MOSI
Programmable I/O
TRBI_MOSI
30
PIN8
TRBI_CLK
Programmable I/O
TRBI_CLK
31
PIO5
Programmable I/O
Alternative funciton UART_TX
PIO4
Programmable I/O
Alternative funciton UART_RX
PIO3
SPDIF_IN
Programmable I/O
Alternative funciton UART_CTS
SPDIF_IN
P
Power ground
35
A
Antenna
P
Power ground
Hardware design notes
  • The simple test of the module only needs to connect VDD/VDD_IO/VBUS/GND/UART_RX/UART_TX to use
  • After drawing, please send it to feasy.com for review so as not to have the best bluetooth distance
Function description
Profiles
  • GATTS (Generic Attribute Profile LE-Peripheral)
  • GATTC (Generic Attribute Profile LE-Central)
  • LEA (Le Audio Profile)
GATT Default service and characteristic
Characteristic
throughput services
Write Without Response
app send to module
module send to app
Command description
Terms
  • Throughout this specification:
  • Content between { } is optional
  • Content behind << represents a command from host
  • Content behind >> represents a response/event to host
Command format
  • All commands start with “AT”, end with <CR><LF>
  • <CR> means “carriage return”, corresponds to hex value 0x0D
  • <LF> means “line feed”, corresponds to hex value 0x0A
  • If command has parameter, parameter follows behind ‘=’
  • If command has multiple parameters, parameter must be separated by ‘,’
  • If command has response, response starts with <CR><LF>, ends with <CR><LF>
  • Module will always report command’s execution result by using “OK” for success or “ERROR” for failure
Example: Get module’s BR/EDR name
>> +NAME=FSC-BT6038A
Example: Pick up an incoming call when no call incoming actually
Event format
<CR><LF>+Event{=Param1{,Param2{,Param3…}}}<CR><LF>
  • All events start with <CR><LF>, end with <CR><LF>
  • If event has parameter, parameter follow behind ‘=’
  • If event has multiple parameters, parameter must be separated by ‘,’
Example: Received “1234567890” from mobile phone via SPP profile
Commands table
General commands
AT+HELP - List firmware information and all support command
<FIRMWARE FUNCTION: appropriate working scenario>
AT+VER - Get firmware version information
+VER - Frmware version information
AT+BAUD - Get/Set uart baudrate
9600/ 19200/ 38400/ 57600/ 115200/ 230400/ 460800
500000/ 921600/ 1000000/ 1382400/ 1500000/ 2000000
Current baudrate
It takes effect immediately and does not need to be restarted
AT+I2SCFG - Get/Set I2S configuration
A base-10 representation of a bit field, for each bit
0: disable
1: enable
0: master
1: slave
0: 48000Hz
1: 44100Hz
0: left justified
1: right justified
0: data 1 bit delay
1: data no delay
BIT[5:6]
01: bit depth=24bits
10: bit depth=32bits
Current I2S configuration
It takes effect after the restart
AT+MICGAIN - Get/Set input gain
AT+MICGAIN{=Param}
0 ~ 10: Set target value
+: Increase
-: Decrease
+MICGAIN=Param
Current input gain
In usb input mode, the parameter only be +/-, and get the parameter is invalid
In I2S/SPDIF input mode, the command is invalid
AT+REBOOT - Soft reboot
Module will disconnect all profiles then reboot
AT+RESTORE - Restore factory settings
AT+BTEN - Get/Set bluetooth state
0: Disable
1: Enable
+BTEN=Param
Current bluetooth state
AT+LECFG - Get/Set random BLE address state
AT+LECFG{=Param}
0: Disable
1: Enable
+LECFG=Param
Current state
AT+PROFILE - Get/Set bluetooth profile
A base-10 representation of a bit field, for each bit:
BIT[11]
LE Audio (LE Audio Profile)
Current profile selection
If modify profile, the module will reboot
BT6038A only support SPP, HFP-AG, A2DP Source, AVRCP Target, LEA, GATT Server
LEA, GATT Server cannot be uesd together
AT+AUTOCONN - Get/Set poweron auto reconnect
0: Disable
1 ~ 15: Reconnect times
Current auto reconnect configuration
In Le Audio, the setting will be invalidated
AT+STAT - Get all state
