FSC-BT631D Programming User Guide
This design guide is suitable for engineers to develop FSC-BT631D Bluetooth modules
Module Default Settings
FSC-BT631D-XXXX
FSC-BT631D-LE-XXXX
On
Hardware Description
Pin Diagram
_images/BT631D_pin_map.png
I2S_OUT
I2S_CLK
I2S BCLK
I2S_IN
I2S DATA IN
I2S SYNC
I2S_MCLK
I2S MCLK
23
External reset input: active Low
24
VBUS
3.3V power supply, recommended: use LDO power supply
25
USB_DP
USB_DP
USB_DP
27
USB_DN
USB_DN
USB_DN
30
UART RTS(default: PA mute pin)
31
UART TX
UART RX
UART CTS(default: No connection required)
35
Change the 0 ohm resistance near the antenna,
you can connect an external Bluetooth antenna
Hardware Design Notes
  • The simple test of the module only needs to connect VDD/VDD_IO/VREG_IN/GND/UART_RX/UART_TX to use
  • After drawing the schematic diagram, please send it to Feasycom for review,so as to avoid the Bluetooth distance not reaching the best effect
  • BT631D is a module that supports both classic Bluetooth and LE Audio. Currently, LE Audio supports BIS function, and more other functions will be developed in the future.
  • As the transmitter of BIS, the audio source can be the A2DP of the mobile phone, I2S input (for the development board, it is an analog input, currently only supports the external codec TLV320AIC3204), or USB.
  • BIS (broadcast isochronous stream)
  • CIS (Connected Isochronous Stream)
GATT Default service and characteristic
Characteristic
throughput services
app send to module
module send to app
Command Description
Terms
Throughout this specification:
  • {} : Content between { } is optional
  • << : Content behind << represents a COMMAND from Host
  • >> : Content behind >> represents a RESPONSE/EVENT to Host
  • All commands start with “AT”, end with <CR><LF>
  • <CR> means “carriage return”, corresponds to hex value 0x0D
  • <LF> means “line feed”, corresponds to hex value 0x0A
  • If Command has Parameter, Parameter follows behind ‘=’
  • If Command has multiple Parameters, Parameter must be separated by ‘,’
  • If Command has Response, Response starts with <CR><LF>, ends with <CR><LF>
  • Module will always report command’s execution result by using “OK” for success or “ERROR” for failure
Read module’s BR/EDR local name
>> +VER=FSC-BT631D-XXXX
Pick up an incoming call when no call incoming actually
>> ERR003
  • All Events start with <CR><LF>, end with <CR><LF>
  • If Event has Parameter, Parameter follow behind ‘=’
  • If Event has multiple Parameters, Parameter must be separated by ‘,’
  • Use the command AT+SEP to replace the default separator to prevent conflicts
Received “1234567890” from mobile phone via SPP profile
Call phone 10086
>> +HFPSTAT=4
>> +HFPAUDIO=1
>> +HFPSTAT=6,10086
AT+HELP - Firmware Function/Command Summary
Using help command to get the basic summary information
If you need to upgrade to the latest version, please refer to FSC-BT631D OTA User Guide
AT+SEP - Read/write Event delimiter
AT+SEP{=Param}
Setting range 0x01~0xFF, default: ‘,’, where ‘0’ means 0xFF
Returns the current delimiter
Parameters for events/responses, which may contain the same value as the default delimiter,
Use this command to replace the default delimiter to prevent conflicts.
(Usually the default delimiter “,” is replaced by the hexadecimal value “xFF”)
Example:Read the pairing record of the module
>> +PLIST=1,32808,1C5CF226D773, Tony, iPhone12
>> +PLIST=2,40, A0BC30075421, Samsung S8
>> +PLIST=E
Example: Set the separator to ‘0xFF’
<< AT+SEP=0
Example: Read the pairing record of the module again
>> +PLIST=1<FF>32808<FF>1C5CF226D773<FF>Tony, iPhone12
>> +PLIST=2<FF>40<FF> A0BC30075421<FF>Samsung S8
>> +PLIST=E
AT+VER - Get Firmware Version
Module type
Firmware version
Production Date
After upgrading the firmware, the production date will not change
>> +VER=BT631D,V2.6.1,20220922
230400/256000/460800/512000/921600/1382400
+BAUD=Param1,Param2,Param3
Returns all currently supported baud rates
The module will switch the baud rate immediately after receiving this command.
BT631D and BT955 do not support 2400
Read module’s baudrate
>> +BAUD=2400,4800,9600,19200,38400,57600,115200,128000,230400,256000,
460800,512000,921600,1382400
Set baud rate
<< AT+BAUD=9600
AT+I2CREG - Read/write I2C registers
AT+I2CREG=Param1, Param2, Param3 {,Param4}
i2c bus address, 2 byes hex string
i2c register address, 2/4 byes hex string
bytes to read/write (1~64)
value to write
+I2CREG=Param
Returns the current value read by I2C
The current version of BT631D does not fully support this command, please do not use it.
Reserved for subsequent releases.
