FSC-BT936D programming user guide
This design guide is suitable for engineers to develop FSC-BT936D series Bluetooth modules
Module Default Settings
FSC-BT936D-XXXX |
FSC-BT936D-LE-XXXX |
On |
Hardware Description
Pin Diagram
MIC_N |
Audio |
MIC input, negative |
MIC_P |
Audio |
MIC input, positive |
MIC_BIAS |
Audio |
MIC Power Supplies |
SPK_LP |
Audio |
Headphone/speaker differential L output, positive |
SPK_LN |
Audio |
Headphone/speaker differential L output, negative |
SPK_RN |
Audio |
Headphone/speaker differential R output, negative |
SPK_RP |
Audio |
Headphone/speaker differential R output, positive |
19 |
Power supply for I/O ports, DC 3.3V |
20 |
21 |
LED2 |
output 1KHZ square wave when not connected with phone,
output high level when connected with phone.
22 |
output low level when not connected with headphone,
output high level when connected with headphone.
23 |
External reset input: active Low |
31 |
UART TX |
UART RX |
35 |
external antenna |
Hardware Design Notes
The simple test of the module only needs to connect VDD/GND/UART_RX/UART_TX to use
After drawing the schematic diagram, please send it to Feasycom for review, so as to prevent the Bluetooth distance from not reaching the best effect
SPP (Serial Port Profile)
GATTS (Generic Attribute Profile LE-Peripheral role)
GATTC (Generic Attribute Profile LE-Central role)
HFP-HF (Hands-Free Profile)
HFP-AG (Hands-Free-AG Profile)
A2DP-Sink (Advanced Audio Distribution Profile)
A2DP-Source (Advanced Audio Distribution Profile)
AVRCP-Controller (Audio/Video remote controller Profile)
AVRCP-Target (Audio/Video remote controller Profile)
HID-DEVICE (Human Interface Profile)
PBAP (Phonebook Access Profile)
GATT Throughput Service
Service: 0000B360-D6D8-C7EC-BDF0-EAB1BFC6BCBCWrite、Notify: 0000B362-D6D8-C7EC-BDF0-EAB1BFC6BCBC
Command Description
Terms
Throughout this specification:
Content between { } is optional
Content behind << represents a COMMAND from Host
Content behind >> represents a RESPONSE/EVENT to Host
All commands start with “AT”, end with <CR><LF>
<CR> means “carriage return”, corresponds to hex value 0x0D
<LF> means “line feed”, corresponds to hex value 0x0A
If Command has Parameter, Parameter follows behind ‘=’
If Command has multiple Parameters, Parameter must be separated by ‘,’
If Command has Response, Response starts with <CR><LF>, ends with <CR><LF>
Module will always report command’s execution result by using “OK” for success or “ERR<code>” for failure
Error Code |
Meaning |
001 |
Failed |
002 |
Invalid parameter |
003 |
Invalid state |
004 |
Command mismatch |
005 |
Busy |
006 |
Command not supported |
007 |
Profile not turned on |
008 |
No memory |
Others |
Reserved for future use |
All Events start with <CR><LF>, end with <CR><LF>
If Event has Parameter, Parameter follow behind ‘=’
If Event has multiple Parameters, Parameter must be separated by ‘,’
Use command AT+SEP to replace default separator for conflict prevention
For some events, use “-”、”~” to replace “+”
AT+SEP - Read/Write Event separator
AT+SEP{=Param} |
set range: 0x01~0xFF,default: ‘,’ ,Where ‘0’ indicates 0xFF |
Returns the current separator |
The parameters for events/responses may contain the same value as the default separator
Use this command to replace the default separator for conflict prevention
(Usually replace the default separator “, “with the hexadecimal value” xFF”)
AT+VER - Get Firmware Version
+VER=Param1,Param2,Param3 |
Module type |
Firmware version |
Data of production |