+STAT=Param1,Param2,Param3,Param4,Param5,Param6,Param7
+DEVSTAT - Device state
+SPPSTAT - SPP state
+GATTSTAT - GATT state
+HFPSTAT - HFP state
+A2DPSTAT - A2DP state
+AVRCPSTAT - AVRCP state
+LEASTAT - LE Audio state
AT+DEVSTAT - Get device state
AT+ADDR - Get BR/EDR MAC address
Module’s BR/EDR MAC address(12 bytes ASCII)
AT+LEADDR - Get BLE MAC address
Module’s LE MAC address(12 bytes ASCII)
AT+NAME - Get/Set BR/EDR name
BR/EDR name
1: Enable suffix“XXXX”(lower 4 bytes of MAC address) after name
BR/EDR name
The name contains a maximum of 31 bytes
AT+LENAME - Get/Set BLE name
BLE name
BLE name
AT+ADVDATA - Get/Set BLE advertising data
AT+ADVDATA{=Param}
advertising data
+ADVDATA=Param
advertising data
This parameter must be a hexadecimal string
Must br an even length and a maximum of 62 bytes hexadecimal string
AT+COD - Get/Set class of device
Class of device(6 bytes ASCII)
Current class of device
Class of device reference COD
AT+PAIR - Get/Set BR/EDR visibility
0: Exit BR/EDR discoverable mode
1: Enter BR/EDR discoverable mode
+PAIR=Param
Current BR/EDR visibility
AT+SCAN - Scan nearby devices
AT+SCAN=Param1{,Param2}{,Param3}
0: Stop scan
1: Scan nearby BR/EDR devices
2: Scan nearby BLE devices
Scan time less than 255 (Unit: s)
0: BLE report like BR/EDR
1: BLE report advertising data
2: Only report support le audio device
+SCAN - Scan result
AT+PLIST - Get/Delete paired list
0: Clear all paired record
1 ~ 8: Clear specific paired record with index
MAC(12 bytes ASCII): Clear specific paired record with MAC address
+PLIST=Param1, Param2{,Param3}
Paired device’s index
Paired device’s MAC address
Paired device’s name(UTF8)
If parameter not exist then list all paired devices
AT+DSCA - Release all connections
This command only initiates a disconnect request
The actual status depends on the query
AT+TPMODE - Get/Set throughput mode
0: Disable
1: Enable
Current throughput mode
When SPP/GATT profile connected and throughput mode is on
The command will be de-active, every byte received via physical UART will be sent to air
AT+AUXCFG - Get/Set audio input mode
AT+AUXCFG{=Param}
0: USB
1: Analog
2: SPDIF
3: I2S
+AUXCFG=Param
Current audio input mode
In le audio only support usb and analog
AT+RSSI - Get remote device rssi
AT+RSSI=Param
MAC address of target device(12 bytes ASCII)
+RSSI=Param1,Param2
Target device’s RSSI
If 0 is returned, the acquisition failed
AT+LINKCFG - Get/Set auto scan and connect
AT+LINKCFG{=Param1{,Param2}}
0: Disable
1: Enable
0: Scan all devices
1: Only scan major service class is rendering or audio
AT+AUDMODE - Get/Set audio mode
AT+AUDMODE{=Param1}
0: BR/EDR mode
1: LE audio broadcast mode
2: LE audio unicast mode
Change this setting module will reboot
AT+PRINT - Get/Set report mode
AT+PRINT{=Param1}
0: Disable
1: Enable
On/Off module actively report a message
HFP commands
AT+HFPSTAT - Get HFP state
+HFPSTAT=Param
AT+HFPCONN - Establish HFP connection
Reconnect to last HFP device if parameter not exist
AT+HFPDISC - Release HFP connection
AT+HFPRING - Simulate incoming call
AT+HFPRING{=Param}
Phone number(ASCII)
The phone number contains a maximum of 15 bytes
Dial specific number if parameter exist, otherwise redial
AT+HFPANSW - Pick up incoming call
AT+HFPCHUP - Reject/Hung up call
AT+HFPAUDIO - Establish/Release voice audio
AT+HFPAUDIO=Param
0: Release voice audio connection with remote hfp sink device
1: Establish voice audio connection with remote hfp sink device
AT+HFPWBS - Get/Set hfp codec negotiation
AT+HFPWBS{=Param}
0: Disable hfp codec negotiation
1: Enable hfp codec negotiation
+HFPWBS=Param
Current state
AT+HFPNREC - Get/Set hfp cvc
AT+HFPNREC{=Param}
0: Disable hfp cvc
1: Enable hfp cvc
+HFPNREC=Param
Current state
A2DP/AVRCP commands
AT+A2DPSTAT - Get A2DP state
AT+A2DPCONN - Establish A2DP connection
Reconnect to last A2DP device if parameter not exist