Example:Read external I2C slave device, address:0x34, register 0003, bytes:2; and modify 0xA13B
<< AT+I2CREG= 34,0003,2
>> +I2CREG=805F
<< AT+I2CREG= 34,0003,2,A13B
AT+I2SCFG - Get/Set I2S Settings
A base-10 representation of a bit field, for each bit
0:disable; 1:enable
0:master; 1:slave
0:FS=48000Hz;1:FS=44100Hz
BIT[3-4]
00: I2S standard format
10: PCM short frame format
BIT[5-6]
10: bit depth=32bits (only 16bits of MSB effective)
11: bit depth=32bits (only used for PCM mode)
Example:Usual configuration and description:
In simulation mode, the module will detect the internal/external codec through I2C at startup and report +CODEC=id
65
67
113
PCM Master; Sample rate=48000Hz; Resolution=16bits; Bit clock= 48000*16*2ch=1.536Mhz
AT+MICGAIN - Get/Set Analog Input Gain
AT+MICGAIN{=Param1,Param2}
music gain (0~15, default:8)
call gain (0~15, default:8)
Adjust Codec analog input volume
AT+SPKVOL - Get/Set Analog Output Volume
AT+SPKVOL{=Param1,Param2}
A2DP Volume (0~15, default:10)
HFP Volume (0~15, default:10)
Adjust Codec analog output volume
AT+REBOOT - Soft Reboot
Module release all Bluetooth connections with remote device then reboot
AT+BTEN - Bluetooth On/Off
0-Power off 1-Power on
AT+PROFILE - Bluetooth Profile Selection
A base-10 representation of a bit field, for each bit:
BIT[13]
BIS/CIS Gateway (LE AUDIO gateway)
BIT[14]
BIS/CIS Headset (LE AUDIO headset)
BIT[15]
*** (For iOS devices)
GATT Server and Client, HFP Sink and Source cannot be enabled at the same time,
A2DP Sink and Source,AVRCP Controller and Target.
BIS Headset can only be enabled individually.
The default Profile: 9387 can be connected by the mobile phone through A2DP,
and the audio will be broadcast through BIS.
Example:Read current profile selection
>> +PROFILE=1195
Example:Only enable A2DP Sink, HFP Sink,disable the others
<< AT+PROFILE=160
Example:Only enableA2DP Source,HFP Source,disable the others
<< AT+PROFILE=80
AT+AUTOCONN - Turn On/Off Power On Auto Reconnect
Expressed in decimal bit field, format reference: AT+PROFILE
Module will attempt to connect last device after power on if set.
AT+STAT - Get All Profile State
Query the current status of all enabled Profiles
Example:Read the current Profile
>> +PROFILE=83
Example:Read Profile status
<< AT+STAT
+STAT=3,1,2,5
_images/profile_state.png
AT+DEVSTAT - Read Device State
Represented in decimal bit field,
AT+ADDR - Read BR/EDR Bluetooth MAC address
Module’s BR/EDR Bluetooth MAC address (12 Bytes ASCII)
Module’s BLE Bluetooth MAC address (12 Bytes ASCII)
BR/EDR local name(1~31 Bytes ASCII)
1: Enable suffix “-XXXX” (lower 4 bytes of MAC address) after local name
Write local name if parameter exist, otherwise read current local name
Read current BR/EDR local name
>> +NAME=FSC-BT631D-XXXX
Change module’s BR/EDR local name to “ABC”,and disable suffix
Change module’s BR/EDR local name to “ABC” and enable suffix
BLE local name(1~25 Bytes ASCII)
In BIS Headset mode, the module will actively search for and local
Bluetooth BIS Gateway device with the same name and actively establish synchronization.
AT+SSP - Read/write BR/EDR pairing mode
Pairing mode (0~3, default:2)
Take effect after restart
AT+PIN - Get/Set BR/EDR Pin Code
Pin code only work in legacy pairing mode, see AT+SSP
Read module’s pin code
Change module’s pin code to 1234
AT+CFM - Accept/reject pairing requests from the remote end
AT+CFM=Param1, Param2
MAC address of the remote device(12Bytes)
0-Reject the remote pairing request
1-Accept pairing requests from the remote end
When +SSP=3, the CFM command is valid
AT+COD: Get/Set Device Class
Class of device(6 bytes ASCII, default:240408 Handsfree device)
Related configuration reference: COD.
AT+PAIR: Get/Set BR/EDR/BLE Visibility
Module will always be discoverable if no device connected (BR/EDR or BLE),
and be undiscoverable if connected with remote device, unless received this command
AT+PAGE: Read/write BR/EDR connectable mode
AT+PAGE=Param
If no device is connected, the module will always be in connectable mode,
If connected to a remote device, the module will not be connectable unless
this command is received
AT+SCAN - Scan Nearby Devices
AT+SCAN=Param1{,Param2{,Param3}}
scan type(0~2)
0: Stop scan
1: Scan nearby BR/EDR devices
2: Scan nearby BLE devices(Some programs do not support)
3: Scan nearby BR/EDR/BLE devices(Some programs do not support)
(1~48)Scan time,unit:1.28s, default:12.8s
(1~25 Bytes ASCII)filter name.