The date of production in response will not be changed after firmware upgrade |
baudrate (2400/4800/9600/19200/38400/57600/128000/230400/
256000/460800/512000/921600/1382400, default:115200)
baudrate |
Module will change baudrate to target value immediately |
AT+MICGAIN - Get/Set Analog Input Gain
AT+MICGAIN{=Param} |
Gain (0~15, default:8), Support ‘+’, ‘-’ adjustment |
Adjust input volume |
AT+SPKVOL - Get/Set Analog Output Volume
AT+SPKVOL{=Param} |
VOL (0~15, default:12), Support ‘+’, ‘-’ adjustment |
Adjust output volume |
Adjust the volume of the call during the call, otherwise adjust the volume of the music |
AT+REBOOT - Soft Reboot
Module release all Bluetooth connections with remote device then reboot |
Module restore all factory settings then reboot |
AT+PROFILE - Bluetooth Profile Selection
AT+PROFILE{=Param} |
A base-10 representation of a bit field, for each bit: |
SPP (Serial Port Profile) |
GATT Server (Generic Attribute Profile) |
GATT Client (Generic Attribute Profile) |
HFP-HF (Hands-Free Profile Handsfree) |
HFP-AG (Hands-Free Profile Audio Gateway) |
A2DP Sink (Advanced Audio Distribution Profile) |
A2DP Source (Advanced Audio Distribution Profile) |
AVRCP Controller (Audio/Video remote controller Profile) |
AVRCP Target (Audio/Video remote controller Profile) |
HID Keyboard (Human Interface Profile) |
PBAP Server (Phonebook Access Profile) |
iAP2 (For iOS devices) |
+PROFILE=Param |
This command does not need to be set, |
AT+DEVSTAT - Read device status
AT+DEVSTAT |
+DEVSTAT=Param |
A base-10 representation of a bit field, |
0: Power Off; 1: Power On |
0: BR/EDR Not Discoverable; 1: BR/EDR Discoverable |
0: BLE Not Advertising; 1: BLE Advertising |
0: BR/EDR Not Scanning; 1: BR/EDR Scanning |
0: BLE Not Scanning; 1: BLE Scanning |
Example:usual combination and description
0 |
Device power off |
Device power on |
Device power on, BR/EDR Discoverable |
Device power on, BR/EDR Not Discoverable, BLE Advertising |
Device power on, BR/EDR Discoverable, BLE Advertising |
Device power on, BR/EDR Not Discoverable, BLE Advertising, Scanning nearby BR/EDR devices |
AT+ADDR - Get BR/EDR MAC Address
Module’s BR/EDR MAC address (12 Bytes ASCII) |
AT+LEADDR |
+LEADDR=Param |
Module’s LE MAC address (12 Bytes ASCII) |
AT+NAME{=Param1{,Param2}} |
BR/EDR local name(1~31 Bytes ASCII) |
1: Enable suffix “-XXXX” (lower 4 bytes of MAC address) after local name
2: Enable suffix “-XXXXXX” (lower 6 bytes of MAC address) after local name
Bluetooth Name |
Write local name if parameter exist, otherwise read current local name |
AT+LENAME{=Param1{,Param2}} |
BLE local name(1~25 Bytes ASCII) |
+LENAME=Param |
AT+SSP - Get/Set BR/EDR Pairing Mode
Pairing mode (0~3, default:2)
+SSP=Param |
need reboot |
AT+PIN - Get/Set BR/EDR Pin Code
AT+PIN{=Param} |
Pin code(4~15 Bytes ASCII, default:0000) |
+PIN=Param |
Pin code only work in legacy pairing mode, see AT+SSP |
AT+CFM - Accept/Reject Remote Pairing Request
AT+CFM=Param1, Param2 |
12 Bytes MAC address of remote device |
0-Reject remote pairing request
1-Accept remote pairing request
Only used for pairing request in pairing mode 3, see AT+SSP |
AT+PAIR: Get/Set BR/EDR/BLE Visibility
AT+PAIR=Param |
Module will always be discoverable if no device connected (BR/EDR or BLE),
and be undiscoverable if connected with remote device, unless received this command
AT+PAGE: Get/Set BR/EDR Connectability
AT+PAGE=Param |
Module will always be connectable mode if no device connected,