AT+A2DPDISC - Release A2DP connection
AT+A2DPCFG - Get/Set A2DP configuration
AT+A2DPCFG{=Param}
0: Disable AAC
1: Enable AAC
0: Disable APTX
1: Enable APTX
0: Disable APTX-LL
1: Enable APTX-LL
0: Disable APTX-HD
1: Enable APTX-HD
0: Disable APTX-AD
1: Enable APTX-AD
0: Disable LDAC
1: Enable LDAC
Current A2DP configuration
BT6038A only support APTX, APTX-AD, APTX-HD
AT+A2DPENC - Get A2DP encoder
AT+A2DPENC
+A2DPENC=Param
+A2DPENC - A2DP encoder
AT+A2DPAUDIO - Establish/Release A2DP audio connection
AT+A2DPAUDIO=Param
0: Release A2DP audio connection with remote a2dp sink device
1: Establish A2DP audio connection with remote a2dp sink device
AT+AVRCPSTAT - Get AVRCP state
AT+AVRCPCONN - Establish AVRCP connection
AT+AVRCPCONN{=Param}
Reconnect to last device if parameter not exist
AT+AVRCPDISC - Release AVRCP connection
AT+AVRCPDISC
AT+AVRCPSPKVOL - Get/Set remote volume
AT+AVRCPSPKVOL{=Param}
Volume value(0 - 15)
Set remote volume
The command must be sent after AVRCP connection is established
And the remote device must support volume control
GATT commands
AT+GATTSTAT - Get GATT state
AT+GATTSEND - Send data via GATT
Payload length(1 ~ 236)
Payload(1~236 bytes)
SPP commands
AT+SPPSTAT - Get SPP state
AT+SPPDISC - Release SPP connection
AT+SPPSEND - Send data via SPP
LE Audio commands
AT+LEASTAT - Get Le Audio state
AT+LEASTAT
+LEASTAT=Param
AT+LEADISC - Release Le Audio connection
AT+LEADISC
Only In le audio unicast mode support
AT+LEACONN - Establish le audio connection
AT+LEACONN=Param1
Events table
General events
Event
Module type
Firmware version
Firmware compile time
Event
0: Power off
1: Power on
0: BR/EDR not discoverable
1: BR/EDR discoverable
0: BLE not advertising
1: BLE advertising
0: BR/EDR not scanning
1: BR/EDR scanning
0: BLE not scanning
1: BLE scanning
+SCAN - Scan result
Event1
+SCAN =Param1,Param2,Param3, Param4,Param5{,Param6{,Param7}}
Index
0: LE public address
1: LE random address
2: BR/EDR address
RSSI(-127 ~ -1)
Size of Param6 if exist
Device name for BR/EDR devices or advertising data for LE devices
Class of device
Event2
Scan finsh
+PAIRED - Pair result
Event
+PAIRED=Param
MAC address(12 bytes ASCII) of current pairing device
+I2SSR - I2S sample rate
Event
+I2SSR=Param
I2S sample rate
HFP events
Event
+HFPSTAT=Param
0: Unsupported
1: Standby
2: Connecting
3: Connected
4: Outgoing call
5: Incoming call
6: Active call
+HFPDEV - HFP remote device information
Event
Remote MAC address(12 bytes ASCII) of current HFP connection
Remote device name(UTF8) of current HFP connection
+HFPCONN - HFP connecting
Event
+HFCONN=Param
Remote MAC address(12 bytes ASCII) of current HFP connecting
+HFPAUDIO - HFP voice audio State
Event
0: HFP voice audio disconnected, audio input/output routed to remote device
1: HFP voice audio connected, audio input/output routed to module
+HFPCID - HFP call phone number
Event
+HFPCID=Param
Phone number(ASCII)
+HFPSR - HFP sample rate
Event
Sample rate
+HFPHUNG - HFP remote device reject an incoming call or end an ongoing call
Event
+HFPHUNG
+HFPVGS - HFP remote device spker gian
Event
+HFPVGS=Param
Remote device spker gain
+HFPVGM - HFP remote device microphone gian
Event
+HFPVGM=Param
Remote device microphone gain
A2DP/AVRCP events
Event
0: Unsupported
1: Standby
2: Connecting
3: Connected
4: Streaming
5: Paused
Event
+A2DPENC=Param
1:SBC
2:APTX
3:APTX-HD
4:APTX-AD
+A2DPDEV - A2DP remote device information
Event
Remote device’s MAC address(12 bytes ASCII) of current A2DP connection
Remote device’s name(UTF8) of current A2DP connection
+A2DPCONN - A2DP connecting
Event
+A2DPCONN=Param
Remote MAC address(12 bytes ASCII) of current A2DP connecting
+A2DPSR - A2DP codec sample rate
Event
+A2DPSR=Param
Event
0: Unsupported
1: Standby
2: Connecting
3: Connected
+AVRCPCONN - AVRCP connecting
Event
+AVRCPCONN=Param
