FSC-BTAUD-QCC AT Command Set
This design guide is applicable to engineers developing the following series of Bluetooth modules: audio receiving modules: FSC-BT1038x , FSC-BT1058-RX , FSC-BT1104QI , FSC-BT1026X and audio transmitting modules: FSC-BT1035 , FSC-BT6038 , FSC-BT1058-TX, among which BT1058 can support receiving and transmitting respectively.
Module default configuration
MODUAL_NAME-XXXX
MODUAL_NAME-LE-XXXX
On
MODUAL_NAME is the name of the current module
Command Description
Terms
Applicable to the entire document
  • {} : Content within {} and {…} is optional.
  • << : The host SEND COMMAND to the module
  • >> : The module RESPONSE/EVENT to the host
  • All commands start with AT, end with <CR><LF>.
  • <CR> means “carriage return”, corresponds to hex value 0x0D.
  • <LF> means “line feed”, corresponds to hex value 0x0A.
  • If Command has Parameter, Parameter follows behind ‘=’.
  • If Command has multiple Parameters, Parameter must be separated by ‘,’.
  • If Command has Response, Response starts with <CR><LF>, ends with <CR><LF>.
  • Module will always report command’s execution result by using OK for success or ERROR for failure.
Read module’s BR/EDR local name
>> +NAME=FSC-BT1038A-XXXX
Pick up an incoming call when no call incoming actually
  • All Events start with <CR><LF>, end with <CR><LF>.
  • If Event has Parameter, Parameter follow behind ‘=’.
  • If Event has multiple Parameters, Parameter must be separated by ‘,’.
  • Use command AT+SEP to replace default separator for conflict prevention.
Received “1234567890” from mobile phone via SPP profile
Dial number “10086” using a mobile phone when HFP connected
>> +HFPSTAT=4
>> +HFPAUDIO=1
>> +HFPCID=10086
>> +HFPSTAT=6
AT+HELP - Firmware Function/Command Summary
<FIRMWARE FUNCTION: audio_transceiver>
<ENABLE PROFILES:LINKS: ON/OFF>
|SPP|:1
|GATTS|:1
|GATTC|:0
|HFP-AG|:1
|A2DP-SRC|:1
|AVRCP-TG|:1
<COMMAND SUMMARY:DESCRIPTION:PROFILE CATEGORY>
AT+BTEN:Bluetooth On/Off:|GENERAL|
AT+PROFILE:Get/Set Profile:|GENERAL|
AT+STAT:Get All Profile State:|GENERAL|
AT+ECHO:Enable/Disable AT Command Echo:|GENERAL|
Using help command to get the basic summary information
AT+VER - Get Firmware Version
Module type
Firmware version
Data of production
>> +VER=FSC-BT1038A,V1.1.2,20250118
9600/19200/38400/57600/115200(default)/230400/460800/921600
/1000000/1382400/1500000/2000000
Return the current baud rate
Module will change baudrate to target value immediately
Example:Query baudrates
Example: Set baudrates
<< AT+BAUD=9600
AT+I2SCFG - Get/Set I2S Settings
Expressed in decimal bit fields, with each bit representing
0:disable; 1:enable
0:master; 1:slave
0:FS=48000Hz; 1:FS=44100Hz
0:left justified; 1:right justified
0:data 1 bit delay; 1:data no delay
BIT[5-6]
01: bit depth=24bits
10: bit depth=32bits
When the BT1038 series I2S is set to slave mode,
the I2S master must continuously provide a clock; otherwise, the module will panic.
Example:usual configuration and description:
65
67
AT+SPDIFCFG - SPDIF format configuration
AT+SPDIFCFG{=Param}
0 - Disable audio output in SPIDF format
1 - Enable audio output in SPDIF format
The output pin is pin15, and it will take effect after a restart.
If the audio output is SPDIF, the I2S configuration will be invalidated.