and be unconnectable if connected with remote device, unless received this command
AT+SCAN - Scan Nearby Devices
AT+SCAN=Param1{,Param2{,Param3}} |
scan type(0~3)
0: Stop scan
1: Scan nearby BR/EDR devices
2: Scan nearby BLE devices
(1~48)Scan period. unit:1.28s, default:12.8s |
(1~25 Bytes ASCII)Name filter. Filter scan results with name if set |
EDR:(1~25 Bytes ASCII)COD filter. BLE:1-Scan tire pressure equipment |
Format description reference: +SCAN - Scan Result +HFPSTAT - HFP State
AT+RSSI: Get BR/EDR Signal Strength
AT+RSSI=Param |
12 Bytes MAC address of current connected device |
+PIN=Param |
RSSI value (-127 ~ 0) |
AT+PLIST{=Param} |
(0) Clear all paired record
(1~8) Clear specific paired record with index
(MAC) Clear specific paired record with MAC address
Response1 |
+PLIST=Param1, Param2, Param3{,Param4} |
(1~8) Paired device’s index |
A base-10 representation of a bit field, support profiles of device, see AT+PROFILE |
(MAC) Paired device’s MAC address |
(UTF8) Paired device’s name |
Response2 |
+PLIST=E End of the paired record |
AT+DSCA{=Param} |
(0/1/12 Bytes MAC address)
(0) Disconnect Bluetooth from phone
(1) Disconnect Bluetooth from headphones
(MAC) Disconnect from specified MAC address
Disconnect all connected Bluetooth if no parameter set
Module release all Bluetooth connections with remote device |
AT+AUDROUTE{=Param} |
Note: HF1 & HF2 means peer Bluetooth headphones
0 Stop audio routing
1 Route music (a2dp streaming) from Module to HP1/HP2 simultaneously
2 Route voice call (hfp sco) between Module and HP1
3 Route voice call (hfp sco) between Module and HP2
4 Route voice call (hfp sco) between HP1 and HP2 (intercom mode)
5 Route voice call (hfp sco) from Module to HP1/HP2 simultaneously
6 Route music (a2dp streaming) from Module to HP1 only
7 Route music (a2dp streaming) from Module to HP2 only
Some route mode require specify firmware version,
BT936D only supports call switch by sending AUDROUTE=2,3
refer to application note for more description: Source mode connection
AT+FOCUS - Select connected audio devices
AT+FOCUS{=Param1{,Param2}} |
(12 Bytes ASCII)MAC address of target device/headphone 1 |
(12 Bytes ASCII)MAC address of target device/headphone 2 |
Decription |
BT936B/BT906/BT936D supports linking two earphones, BT930 only supports linking one earphone |
HFP Commands
AT+HFPSTAT - Read HFP State
AT+HFPSTAT |
+HFPSTAT=Param1{,Param2{,Param3}} |
Format description reference: +HFPSTAT - HFP State |
AT+HFPCONN - Establish HFP Connection
AT+HFPCONN{=Param} |
MAC address of target device (12 Bytes ASCII) |
Reconnect to last HFP device if parameter not exist |
AT+HFPDISC - Release HFP Connection
AT+HFPDISC |
Release current HFP connection with remote device |
AT+HFPDIAL - Dial/Redial Phone Number
AT+HFPDIAL{=Param} |
Phone number (1~25 Bytes ASCII) |
Dial specific number if parameter exist, otherwise redial |
AT+HFPDTMF - Send DTMF code
AT+HFPDTMF{=Param} |
DTMF (0~9/#/*) |
AT+HFPANSW - Pick Up Incoming Call
AT+HFPANSW |
Pick up an incoming call |
AT+HFPCHUP - Reject/Hung up Call
AT+HFPCHUP |
Reject incoming call or hung up outgoing/active call |
AT+HFPADTS - Transfer Voice Audio Between Local and Remote Device
AT+HFPADTS=Param |
1: Transfer voice audio from module to remote device
2: Transfer voice audio from remote device to module
Transfer voice audio between module and remote device by default if no parameter set |
AT+HFPVR - Start/Stop Voice Recognition of Remote Device
AT+HFPVR=Param |
0-Stop 1-Start |