Remote MAC address(12 bytes ASCII) of current AVRCP connecting
+SPKVOL - Remote spker volume change
Event
+SPKVOL=Param
Remote spker volume
+CTVOLUP - volume up
Event
+CTVOLUP
Receive volume up command
+CTVOLDN - volume down
Event
+CTVOLDN
Receive volume down command
+CTPLAY - Track play
Event
+CTPLAY
Receive play command
+CTPAUSE - Track pause
Event
+CTPAUSE
Receive pause command
+CTSTOP - Track stop
Event
+CTSTOP
Receive stop command
+CTFWD - Track forward
Event
+CTFWD
Receive forward command
+CTBACK - Track backward
Event
+CTBACK
Receive backward command
LE Audio events
+LEASTAT=Param
0: Unsupported
1: Standby
2: Connecting
3: Connected
4: Streaming
5: Pause
+LEASR - LE Audio sample rate
+LEASR=Param
Sample rate
GATT events
0: Unsupported
1: Standby
2: Connecting
3: Connected
+GATTDATA - GATT received incoming data
+GATTDATA=Param1,Param2
SPP events
0: Unsupported
1: Standby
2: Connecting
3: Connected
+SPPDATA - SPP received incoming data
+SPPDEV - SPP remote device information
Event
+SPPDEV=Param1
Remote device’s MAC address(12 bytes ASCII) of current SPP connection
Application scenarios
profiles initializing and change parameter
The following figure shows Profile initialization and name modification
bt -> host: +VER=FSC-BT6038A,V1.0.1,20240524
rnote over host, bt: send AT+PAIR=1, enter discoverable
host -> bt: AT+PAIR=1
bt -> host: +DEVSTAT=7 (enter discoverable,phone can find and spp/gatt connect to us)
rnote over host, bt: change name to "CARKIT",disable suffix. and verify readback
bt -> host: AT+NAME=FSC-BT6038A
modify any parameters, it is recommended to query first and then modify the final verification
Source mode connection
rnote over host, bt: scan nearby devices
host -> bt: AT+SCAN=1
bt -> host: +SCAN=1,2,DC0D30000057,-42,11,FSC-BT1026C,240408
bt -> host: +SCAN=2,2,DC0D30000012,-70,16,FSC-BT1006A-0012,240404
host -> bt: AT+A2DPCONN=DC0D30000057 (connect FSC-BT1026C)
bt -> host: +A2DPSTAT=3 (A2DP connected)
bt -> host: +A2DPDEV=DC0D30000057,FSC-BT1026C
bt -> host: +HFPSTAT=3 (HFP connected)
bt -> host: +AVRCPSTAT=3 (AVRCP connected)
bt -> host: +A2DPENC=1 (sbc encoder)
bt -> host: +A2DPSTAT=4 (auto enter A2DP Streaming)
rnote over host, bt: stop Streaming
host -> bt: AT+A2DPAUDIO=0
bt -> host: +A2DPSTAT=5 (A2DP pause)
rnote over host, bt: Establish hfp audio
host -> bt: AT+HFPAUDIO=1
bt -> host: +HFPSTAT=4
bt -> host: +HFPAUDIO=1
bt -> host: +HFPSTAT=6
bt -> host: +HFPSR=16000 (Sample rate : 16000)
rnote over host, bt: Release hfp audio
host -> bt: AT+HFPAUDIO=0
bt -> host: +HFPAUDIO=0
Le Audio broadcast mode
rnote over host, bt: change profile
host -> bt: AT+PROFILE=2385
rnote over host, bt: change Audio mode
host -> bt: AT+AUDMODE=1
bt -> host: +LEASTAT=4 (auto enter Le Aduio Streaming)
bt -> host: +LEASR=48000 (Sample rate : 48000)
Now scan broadcast data using other sink devices that support le audio
Le Audio unicast mode
host -> bt: AT+AUDMODE=2
host -> bt: AT+SCAN=2,10,2 (only scan le audio)
bt -> host: +SCAN=1,0,00025B00FF02,-52,23,FSC-BT1038A-LE-FF02
host -> bt: AT+LEACONN=00025B00FF02 (connect FSC-BT1038A-LE-FF02)
bt -> host: +LEASTAT=3
bt -> host: +LEASTAT=4 (auto enter Le Audio Streaming)
SPP data transfer
rnote over host, bt: enter discoverable
rnote over host, bt: phone connect module
bt -> host: +PAIRED=594171484D07
bt -> host: +SPPDEV=594171484D07
bt -> host: +SPPSTAT=3
bt -> host: +DEVSTAT=5
rnote over host, bt: send data to phone
host -> bt: AT+SPPSEND=10,0123456789
rnote over host, bt: received data from phone
bt -> host: +SPPDATA=10,0123456789
rnote over host, bt: disconnect
host -> bt: AT+SPPDISC
SPP connect is not supported iphone
GATT data transfer
bt -> host: +GATTSTAT=3
bt -> host: +GATTDEV=594171484D07
host -> bt: AT+GATTSEND=10,0123456789
bt -> host: +GATTDATA=10,0123456789
host -> bt: AT+GATTDISC
Download PDF Document