Format description reference: +SCAN - Scan Result
AT+RSSI: Read BR/EDR signal strength
AT+RSSI=Param
MAC address of the currently connected device
RSSI value (-127 ~ 0)
(0) Clear all paired record
(1~8) Clear specific paired record with index
(MAC) Clear specific paired record with MAC address
(1~8) Paired device’s index
In decimal digit field, device connection profile, refer to AT+PROFILE
(MAC)Paired device’s MAC address
(UTF8)Paired device’s name
+PLIST=E End of the paired record
Example:Read module’s paired record
>> +PLIST=1,32808,1C5CF226D773, iPhone12
Example:Clear module’s paired record
AT+AUDROUTE - Audio Route Manager
AT+AUDROUTE{=Param}
Note: HF1 & HF2 means peer Bluetooth headphones
0 Stop audio routing
1 Route music (a2dp streaming) from Module to HP1/HP2 simultaneously
2 Route voice call (hfp sco) between Module and HP1
3 Route voice call (hfp sco) between Module and HP2
4 Route voice call (hfp sco) between HP1 and HP2 (intercom mode)
5 Route voice call (hfp sco) from Module to HP1/HP2 simultaneously
6 Route music (a2dp streaming) from Module to HP1 only
7 Route music (a2dp streaming) from Module to HP2 only
Some route mode require specify firmware version,
refer to application note for more description: Source mode connection
AT+AUXCFG - Audio Input Mode Configuration
AT+AUXCFG{=Param}
Mode (0~3, Default:2)
0: Audio input via USB
1: Audio input via I2S
2: Audio input via A2DP
3: Audio is input via A2DP but is no longer broadcast out via BIS
+AUXCFG=Param
AT+TPMODE - Turn On/Off Throughput Mode
Throughput mode(0~1,default:0) 0: Turn Off 1: Turn On
When SPP/GATT profile connected and throughput mode is on,
every byte received via physical UART will be sent to air, vice visa
AT+TXPOWER - tx power configuration
AT+TXPOWER{=Param}
(value:0-7, Default:7)
Only valid for BT631D Classic Bluetooth part
Value
Power(dBm)
-24
-4
HFP Command
AT+HFPSTAT - Read HFP State
+HFPSTAT=Param1{,Param2{,Param3}}
Format description reference: +HFPSTAT - HFP State
AT+HFPSR - Read/Write HFP Sample rate
AT+HFPSR{=Param}
Sampling rate during HFP call, configurable: 0/8000/16000/48000 Default:0
This parameter will override the voice call settings in AT+I2SCFG,
and use this parameter to set the sampling rate of HFP I2S
AT+HFPCFG - Read/Write HFP configuration
AT+HFPCFG{=Param}
Expressed in decimal bit field, default: 2
0-When HFP is disconnected abnormally, the link to the last disconnected device will not be restored.
1-When HFP is disconnected abnormally, the link to the last disconnected device will not be restored.
0-Turn off the echo cancellation function;
1-turn on the echo cancellation function
0-turn off the three-way calling function,
1-turn on the three-way calling function (the firmware needs to support the three-party calling function)
AT+HFPCONN - Establish HFP Connection
MAC address of target device(12 Bytes ASCII)
Reconnect to last HFP device if parameter not exist
Example:Connect to last HFP device
<< AT+HFPCONN
Example:Connect to specific HFP device with MAC address
<< AT+HFPCONN=1C5CF226D773
AT+HFPDISC - Release HFP Connection
Release current HFP connection with remote device
AT+HFPDIAL - Redial/Dial phone number
AT+HFPDIAL{=Param}
Phone number (1~25 Bytes ASCII)
Dial specific number if parameter exist, otherwise redial
Example:Redial
<< AT+HFPDIAL
Example:Dial “075527924639”
<< AT+HFPDIAL=075527924639
AT+HFPDTMF - Send DTMF
AT+HFPDTMF{=Param}
DTMF (0~9/#/*)
Example:During call,send DTMF “#”
<< AT+HFPDTMF=#
AT+HFPANSW - Pick up Incoming Call
AT+HFPCHUP - Reject/hang up incoming and outgoing calls
Reject an incoming call or hang up an outgoing call/conversation
AT+HFPMCAL - Three-way call control
AT+HFPMCAL=Param
0: Release held call or reject waiting call
1: Release active call and accept another call
2: Hold active call and accept another call
See application scenarios: HFP three-way call operation
AT+HFPADTS - Voice Switching
AT+HFPADTS=Param
1: Stream voice audio from module to remote device
2: Transfer voice audio from remote device to module
If the parameter is empty, alternate switching
AT+HFPVR - Start/Stop speech recognition on remote device
AT+HFPVR=Param
0-Stop 1-Start
Start/stop speech recognition for remote devices (e.g. Siri for iOS devices)
AT+HFPINFO - Read HFP current information
AT+HFPINFO
Returns the current HFP status, signal strength, battery, device name and other information
AT+MICMUTE - Mute Microphone
AT+MICMUTE=Param
0-unmute 1-mute
Mute local microphone during calls