Start/Stop Voice Recognition of Remote Device (such as Siri for iOS devices) |
AT+HFPINFO - Read HFP information
AT+HFPINFO |
Return the current HFP status, signal strength, battery, device name, etc. |
AT+MICMUTE - Mute Mic
AT+MICMUTE=Param |
0-unmute 1-mute |
mute mic when call active |
A2DP/AVRCP Commands
AT+A2DPSTAT - Read A2DP State
AT+A2DPSTAT |
+A2DPSTAT=Param |
Format description reference: +A2DPSTAT - A2DP State |
AT+A2DPCONN - Establish A2DP Connection
AT+A2DPCONN{=Param} |
Reconnect to last A2DP device if parameter not exist |
AT+A2DPDISC - Release A2DP Connection
AT+A2DPDISC |
Release current A2DP connection with remote device |
AT+A2DPINFO - Read A2DP information
AT+A2DPINFO |
Return the current A2DP status, remote device name , etc. |
AT+AVRCPSTAT - Read AVRCP State
AT+AVRCPSTAT |
+AVRCPSTAT=Param |
Format description reference: +AVRCPSTAT - AVRCP State |
AT+AVRCPCFG - Get/Set AVRCP Configuration
AT+AVRCPCFG{=Param} |
A base-10 representation of a bit field, default:3, for each bit: |
Auto get track ID3 information (title, artist, album) on track changed.default:1 |
Auto get track play progress if value > 0. default:1 second |
Browsing function enable/disable |
Auto pull media cover art image to specify folder |
AT+PLAYPAUSE - Track Play/Pause
AT+PLAYPAUSE |
Send play or pause command to remote media player according to current play status |
AT+PLAY - Track Play
AT+PLAY |
Send play command to remote media player |
AT+PAUSE - Track Pause
AT+PAUSE |
Send pause command to remote media player |
AT+STOP - Track Stop
AT+STOP |
Send stop command to remote media player |
AT+FORWARD - Track Forward
AT+FORWARD |
Send forward command to remote media player |
AT+BACKWARD - Track Backward
AT+BACKWARD |
Send backward command to remote media player |
PBAP Commands
AT+PBSTAT - Read PBAP state
AT+PBSTAT |
+PBATAT=Param |
Format description reference: +PBSTAT - PBAP status |
AT+PBCONN - Establish PBAP Connection
AT+PBCONN{=Param} |
Module will use current HFP device’ MAC address if parameter not exist
For some firmware release, module will establish PBAP connection
automatically on received command AT+PBDOWN
AT+PBDISC - Release PBAP Connection
AT+PBDISC |
Release current PBAP connection with remote device |
AT+PBDOWN - Download Phonebook
Param1{, Param2{, Param3{, Param4}}} |
Phonebook type(0-5)
Max items (1~65535, default:3000 for phonebook; 50 for call log) |
Phonebook format (defaut:0)
(0) Family Name, Middle Name, Given Name
(1) Given Name, Middle Name, Family Name
(2) Raw vCard 2.1
Contact photo required (0/1) |
For some phones (e.g. iPhone), the contact download permission
must be turned on in phone’s Bluetooth settting
refer to application note for more description: Phonebook downloading
AT+PBABORT - Abort Downloading
AT+PBABORT |
Abort downloading |
SPP Commands
AT+SPPSTAT - Read SPP State
AT+SPPSTAT |
+SPPATAT=Param |
Format description reference: +SPPSTAT - SPP State |
AT+SPPCONN{=Param} |
AT+SPPDISC |
Release current SPP connection with remote device |
AT+SPPSEND=Param1,Param2 |
Payload length (1~492) |
Payload (1~492 Bytes UTF8) |
If throughput mode is on, this command is de-active |
GATT Commands
AT+GATTSTAT - Read GATT State
AT+GATTSTAT |
+GATTATAT=Param |
Format description reference: +GATTSTAT - GATT State |
AT+GATTDISC |
Release current GATT connection with remote device |
AT+GATTSEND=Param1,Param2 |
Event Table
General Events
+PWRSTAT - Powering State
Format1 |
+PWRSTAT=Param |
0-Powering off 1-Powering on(booting) |