Some modules do not support SPDIF output
AT+MICGAIN - Get/Set Analog Input Gain
AT+MICGAIN{=Param}
Microphone input gain
+: Increase gain
-: Decrease gain
+MICGAIN=Param
Param:
FSC-BT1035 : 0~15, default:10
FSC-BT6038 : 0~10, default:5
FSC-BT1058-TX : 0~10, default:5
Only supported by audio transmitting modules
In USB input mode, the parameter can only be “+” or “-”; This command is invalid when using I2S/SPDIF input
AT+SPKVOL - Get/Set Analog Output Volume
AT+SPKVOL{=Param}
Volume (‘+’ / ‘-’/ 0-15, default:15)
Adjust output volume, adjust A2DP volume during music playback,
Adjust HFP volume during calls, and support volume adjustment in LEA mode
AT+REBOOT - Soft Reboot
The module will reboot
AT+BTEN - Bluetooth On/Off
0-Power off 1-Power on
This command is not saved upon power loss
AT+LECFG - Get/Set LE Random MAC Address
AT+LECFG{=Param}
0 - Disable; 1 - Enable
+LECFG=Param
AT+PROFILE - Bluetooth Profile Configuration
SPP (Serial Port Profile)
BIT[11]
Map Server (Message Access Profile)
BIT[16]
Bis Sink (Le audio broadcast sink)
BIT[17]
Bis Source (Le audio broadcast source)
BIT[18]
Cis Sink (Le audio unicast sink)
BIT[19]
Cis Source (Le audio unicast source)
It is not possible to enable bothGATT Server & Client, HFP Sink & Source,
A2DP Sink & Source,AVRCP Controller & Target
If the Profile configuration is changed, the module will automatically restart.
Not supported by audio transmitting modules:GATT Server、 HFP-HF、 A2DP Sink、AVRCP Controller、HID Keyboard、PBAP;
Not supported by audio receiving modules:GATT Client、 HFP-AG、 A2DP Source、AVRCP Target;
FSC-BT1026X 、 FSC-BT1035 Not supported le audio
Example:Read the current profile
>> +PROFILE=9385
Example:Only enable A2DP Sink and HFP Sink, disable others
<< AT+PROFILE=160
Example:Only enable A2DP Source and HFP Source, and disable others
<< AT+PROFILE=80
AT+AUTOCONN - Set the number of Bluetooth power-on reconnection attempts
(0~15, default:3)
(0) Turn Off
(1-15) Turn on and reconnect times
After being powered on, the module will attempt to establish a connection with the last connected device, retrying for Param times.
AT+STAT - Read profile status
DEVSTAT
SPPSTAT
GATTSTAT
HFPSTAT
A2DPSTAT
AVRCPSTAT
HIDSTAT
Param8
PBSTAT
Param9
BISSTAT
Param10
CISSTAT
FSC-BT1035 does not support LE-Audio
AT+DEVSTAT - Read device status
Example : Common combinations and descriptions
AT+ADDR - Get BR/EDR MAC Address
Module’s BR/EDR MAC address (12 Bytes ASCII)
Module’s LE MAC address (12 Bytes ASCII)
BR/EDR local name(1~31 Bytes ASCII)
1: Enable suffix “-XXXX” (lower 4 bytes of MAC address) after local name
Write local name if parameter exist, otherwise read current local name
Read current BR/EDR local name
>> +NAME=FSC-BT1038-1234
Change module’s BR/EDR local name to “ABC”,and disable suffix
Change module’s BR/EDR local name to “ABC” and enable suffix
BLE local name(1~25 Bytes ASCII)
0: 0-Disable suffix
When Param1 is absent, it defaults to reading the Bluetooth name; when Param1 is present, it is used to set the Bluetooth name.