A2DP/AVRCP Commands
AT+A2DPSTAT - Read A2DP State
Format description reference: +A2DPSTAT - A2DP State
AT+A2DPCONN - Establish A2DP Connection
Reconnect to last A2DP device if parameter not exist
AT+A2DPDISC - Release A2DP Connection
Release current A2DP connection with remote device
AT+A2DPINFO - Read A2DP Current Information
AT+A2DPINFO
Returns the current A2DP status, remote device name and other information
AT+A2DPSR - Write A2DP Sample rate
AT+A2DPSR=Param
Sample rate:48000/44100
The setting is valid in A2DP Source mode
AT+AVRCPSTAT - Read AVRCP State
Format description reference: +AVRCPSTAT - AVRCP State
AT+AVRCPCFG - Read/Write AVRCP Configuration
AT+AVRCPCFG{=Param}
A base-10 representation of a bit field, default:3, for each bit:
Auto get track ID3 information (title, artist, album) on track changed.default:1
BIT[1-3]
Auto get track play progress if value > 0. 默认:1(second)
Player browsing function enable/disable
Specify a folder to automatically pull media cover images
Example: Read AVRCP Configuration
<< AT+AVRCPCFG
>> +AVRCPCFG=1
Example: Set to 5 seconds to report playback progress
<< AT+AVRCPCFG=9
AT+PLAYPAUSE - Track Play/Pause
AT+PLAYPAUSE
Send play or pause command to remote media player according to current play status
AT+PLAY - Track Play
AT+PLAY
Send play command to remote media player
AT+PAUSE - Track Pause
AT+PAUSE
Send pause command to remote media player
AT+STOP - Track Stop
AT+STOP
Send stop command to remote media player
AT+FORWARD - Track Forward
AT+FORWARD
Send forward command to remote media player
AT+BACKWARD - Track Backward
AT+BACKWARD
Send backward command to remote media player
AT+REPEAT - Set media player repeat mode
AT+REPEAT{=Param}
Repeat mode (0/1) 0-Turn Off 1-Turn On
+PLAYMODE=Param1,Param2
Format description reference: +PLAYMODE - Media Player Repeat/Shuffle Mode
AT+SHUFFLE - Set media player shuffle mode
AT+SHUFFLE{=Param}
Shuffle mode (0/1) 0-Turn Off 1-Turn On
AT+GETMP - Get the media player of the remote device
AT+GETMP
+BROWDATA=Param1,Param2,Param3,Param4
Format description reference: +BROWDATA - Media Player File System Browsing Data
Get the media player of the remote device. Only players with the browsable flag set support browsing.
For some mobile phones (such as iOS devices), users may need to start the player on the mobile phone for the first time
Please see application scenarios: AVRCP file system browsing
AT+SETMP - Select media player
AT+SETMP=Param
Media player index
To select a media player to browse, the player’s browsable flag must be set.
After selecting the player we will enter the root directory, please refer to the application scenario: AVRCP file system browsing
AT+GETFD - List Subfolders/Tracks of Selected Folder
AT+GETFD=Param1,Param2
Starting position, (1~65535)
End position, (1~65535), Param2 >= Param1
List subfolders or media items in the current folder. Please see application scenarios: AVRCP file system browsing
AT+SETFD - Select And Enter The Folder
AT+SETFD=Param
0:Enter up level folder other:Enter selected folder
Select and enter the folder to browse. Please see application scenarios: AVRCP file system browsing
AT+GETNP - List tracks in the “Now Playing” list
AT+GETNP=Param1,Param2
(1~65535),Start position
(1~65535),End position, Param2 >= Param1
+BROWDATA=M,Param1,Param2,Param3
AT+ADDMP - Add tracks to media player
AT+ADDMP=Param
Track ID
Add selected tracks to media player and start playing
PBAP指令
AT+PBSTAT - Read PBAP state
AT+PBSTAT
+PBATAT=Param
Format description reference: +PBSTAT - PBAP State
AT+PBCONN - Establish PBAP Connection
AT+PBCONN{=Param}
Module will use current HFP device’ MAC address if parameter not exist
For some firmware release, module will establish PBAP connection automatically on received command AT+PBDOWN
AT+PBDISC - Release PBAP Connection
AT+PBDISC
Release current PBAP connection with remote device
AT+PBDOWN - Download Phonebook
AT+PBDOWN=Param1{,Param2}
Phonebook type(0-5)
Max items (1~65535, default:3000 for phonebook; 50 for call log)
For some phones (e.g. iPhone), the contact download permission must be turned on in phone’s Bluetooth settting
refer to application note for more description: Phonebook/Contact photo download
AT+PBABORT - Cancel Phonebook Download
AT+PBABORT
Cancel phonebook download
BIS Command
AT+BISCONN - Connecting to the BIS Gateway device
AT+BISCONN{=Param}
Target device Bluetooth name. If no parameters are provided, it will automatically search and connect to the BIS Gateway device.