AT Command is not recommended to be used while powering on/off state |
+SCAN - Scan Result
Format1 |
+SCAN=Param1,Param2,Param3,Param4,Param5,Param6 |
Index |
RSSI (-127 ~ -1) |
Device address type (0~3)
(0) BR/EDR address
(1) LE public address
(2) LE random address
Device Name for BR/EDR devices or advertising data for LE devices |
Class of device(6 Bytes ASCII) |
Format2 |
+SCAN=E: Scan stopped |
+ADV - Tire pressure scanning results
Format1 |
+ADV=Param |
The first 12 bytes are the tire pressure address, and the following data are tire pressure data |
+PAIRREQ - Pair Request
Format |
+PAIRREQ=Param1,Param2{,Param3} |
Passkey (000000~999999) |
MAC address (12 Bytes ASCII) of current pairing device |
Name of current pairing device |
+PAIRED - Pair Result
Format |
+PAIRED=Param1,Param2 |
Pair result (0)-Success (1~255)-Failed reason |
+SPKVOL - Output volume level
Format1 |
+SPKVOL=Param1,Param2 |
A2DP’s volume level |
HFP’s volume level |
HFP Events
Format |
(0~10) The HFP status which connected with phone bluetooth
The status is the same as above, the status of the first Bluetooth earphone HFP |
The status is the same as above, the status of the second Bluetooth earphone HFP |
+HFPCID - Incoming/Outgoing call number
Format |
+HFPCID=Param |
(1~25 Bytes ASCII), call number |
+HFPCIE - Incoming/Outgoing call number remark
Format |
+HFPCID=Param |
(UTF8), call number remark |
+HFPDEV - HFP Remote Device Information
Format |
+HFPDEV=Param1{,Param2} |
12 Bytes ASCII), Remote MAC address of current HFP connection |
(UTF8), Remote device name of current HFP connection |
When indicating - HFPDEV, it represents the information of the first headphone,
when indicating ~ HFPDEV, it represents the information of the second headphone
Example: HFP connect with device successfully >> +HFPDEV=1C5CF226D774,iPhone
+HFPAUDIO - HFP Voice Audio State
Format |
+HFPAUDIO=Param1,Param2,Param3 |
HFP audio status which connected with phone bluetooth
(0) HFP voice audio disconnected, audio input/output routed to remote device
(1) HFP voice audio connected, audio input/output routed to module
The status is the same as above, the audio status of the first Bluetooth earphone HFP |
The status is the same as above, the audio status of the second Bluetooth earphone HFP |
+HFPSIG - HFP Remote Device Network Signal Strength
Format |
+HFPSIG=Param |
(0~5)Network signal strength of remote device |
Format |
+HFPBATT=Param1,Param2,Param3 |
(-1~5) Remote device battery level, mobile phone battery level |
(-1~5) Remote device battery level, the first headphone battery level |
(-1~5) Remote device battery level, the second headphone battery level |
-1 indicates that the battery level is not be obtained |
+HFPNET - HFP Remote Device Network Operator Selection
Format |
+HFPNET=Param |
(UTF8)Network operator selection of remote device |
+HFPMANU - HFP Remote Device Manufacture
Format |
+HFPMANU=Param |
(UTF8)Manufacture name of remote device |
+HFPNUM - HFP Remote Device Phone Subscriber Number
Format |
+HFPNUM=Param |
(ASCII)Phone subscriber number of remote device |
+HFPIBR - HFP Remote Device In-band-ring Support
Format |
+HFPIBR=Param |
(0/1) In-band-ring support |
Report whether the current connected phone support in-band-ring |
+HFPRING - HFP Remote Device Ringing
Format |
+HFPRING=Param |
(0/1) In-band-ring off/on |
Descreption |
Phone is ringing when call incoming, the host platform should play a local ringtone
if in-band-ring not supported by remote mobile phone
+HFPVR - Wake up HFP remote voice device