AT+PIN - Get/Set BR/EDR Pin Code
The PIN code is only valid in the legacy pairing mode, refer to AT+SSP
FSC-BT1038x , FSC-BT1104QI do not support this command
Example:Read module’s pin code
Example: Change module’s pin code to “1234”
AT+SSP - Get/Set BR/EDR Pairing Mode
Pairing mode (0~2, default:0)
(1) Secure simple pairing, display yes/no in pairing
(2) Secure simple pairing, display pairing code and yes/no in pairing
Need reoot
AT+COD - Get/Set Device Class
AT+COD{=Param}
Device Type(6 bytes ASCII, default:240404 Handsfree device)
For related configuration, please refer to COD.
AT+PAIR: Get/Set BR/EDR/BLE Visibility
AT+PAIR{=Param}
1: Enter BR/EDR/BLE discoverable mode (start advertising/broadcasting)
If no device (BR/EDR or BLE) is connected, the module will always be discoverable;
If connected to a remote device, the module will not be discoverable unless it receives this command.
AT+SCAN - Scan Nearby Devices
AT+SCAN=Param1{,Param2,{Param3}}
0: Stop scan
1: Scan nearby BR/EDR devices
2: Scan nearby BLE devices
3: Scan nearby BLE-BIS devices
Scan timeout(1-255 unit:seconds/1.28 seconds),defalut:10
Name filtering (only valid when Param1=3)
The scan timeout varies between different modules, depending on the specific module.
Format description reference +SCAN - Scan content format
Example: Scan nearby BR/EDR devices using AT+SCAN = 1,10, with a scanning duration of 10 seconds
+DEVSTAT=261
+SCAN=1,2,D58C79C88D15,-79,5,N-612
+SCAN=2,2,5820590F1E83,-60,7,Redmi 7
+SCAN=3,2,E0D8C4660C75,-70,16,JMGO-N1 Pro-0127
+SCAN=4,2,789F38FEDCBA,-57,10,FSC-BW256B
+SCAN=5,2,51684A0931E5,-74,17,闄曟苯X6000锛嗭紗
+SCAN=6,2,70CD0D311A59,-73,13,FEASYCOM-WILL
+SCAN=7,2,388F817516D3,-72,7,PSE0500
+SCAN=8,2,947BAE63703F,-62,10,xiaomiqin1
+DEVSTAT=5
(0) Clear all paired records
(1~8) Clear the paired records of the specified index
(MAC) Clear pairing records at the specified address
+PLIST=Param1,Param2{,Param3}
(1~8) Paired device index
(MAC)MAC address of the paired device
(UTF8)Bluetooth name of the paired device
+PLIST=E Pairing record query completed
If the parameter is omitted, all pairing records will be listed.
Only connection records of BR/EDR devices are supported; LE is not supported temporarily.
Example:Read the pairing records of the module
>> +PLIST=1,1C5CF226D773, iPhone12
+PLIST=2,A0BC30075421, Samsung S8
Example:Clear all paired records of the module
AT+DSCA - Disconnect all connections
The module disconnects all Bluetooth connections with remote devices(ED/BR,GATT,LEA).
AT+AUDROUTE - Audio Routing Management
AT+AUDROUTE{=Param}
0 Stop audio routing
1 The module transmits audio stream to HP1/HP2 (A2DP playback mode)
2 Voice call between the module and HP1 (HFP SCO)
3 Voice call between the module and HP2 (HFP SCO)
4 Voice call between HFP1 and HP2 (HFP SCO, intercom mode)
5 The module initiates voice call (HFP SCO) to HP1/HP2
6 The module transmits audio stream to HP1 (A2DP playback mode)
7 The module transmits audio stream to HP2 (A2DP playback mode)
Only supported by audio transmitting modules. HP1 and HP2 refer to Bluetooth peer headphones, and the modules in this document only support HP1 (0/1/2)
Some firmware uses AT+HFPAUDIO to establish voice calls and AT+A2DPAUDIO to transmit audio streams
AT+TPMODE - Turn on/off transparent transmission mode
Mode (0~1, default 0) 0: Command mode 1: Transparent transmission mode
When connected under the SPP/GATT protocol and with transparent transmission mode enabled, AT commands will be disabled.