CIS Command
AT+CISCONN - Connecting to the CIS Headset device
AT+CISCONN{=Param}
Target device Bluetooth name. Automatically connects to the right earpiece after connecting to the left earpiece. If no parameters are provided, it will reconnect to the previously connected device.
AT+AUDIOMODE - Turn On/Off CIS Mode
AT+AUDIOMODE=Param
(0) Turn off CIS mode,Turn on BIS mode
(1) Turn on CIS mode,Turn off BIS mode
AT+AUDIOCH - Select audio channel
AT+AUDIOCH=Param
(0) Left audio channel
(1) Right audio channel
AT+TALK - Turn On/Off CIS Intercom Communication
AT+TALK=Param
(0) Turn off Intercom
(1) Turn on Intercom
The intercom feature requires establishing a CIS connection first, and the audio source of CIS cannot be A2DP.
The intercom function is established between the transmitter and receiver (left audio channel) of CIS.
SPP Command
AT+SPPSTAT - Read SPP State
Format description reference: +SPPSTAT - SPP State
Release current SPP connection with remote device
Payload (1~492 Bytes UTF8)
Example: Send data “1234567890” to remote device via SPP
GATT Server Command
AT+GATTSTAT - Read GATT State
Format description reference: +GATTSTAT - GATT State
Release current GATT connection with remote device
Example: Send data “1234567890” to remote device via GATT
GATT Client Command
AT+LECONN - GATT Server Connection
+LECONN=Param1,Param2 {, Param3{, Param4}}
12-byte device address + 1-byte address type(0:public,1:random)
ServiceUUID (16 or 128 bit)
WriteUUID (16 or 128 bit)
NotifyUUID (16 or 128 bit)
Initiates a connection to the specified device. The parameter consists of 12 bytes (device address) and 1 byte (address type).
Generally, the address type is 0 or 1.
The address type is obtained by using the AT+SCAN=2 command to scan the third parameter returned :ref: ‘REF100’
Example :+SCAN=0,-74,2,DD0D30037591 indicates that the LE device broadcasts data
Example: Connect the GATT Server with DD0D30037591. The ServiceUUID is 0xFFF0, WriteUUID is 0xFFF2, and NotifyUUID is 0xFFF1
<< AT+LECONN=DD0D300375911,FFF0,FFF2,FFF1
<< OK
AT+LEDISC - Release GATT Connection
AT+LEDISC
Disconnect the current GATT connection from the remote device
AT+LESEND - Send Data Via GATT
+LESEND=Param1,Param2
Example: Send data to remote device through GATT Client “1234567890”
<< AT+LESEND=10,1234567890
HID Command
AT+HIDSTAT - Read HID State
AT+HIDSTAT
+HIDATAT=Param
Format description reference: +HIDSTAT - HID State
AT+HIDCONN - Establish HID Connection
AT+HIDCONN{=Param}
AT+HIDDISC - Release HID Connection
AT+HIDDISC
Release current HID connection with remote device
AT+HIDMODE - Get/Set HID Input Mode
AT+HIDMODE{=Param}
HID keyboard input mode(0~1), default 1
(0) Hex key code
(1) Ascii key code (English)
Module can support various keyboard language with specify firmware,
such as: TURKEY SPAIN PORTUGAL FRANCE GERMANY ITALY CZECH JAPAN
AT+HIDDLY - Get/Set HID Report Period
AT+HIDDLY{=Param}
AT+HIDSEND - Send HID Keyboard Report
AT+HIDSEND=Param1,Param2
Report length
Report payload
Example: Send key code ‘A’ to remote device (on AT+HIDMODE=1)
>> AT+HIDSEND=1,A
<< OK
Example: Send key code ‘4’ to remote device (on AT+HIDMODE=0)
<< AT+HIDSEND=4, xA1 x01 x00 x04
Note: As payload is hex value, hence actual command is:
41 54 2B 48 49 44 53 45 4E 44 3D 34 2C A1 01 00 04 0d 0a
Where:
A1 : report start
01 : page id 1
00 : modifier
04 : key code
Module will auto send debounce key code by itself
AT+HIDCMD - Send HID User Report
AT+HIDCMD=Param
2 bytes hid user report
e.g., for iPhone:
Play/Pause: 00 CD
Stop: 00 B7
Forward: 00 B5
Backward: 00 B6
Fast Forward: 00 B3
Rewind:00 B4
Record:00 B2
VolumpUp:00 E9
VolumpDn:00 EA
Mute:00 E2
On screen keyboard Toggle:01 AE
Example: Send Volume Up to iPhone
<< AT+HIDCMD= x00 xE9
Note: As the payload is hex value, hence actual command is:
41 54 2B 48 49 44 43 4D 44 3D 00 E9 0D 0A
Events Table
General Events
+PWRSTAT - Power on status
+PWRSTAT=Param
0-Powering off 1-Powering on(booting)
It is not recommended to use AT commands during power on and off.