Format |
+HFPVR=Param |
0-Stop wake-up voice 1-wake up voice |
This event is used to indicate the wake-up of remote voice devices, such as Siri |
A2DP/AVRCP Events
Format |
+HFPMANU=Param |
The A2DP status of connecting with phone bluetooth
The status is the same as above, the A2DP status of the first Bluetooth earphone |
The status is the same as above, the A2DP status of the second Bluetooth earphone |
+A2DPDEV - A2DP Remote Device Information
Format |
+A2DPDEV=Param1{,Param2} |
(12 Bytes ASCII), Remote device’s MAC address of current A2DP connection |
(UTF8), Remote device’s name of current A2DP connection |
When indicating - A2DPDEV, it represents the information of the first headphone,
when indicating ~ A2DPDEV, it represents the information of the second headphone
Format |
+AVRCPSTAT=Param1,Param2,Param3 |
The AVRCP status of connecting with phone bluetooth
The status is the same as above, the AVRCP status of the first Bluetooth earphone |
The status is the same as above, the AVRCP status of the second Bluetooth earphone,only one AVRCP connection with headphones is supported currently |
+PLAYSTAT - Media Player State
Format |
+PLAYSTAT=Param |
+TRACKSTAT - Media Player Play Progress
Format |
+TRACKSTAT=Param1,Param2,Param3 |
(0~4), Media Player State, see +PLAYSTAT |
(Decimal ASCII),Elapsed time of current track in second |
(Decimal ASCII),Total time of current track in second |
+TRACKINFO - Media Track Information
Format |
+TRACKINFO=Param1,Param2,Param3 |
title |
artist |
album |
+CTPAUSE - Pause
Remote device sends pause command |
+CTPLAY - Play
Remote device(bluetooth headphone) sends play command |
+CTSTOP - Stop
Remote device(bluetooth headphone) sends stop command |
+CTBACK - Return to previous track
Remote device (Bluetooth headset) sends command to return to previous track |
+CTFWD - Play next trak
Remote device (Bluetooth headset) sends command to play next track |
PBAP Events
Format |
+PBSTAT=Param |
+PBCNT - Phonebook Entries of Remote Device
Format |
+PBCNT=Param |
Phonebook entries of remote device |
+PBDATA - Phonebook data
Format1 |
+PBDATA=Param1,Param2,Param3{,Param4} |
(4) Missed call logg
Call number remark |
Call number |
+PBDATA=E: Download complete |
Descreption |
Call time may not exist for some mobile phones |
SPP Events
Events for iAP2 (Apple Accessory Protocol) and AAP (Android Auto Protocol) are almost the same with SPP, which are:
+IAPSTAT, +IAPDATA for iAP2 profile
+AAPSTAT, +AAPDATA for AAP profile
Document will omit these events.
Format |
+SPPSTAT=Param |
Format |
+SPPDATA=Param1,Param2 |
Payload length |
Payload |
GATT Events
Format |
+GATTSTAT=Param |
Format |
Payload length |
Payload |
Application scenarios
profiles initializing and change parameter
The following figure shows Profile initialization and name modification
3 uart_send("AT+NAME\r\n");
4 if(uart_read("+NAME",name_buf))
5 {
6 if(memcmp(name_buf,"CARKIT",6))
7 {
8 uart_send("AT+NAME=CARKIT,0\r\n"); //defalut disable MAC address suffix
9 uart_send("AT+NAME\r\n"); // read bt name
10 if(uart_read("+NAME",name_buf))
11 {
12 if(memcmp(name_buf,"CARKIT",6))
13 {
14 //change name fail
15 }
16 else
17 {
18 //change name success
19 }
20 }
21 }
22 }
Sink mode connection
BT930、BT936D module supoort sink mode
When some firmware does not support downloading, it will automatically connect to PBAP, and you need to send AT+PBCONN to connect to PBAP before downloading
If you need to upgrade to the latest version, please refer to Upgrade Over-the-Air.