Each byte received through UART will be sent to the remote end.
AT+AUXCFG - Query/configure input mode
AT+AUXCFG{=Param}
mode(0-4,default:0)
0: BT mode
1: LineIn mode
2: Spdif mode
3: I2S mode
4: USB mode
This commandis used to configure the input mode of the module.
FSC-BT1035 The order of Param parameters is different:
0: USB mode
1:LineIn mode
2:Spdif mode
3:I2S mode
_images/AT%2BAUXCFG.png
Example:Set LineIn mode for input
<< AT+AUXCFG=1
AT+RSSI - Get the signal value of connected devices
AT+RSSI=Param
(12-byte ASCII) MAC address of the target device
+RSSI=Param1,Param2
Connection signal strength value of the target device (0: Unavailable)
AT+LINKCFG - Query/Configure Auto Connection
AT+LINKCFG{=Param1{,Param2}}
0: On 1: Off (default:0)
0: COD filtering function disabled 1: COD filtering function enabled (default:1)
If auto connection is enabled, the module will continuously scan nearby devices after startup (Param2=1),
then attempt to connect to the device with the optimal signal strength.
AT+MICMUTE - Mute MIC
AT+MICMUTE=Param
0-unmute 1-mute
Mute the local microphone during a call
Only supported by audio receiving modules
AT+SPKMUTE - Mute Speaker
AT+SPKMUTE=Param
0-unmute 1-mute
Mute the local speaker during audio playback
AT+GAMEMODE - Enable/Disable Game Mode
AT+GAMEMODE=Param
0: Disable Game Mode
1: Enable Game Mode
Audio receiving modules FSC-BT1038x, FSC-BT1104QI do not support this command
Audio transmitting modules do not support this command
Currently, the game mode only supports the classic Bluetooth mode.
When this mode is enabled, the delay of the encoding formats corresponding to AAC and SBC
is set from dynamic delay to a fixed low-delay state of 100ms to achieve a better gaming experience.
HFP Commands
AT+HFPSTAT - Read HFP State
+HFPSTAT=Param
Format description reference: +HFPSTAT - HFP State
AT+HFPCONN - Establish HFP Connection
MAC address of target device (12 Bytes ASCII)
Reconnect to last HFP device if parameter not exist
Both audio transmitting and receiving modules support this command
Example:Connect to last HFP device
<< AT+HFPCONN
Example:Connect to specific HFP device with MAC address
<< AT+HFPCONN=1C5CF226D773
AT+HFPDISC - Release HFP Connection
Release current HFP connection with remote device
AT+HFPRING - Simulate Incoming Call
AT+HFPRING=Param
Phone number (1~25 Bytes ASCII)
Simulate an incoming call from the number “Param”
Example:Redial
<< AT+HFPRING
Example: Simulate an incoming call from the number “075527924639”
<< AT+HFPRING=075527924639
AT+HFPDIAL - Dial/Redial Phone Number
AT+HFPDIAL{=Param}
Dial specific number if parameter exist, otherwise redial
Example:Redial
<< AT+HFPDIAL
Example:Dial number “075527924639”
<< AT+HFPDIAL=075527924639
AT+HFPDTMF - Send DTMF code
AT+HFPDTMF{=Param}
DTMF (0~9/#/*)
Example:Send DTMF code “#” while calling “#”
<< AT+HFPDTMF=#
AT+HFPANSW - Pick Up Incoming Call
AT+HFPCHUP - Reject/Hung up Call
Reject/Hung up Call
AT+HFPNREC - Enable/Disable AGHFP Echo Cancellation Algorithm
AT+HFPNREC{=Param}
default:1
0: Disable Ag-hfp cvc
1: Enable Ag-hfp cvc
+HFPNREC=Param
AT+HFPWBS - Enable/Disable WBS Function
AT+HFPWBS{=Param}
default:1
0: Disable Ag-hfp codec negotiation
1: Enable Ag-hfp codec negotiation
+HFPWBS=Param
Enabling WBS enables 16K call by default, and the setting takes effect after restart.