+SCAN - Scan Result
Index
Device address type (0~3)
(0) BR/EDR address
(1) LE public address
(2) LE random address
BR/EDR device name or LE device broadcast data
Device type(6 Bytes ASCII)
+SCAN=E: Stop scan
Example: Scan BR/EDR nearby devices
+SCAN=1,-32,3,B019C66209FA,wt-iphone,7A020C
+SCAN=2,-74,0,DC0D30000053,BW226,040680
+SCAN=3,-43,0,00158354F994,LAPTOP-3L,120104
+PAIRREQ - Pairing Request
+PAIRREQ=Param1,Param2{,Param3}
Passkey (000000~999999)
The MAC address of the currently paired device (12 Bytes ASCII)
The name of the currently paired device
+PAIRED - Pair Result
+PAIRED=Param1,Param2
Pair Result (0)-Success (1~255)-Failure reason
+CODEC - Codec ID
+CODEC=Param
Code id
This command is currently invalid, please ignore it
HFP Events
(0~10)
(7) Active held (3-way-calling)
(8) First call active, second call waiting (3-way-calling)
(9) First call active, second call held (3-way-calling)
(10) First call outgoing, second call held (3-way-calling)
Phone number, When status>3
Phone number (three-way call)
Example: Call 10086
<< AT+HFPDIAL=10086
>> +HFPSTAT=3
>> +HFPSTAT=4,10086
>> +HFPAUDIO=1
Example: The call is coming and the number is 13265463800
>> +HFPSTAT=5, 13265463800
>> +HFPAUDIO=1
+HFPDEV - HFP Remote Device Information
(12 Bytes ASCII), 当前HFP连接远端设备的MAC地址
(UTF8), 当前HFP连接远端设备的名称
Example: HFP connect success with device
+HFPAUDIO - HFP Voice Audio State
(0) HFP voice audio disconnected, audio input/output routed to remote device
(1) HFP voice audio connected, audio input/output routed to module
+HFPSIG - HFP Remote Device Network Signal Strength
+HFPSIG=Param
(0~5) Network signal strength of remote device
+HFPROAM - HFP Remote Device Roaming State
+HFPROAM=Param
(0/1) Roaming state of remote device
(0~5) Battery level of remote device
+HFPNET - HFP Remote Device Network Operator Selection
+HFPNET=Param
(UTF8) Network operator selection of remote device
+HFPMANU - HFP Remote Device Manufacture
+HFPMANU=Param
(UTF8) Manufacture name of remote device
+HFPNUM - HFP Remote Device Phone Subscriber Number
+HFPNUM=Param
(ASCII) Phone subscriber number of remote device
+HFPIBR - HFP Remote Device In-band-ring Support
+HFPIBR=Param
0-No support 1-support
Report whether the current connected phone support in-band-ring
+HFPRING - HFP Remote Device n-band-ring Indication
+HFPRING=Param
0-No support in-bang-ring 1-support in-band-ring
The mobile phone is ringing when the call comes. If the remote mobile phone does not support in-band-ring, the module plays the local ringtone.
A2DP/AVRCP Events
+A2DPDEV - A2DP Remote Device Information
(12 Bytes ASCII), Remote device’s MAC address of current A2DP connection
(UTF8), Remote device’s name of current A2DP connection
+PLAYSTAT - Media Player State
Repeat Mode (1~4)
(1) Off
(2) Single Track
(3) All Tracks
(4) Group
Shuffle Mode (1~3)
(1) Off
(2) All Tracks
(3) Group
+TRACKSTAT - Media Player Play Progress
(0~4), Media Player State, see +PLAYSTAT
(Decimal ASCII),Elapsed time of current track in millisecond
(Decimal ASCII),Total time of current track in millisecond
Example: Read media player play progress every 1s
>> +TRACKSTAT=1,54000,322000
>> +TRACKSTAT=1,55000,322000
>> +TRACKSTAT=1,56000,322000
+TRACKINFO - Media Track Information
title
artist
album
Example: Phone playing song “Creep-Radio Head”
>> +TRACKINFO=Creep,Radiohead,Pablo Honey
+BROWSTAT - Media Browsing Status
+BROWSTAT=Param
(4) Browsing
+BROWDATA=Param1, Param2 {, Param3{, Param4}}
Browsing type, for each type, the following data represents:
P
Parame1: media player information
Parame2: 0 – support browsing; 1- not support browsing
Parame3: media player id
Parame4: media player name
R
Parame1: root dictionary name
Parame2: root dictionary name
F
Parame1: folder ID and name
Parame2: folder ID
Parame3: folder name
M
Parame1: media track ID and name
Parame2: media track ID
Parame3: media track name
E
Parame1: browsing operation result code
Parame2: 0 - browsing success; other - browsing error code
+BIPSTAT - BIP State
+BIPSTAT=Param
BIP configuration files are now only used for media player cover image downloads, please see application scenarios: AVRCP album image download
+COVERART - Media Track Cover Downloaded Successfully
+COVERART=Param
Image ID
The cover image is placed in the specified folder named ImageID.jpg. Please refer to the application scenario: AVRCP album image download
Phonebook Access Events
+PBSTAT=Param
+PBCNT - Phonebook Entries of Remote Device
+PBCNT=Param
Phonebook entries of remote device
+PBDATA - Phonebook Data
+PBDATA=Param1,Param2,Param3{,Param4}
Number
(15 Bytes ASCII), Call time if current download type is call log
+PBDATA=E Download complete
Call time may not exist for some mobile phones
Example: Download all phonebook
<< AT+PBDOWN=1
>> +PBCNT=234
+PBDATA=1 , Jack , 18219146201
+PBDATA=1 , kenan , 8613771972680
+PBDATA=E
Example: Download 10 dialed call log
<< AT+PBDOWN=3,10
>> +PBDATA=3 , China Mobile , 10086 , 20171013T103516
+PBDATA=3 , Jerry , 18688967507 , 20171012T152826
+PBDATA=E
SPP Events
Because the instructions of AAP (Android Auto Protocol) are almost the same as SPP, they are:
+AAPSTAT, +AAPDATA for AAP profile
The documentation will ignore these instructions, and the default BT631D does not support this instruction.