AT+HFPADTS - Transfer Voice Audio Between Local and Remote Device
AT+HFPADTS=Param
0: Transfer voice audio from module to remote device
1: Transfer voice audio from remote device to module
Transfer voice audio between module and remote device by default if no parameter set
AT+HFPVR - Start/Stop Voice Recognition of Remote Device
AT+HFPVR=Param
0-Stop 1-Start
Start/Stop Voice Recognition of Remote Device (such as Siri for iOS devices)
AT+HFPSCO - SHFP SCO Configuration
AT+HFPSCO=Param
0-default
1-always to HF
2-always to AG
AT+HFPBATT - Send device battery level
AT+HFPBATT=Param
level(0-9)
A2DP/AVRCP Commands
AT+A2DPSTAT - Read A2DP State
Format description reference +A2DPSTAT - A2DP State
AT+A2DPCONN - Establish A2DP Connection
Reconnect to last A2DP device if parameter not exist
Both audio transmitting and receiving modules are supported
AT+A2DPDISC - Release A2DP Connection
Release current A2DP connection with remote device
AT+A2DPCFG - Read/Write A2DP Configuration
AT+A2DPCFG=Param
A base-10 representation of a bit field, for each bit
0: Disable AAC Codec 1: Enable AAC Codec
0: Disable APTX Codec 1: Enable APTX Codec
0: Disable APTX-LL Codec 1: Enable APTX-LL Codec
0: Disable APTX-HD Codec 1: Enable APTX-HD Codec
0: Disable APTX-AD Codec 1: Enable APTX-AD Codec
0: Disable LDAC Codec 1: Enable LDAC Codec
Param=0:Enable SBC
Example:Read current A2DP configuration
<< AT+A2DPCFG
>> +A2DPCFG=0
Example:Set A2DP configuration to: Only enable AAC Codec
<< AT+A2DPCFG=1
AT+A2DPDEC - Read A2DP Decoder
AT+A2DPDEC
+A2DPDEC=Param
See the table below
_images/AT%2BA2DPDEC.png
AT+A2DPENC - Query A2DP Encoding
AT+A2DPENC
+A2DPENC=Param
1:SBC 2:APTX 3:APTX-HD 4:APTX-LL 5:APTX-AD
AT+AVRCPCONN - Establish AVRCP Connection
AT+AVRCPCONN{=Param}
MAC address of the target device (12 Bytes ASCII)
If the parameter is not present, reconnect to the last AVRCP device
Both audio transmitting and receiving modules are supported, and A2DP connection is required first
AT+AVRCPDISC - Release AVRCP Connection
AT+AVRCPDISC
Terminate the current AVRCP connection with the remote device
This command only initiates a disconnection request, and the actual status queried shall be determined based on the actual result
AT+AVRCPSTAT - Read AVRCP State
Format description reference:ref:REF104
AT+AVRCPCFG - Get/Set AVRCP Configuration
AT+AVRCPCFG{=Param}
A base-10 representation of a bit field, default:9, for each bit:
Auto get track ID3 information (title, artist, album).0:disable 1:enable default:1
BIT[1-3]
Auto get track play progress if value > 0. 0:disable default:5(second)
Auto get volume change value. 0:disable 1:enable default:1
Example: Read AVRCP configuration
<< AT+AVRCPCFG
>> +AVRCPCFG=1
Example: Get track play progress every 1 second
<< AT+AVRCPCFG=3
AT+ABSVOL - Query/Configure Remote Absolute Volume
AT+AT+ABSVOL{=Param}
Set remote volume (0~127)
+: Volume increases
-: Volume decrease
AT+ABSVOL=Param
This command must be sent after the AVRCP connection is established, and the remote device must support the absolute volume control function
AT+PLAYPAUSE - Track Play/Pause
AT+PLAYPAUSE
Send play or pause command to the remote media player according to the current play status (play when paused, pause when playing), supporting classic Bluetooth play/pause and BIS play/pause
AT+PLAY - Track Play
AT+PLAY
Send play command to the remote media player, supporting classic Bluetooth playback and BIS playback
AT+PAUSE - Track Pause
AT+PAUSE
Send pause command to the remote media player, supporting classic Bluetooth pause and BIS pause
AT+STOP - Track Stop
AT+STOP
Send play stop command to the remote media player, only supporting classic Bluetooth playback stop
AT+FORWARD - Track Forward
AT+FORWARD
Send forward command to remote media player
AT+BACKWARD - Track Backward
AT+BACKWARD
Send backward command to remote media player
AT+FFWD - Track FastForward
AT+FFWD=Param
0-Fast Forward Release, 1-Fast Forward Press
Send fast forward command to remote media player
AT+RWD - Track Rewind
AT+RWD=Param
0-Rewind Release, 1-Rewind Press
Send rewind command to remote media player
PBAP Commands
AT+PBSTAT - Read PBAP state
AT+PBSTAT
+PBATAT=Param
Format description reference +PBSTAT - PBAP State
AT+PBCONN - Establish PBAP Connection
AT+PBCONN{=Param}
Module will use current HFP device’ MAC address if parameter not exist.
Default firmware support: When sending AT+PBDOWN, it automatically connects to PBAP.
Only supported by audio receiving modules. Please enable the permission for accessing contacts on the mobile phone side.
AT+PBDISC - Release PBAP Connection
AT+PBDISC
Release current PBAP connection with remote device
AT+PBDOWN - Download Phonebook
AT+PBDOWN=Param1{,Param2}
Phonebook type(0-5)
Max items (1~65535, default:3000 for phonebook; 50 for call log)
For some phones (e.g. iPhone), the contact download permission must be turned on in phone’s Bluetooth settting.
Please refer to the application scenarios Phonebook Download
SPP Commands
AT+SPPSTAT - Read SPP State
Format description reference +SPPSTAT - SPP State
Establish an SPP connection with a remote device
Release current SPP connection with remote device
Payload (1~492 Bytes)
Example: Send data “1234567890” to remote device via SPP
GATT Commands
AT+GATTSTAT - Read GATT State
Format description reference +GATTSTAT - GATT State
Release current GATT connection with remote device
Example: Send data “1234567890” to remote device via GATT
<< AT+GATTSEND=10,1234567890
BIS指令
AT+BISSTAT - Read BIS State
AT+BISSTAT
+BISATAT=Param
Format description reference +BISSTAT - BIS State
AT+BISCONN - BIS Synchronize Broadcast Source
AT+BISCONN=Param1{,Param2,Param3}
MAC address
Broadcast advertising_sid
Broadcast broadcast_id
Synchronize the BIS broadcast source. If Param2 and Param3 are omitted, initiate scanning first, then initiate connection if the MAC address matches
Obtain advertising_sid and broadcast_id with reference to “AT+SCAN=3”
BIS pause and playback refer to “AT+PLAYPAUSE”
This command is not supported by audio transmitting modules
Example: Add the synchronized and discovered BIS broadcast source via AT+BISCONN=00025B00FF00,15,62640
AT+BISDISC - BIS Remove Broadcast Source
AT+BISDISC{=Param}
Address code
Remove the BIS broadcast source according to the MAC address, remove all BIS sources if the address is omitted
CIS Commands
AT+CISSTAT - Read CIS State
AT+CISSTAT
+CISSTAT=Param
Format description reference:ref:REF110
AT+CISCONN - Establish CIS Connection