Example: Received data “1234567890” from remote device via SPP
GATT Events
Example: Received data “1234567890” from remote device via GATT
HID Events
+HIDSTAT=Param
Application scenarios
Profiles initializing and change parameter
The following figure shows Profile initialization and name modification
rnote over host, bt: Profile初始化
bt -> host: +DEVSTAT=0
bt -> host: +PWRSTAT=1
bt -> host: +VER=BT631D,V2.0.1,20210922
bt -> host: +PROFILE=1195
bt -> host: +PBSTAT=1
bt -> host: +DEVSTAT=7 (be discovered and opened. The mobile phone can find bt and can connect to it.)
rnote over host, bt: change name to "CARKIT",disable suffix. and verify readback
bt -> host: AT+NAME=FSC-BT631D-1E49
Sink mode connection
BT631D default: AUXCFG=2,PROFILE=9387
bt -> host: +PROFILE=9387
rnote over host, bt: Mobile phone search and connect to us
bt -> host: +A2DPSTAT=3 (A2DP connected)
bt -> host: +AVRCPSTAT=3 (AVRCP connected)
bt -> host: +HFPSTAT=3 (HFP connected)
bt -> host: +HFPSIG=3
bt -> host: +HFPBATT=4
host -> bt: +HFPDIAL=10086 (dial number"10086")
bt -> host: +HFPSTAT=4,10086
bt -> host: +HFPAUDIO=1 (audio established)
host -> bt: AT+HFPCHUP(hung up)
bt -> host: +HFPAUDIO=0 (audio release)
host -> bt: AT+PLAY(media streaming)
bt -> host: +A2DPSTAT=5
bt -> host: +PLAYSTAT=1(player playing)
bt -> host: +TRACKINFO=song,artist,album(track id3 info)
bt -> host: +TRACKSTAT=1,1,240
bt -> host: +TRACKSTAT=1,2,240
host -> bt: AT+PAUSE(pause media player)
bt -> host: +A2DPSTAT=4
The transmission(source) mode connection needs to configure the module to A2DP Source, HFP Source By default, the program will not actively enter audio transmission mode or call (intercom) mode after connecting to headphones or speakers. You need to send instructions: Start audio transmission (AT+AUDROUTE=1) Start call (AT+AUDROUTE=2)
bt -> host: +PROFILE=339
rnote over host, bt: Scan nearby headphones and audio devices and connect them
host -> bt: AT+SCAN=1
bt -> host: +SCAN=1,-87,0,DC0D30001E49,FSC-BT631D-1E49,5A020C
bt -> host: +SCAN=2,-78,0,7C9A1DA36B41,AirPods,240404
host -> bt: AT+A2DPCONN=7C9A1DA36B41
bt -> host: +A2DPDEV=7C9A1DA36B41,AirPods
bt -> host: +HFPSTAT=2
bt -> host: +HFPDEV=7C9A1DA36B41,AirPods
rnote over host, bt: Start audio transmit mode
host -> bt: AT+AUDROUTE=1
bt -> host: +AUDMODE=1 (Returns the current audio routing mode)
rnote over host, bt: Release audio transmit mode
host -> bt: AT+AUDROUTE=0
bt -> host: +AUDMODE=0
rnote over host, bt: Start call and intercom mode
host -> bt: AT+AUDROUTE=2
bt -> host: +HFPAUDIO=1 (audio establish)
bt -> host: +AUDMODE=2
rnote over host, bt: Release call and intercom mode
MCU connects AirPods and starts audio transmission. Reference code:
 1#define PROFILE_HFP_HF              (uint16)(BIT3)
 2#define PROFILE_HFP_AG              (uint16)(BIT4)
 3#define PROFILE_A2DP_SINK           (uint16)(BIT5)
 4#define PROFILE_A2DP_SOURCE         (uint16)(BIT6)
 6void bt_connect(void)
 7{
 8    //enable hfp source,a2dp source,avrcp tg,spp,gatt
 9    uart_send("AT+PROFILE=339\r\n"); //if profile changes,module will auto reboot,
10    wait_ms(500);
11    uart_send("AT+PROFILE\r\n");
12    uint32 profiles = uart_read("+PROFILE",profiles);
13    if(profiles & (PROFILE_A2DP_SOURCE|PROFILE_HFP_AG))
14    {
15        uint8 addr[6];
16        uint8 buf[30]={0};
17        uint8 a2dp_state=0
18        uart_send("AT+SCAN=1\r\n");
19        uart_read_scan_addr("+SCAN",addr);
20        sprintf(buf,"AT+A2DPCONN=%s\r\n",addr);
21        uart_send(buf); //send a2dp connect
23        uart_read("+A2DPSTAT",a2dp_state);
24        if(a2dp_state == 3) //a2dp connected
25        {
26            uart_send("AT+AUDROUTE=1"); // start a2dp audio
27        }
28        uart_read("+A2DPSTAT",a2dp_state);
29        if(a2dp_state == 5)
30        {
31            //a2dp streaming
32        }
33    }
34    else
35    {/*not support master*/}
36}
BT631D and other modules do not turn on the three-way calling function. If you need to test this function, please contact Feiyitong.
rnote over host, bt: HFP connected
rnote over host, bt: Dial "10086"
host -> bt: AT+HFPDIAL=10086
bt -> host: +HFPSTAT=4,10086 (phone dialing)
rnote over host, bt: Three-way call
bt -> host: +HFPSTAT=8,10086,18620277271
host -> bt: AT+HFPMCAL=2 (Hold active call and accept another call)
bt -> host: +HFPSTAT=9,18620277271,10086 (18620277271 active,10086 hold)
bt -> host: +HFPSTAT=9,10086,18620277271 (10086 active,18620277271 hold)
host -> bt: AT+HFPMCAL=1 (Release active call and accept another call)
bt -> host: +HFPSTAT=6,18620277271 (one call active now)
rnote over host, bt: hang up the phone
The BT631D module does not open this function. If you need to test this function, please contact Feitong.
rnote over host, bt: A2DP/AVRCP connected
rnote over host, bt: Operating file browsing function
bt -> host: +BROWSTAT=3 (browsing channel connected)
host -> bt: AT+GETMP (retrieve media players)
bt -> host: +BROWSTAT=4
bt -> host: +BROWDATA=P,1,1,Music (found browsable media player)
bt -> host: +BROWDATA=E,0
host -> bt: AT+SETMP=1 (select player)
bt -> host: +BROWDATA=R,iPhone (filesystem root:iPhone)
host -> bt: AT+GETFD=1,5 (list folders under root dir)
bt -> host: +BROWDATA=F,0100000000000000,music (/iPhone/music)
bt -> host: +BROWDATA=F,0200000000000000,playlist (/iPhone/playlist)
host -> bt: AT+SETFD=0200000000000000 (list folders under playlist)
bt -> host: +BROWDATA=F,0100000000000000,Recently added
bt -> host: +BROWDATA=F,524A57F5E4594DE6,Play history
bt <--> host: (continue list sub dir until find audio tracks:AT+SETFD=folder id,AT+GETFD=x,y)
bt -> host: +BROWDATA=M,285E9813C3AB900E,New Soul
bt -> host: +BROWDATA=F,C15E9813C3AB900E,BLUE
host -> bt: AT+ADDMP=C15E9813C3AB900E (select audio track and add to media player)
bt --> host: media player playing BLUE now
Album image downloading is only supported by the vehicle protocol stack module, BT631D module does not support.
rnote over host, bt: Download album image
bt -> host: +BIPSTAT=3 (basic image profile connected)
bt <--> host: music start streaming
bt -> host: +BIPSTAT=4 (blueware auto pulling coverart jpeg image background)
bt -> host: +COVERART=1000090 (download complete)
Contact photo Only supported by vehicle protocol stack module, not supported by BT631D module
rnote over host, bt: download all phonebook
host -> bt: AT+PBDOWN=1
bt -> host: +PBSTAT=2
bt -> host: +PBSTAT=3 (PBAP connected)
bt -> host: +PBSTAT=4 (PBAP is downloading)
bt -> host: +PBDATA=1,Local number,+8618620277272
bt -> host: +PBDATA=1,zhang,0571-85592192
bt -> host: +PBDATA=1,jerry,18909731215
bt -> host: +PBDATA=E (Download completed)
rnote over host, bt: Download all phonebooks and request avatars
host -> bt: AT+PBDOWN=1,,,1
bt <--> host: (if item's photo flag set,photo image number.jpg should be placed in spcecify folder)
bt -> host: +PBDATA=1,Local number,+8618620277272,1
bt -> host: +PBDATA=1,jerry,18909731215,1
rnote over host, bt: download 50 contacts in recent call history
host -> bt: AT+PBWODN=5,50
bt -> host: +PBDATA=3,yidong,+10086,20200213T114247
bt -> host: +PBDATA=2,andy,85592192,20200212T104202
Download PDF Document