AT+CISCONN=Param1{,Param2}
MAC address of the target device (12-byte ASCII string)
(0) Public address
(1) Random address
This command is only valid in the mono audio broadcast mode
AT+CISDISC - Disconnect CIS Connection
AT+CISDISC
The actual status queried shall be determined based on the actual result
Events Table
General Events
+PAIRED - Pair Result
+PAIRED=Param
MAC address (12 Bytes ASCII) of current pairing device
+SCAN=Param1,Param2,…,Param6{,Param7,Param8}
index
Device address type(0-2)
(0) LE public address
(1) LE random address
(2) BR/EDR address
Name length, i.e., the size of Param6 (if present)
advertising sid
Param8
broadcast id
+SCAN=E: stop scan
Stop when the timeout is reached or 8 devices are scanned (+SCAN=E)
When using AT+SCAN=1/2, the return type is Format1, Format3
When using AT+SCAN=3, the return type is Format2 or Format3, which can be used for BIS synchronization
HFP Events
+HFPSTAT=Param
(0~6)
+HFPDEV - HFP Remote Device Information
(12 Bytes ASCII), Remote MAC address of current HFP connection
(UTF8), Remote device name of current HFP connection
Example: HFP connect success with device
+HFPCID - Incoming/Outgoing Call Number
+HFPCID=Param
(1~25 Bytes ASCII), Call number
Example: Dial number 10086
<< AT+HFPDIAL=10086
>> +HFPSTAT=4
>> +HFPCID=10086
>> +HFPCIE=China Mobile
>> +HFPAUDIO=1
Example: Incoming call with number 13265463800
>> +HFPSTAT=5
>> +HFPCID=13265463800
>> +HFPCIE=Jerry
>> +HFPAUDIO=1
+HFPCIE - Incoming/Outgoing Call Name
+HFPCIE=Param
(UTF8), Call name
This event is supported by IOS mobile phones, but not supported by most Android phones
+HFPAUDIO - HFP Voice Audio State
(0) HFP voice audio disconnected, audio input/output routed to remote device
(1) HFP voice audio connected, audio input/output routed to module
+HFPSIG - HFP Remote Device Network Signal Strength
+HFPSIG=Param
(0~5)Network signal strength of remote device
+HFPROAM - HFP Remote Device Roaming State
+HFPROAM=Param
(0/1) Roaming state of remote device
Receive mode: Mobile phone (0~5) Battery level of the remote device
Transmit mode: Headphone (0-9) Battery level of the remote device
+HFPNET - HFP Remote Device Network Operator Selection
+HFPNET=Param
(UTF8)Network operator selection of remote device
+HFPMANU - HFP Remote Device Manufacture
+HFPMANU=Param
(UTF8)Manufacture name of remote device
+HFPNUM - HFP Remote Device Phone Subscriber Number
+HFPNUM=Param
(ASCII)Phone subscriber number of remote device
+HFPIBR - HFP Remote Device In-band-ring Support
+HFPIBR=Param
0-Not supported 1-Supported
Report whether the current connected phone support in-band-ring
+HFPSR - HFP Sample rate
Sample rate: 8000/16000/32000
A2DP/AVRCP Events
+A2DPDEV - A2DP Remote Device Information
(12 Bytes ASCII), Remote device’s MAC address of current A2DP connection
(UTF8), Remote device’s name of current A2DP connection
+A2DPSR - A2DP Remote Device Information
+A2DPSR=参数
A2DP encoding sampling rate
+AVRCPSTAT - AVRCP State
+PLAYSTAT - Media Player State
+CTVOLUP - Receive Volume Increase
+CTVOLUP
Received the command from the CT side to increase the device volume
This indication exists only for audio transmitting modules
+CTVOLDN - Receive Volume Decrease
+CTVOLDN
Received the command from the CT side to decrease the device volume
+CTPLAY - Play
+CTPLAY
Received the play resume command from the CT side
+CTPAUSE - Pause
+CTPAUSE
Received the pause command from the CT side
+CTFWD - Next Track
+CTSTOP
Received the command to play the next track from the CT side
+CTBACK - Previous Track
+CTBACK
Received the command to play the previous track from the CT side
+TRACKSTAT - Media Player Play Progress
(0~4), Media Player State, see +PLAYSTAT
(Decimal ASCII),Elapsed time of current track in millisecond
(Decimal ASCII),Total time of current track in millisecond
+TRACKINFO - Media Track Information
title
artist
album
Example: Phone playing song“Creep-Radio Head”
PBAP Events
+PBSTAT=Param
+PBCNT - Phonebook Entries of Remote Device
+PBCNT=Param
Phonebook entries of remote device
+PBDATA - Phonebook Data
+PBDATA=Param1<FF>Param2<FF>Param3{<FF>Param4}
Number
(15 Bytes ASCII), Call time if current download type is call log
+PBDATA=E Download complete
Call time may not exist for some mobile phones
Example: Download all phonebook
<< AT+PBDOWN=1
>> +PBCNT=234
+PBDATA=1,Jack,18219146201
+PBDATA=1,kenan,8613771972680
+PBDATA=E
Example: Download 10 dialed call log
<< AT+PBDOWN=3,10
>> +PBDATA=3,China Mobile,10086,20171013T103516
+PBDATA=3,Jerry,18688967507,20171012T152826
+PBDATA=E
SPP Events
Example: Received data “1234567890” from remote device via SPP
GATT Events
+GATTDATA=Param1,Param2
Example: Received data “1234567890” from remote device via GATT
BIS Events
+BISSTAT=Param1{,Param2}
Device 1:
(2) Syncing
(3) Synced
Device 2:
(2) Syncing
(3) Synced
Param2 is present when there is a second synchronized device,
and the audio transmitting module only has the (1)Standby and (5)Streaming states
CIS Events
+CISSTAT - CIS State
+CISSTAT=Param
Hardware Description
Pin Diagram
FSC-BT1038x & FSC-BT1058-RX:
_images/BT1038_pin_map.png
FSC-BT1104QI:
_images/BT1104QI_pin_map.png
Vss
Power Ground
LED4
General-purpose analog/digital input or open drain LED output
LED5
PCM_CLK
PCM_BCLK
PCM_IN
PCM_DIN[0]
PCM_OUT
PCM_SYNC
PCM_SYNC
Low-level Reset
PCM_MCLK
MCLK_OUT
UART flow control pin (no connection by default) / SPIIF output
UART flow control pin (default PA)
Outputs square wave in pairing mode,
Outputs high level when Bluetooth is connected
Outputs low level when BIS is disconnected,
Outputs high level when connected
19
LED2
29
VCHG_SENSE
Analog
Charger input sense pin after external
mode sense-resistor,High impedance
30
CHG_EXT
External charger transistor current control.
Connect to base of external charger transistor
as per application schematic.
31
VDD_USB
/3.3V_OUT
3.3V voltage output (MAX. 50mA OUT)
Vss
Power Ground
VBAT_IN
Vdd
3.3V power supply,
LDO power supply is recommended
SYS_CTRL
Power pin, long press to power on/off
VDD_IO
pio supply(1.8v~3.3v)
37
USB_DP
USB Full Speed device D+
38
USB_DN
USB Full Speed device D-
39
VCHG
Vdd
Charger input to Bypass regulator.(USB VBUS)
40
MIC_RP
MIC2/Line_IN differential R input, positive
41
MIC_RN
MIC2/Line_IN differential R input, negative
MIC1/Line_IN differential L input, positive
MIC1/Line_IN differential L input, negative
48
Change the 0-ohm resistor near the antenna to connect an external Bluetooth antenna
52
Vss
Power Ground
FSC-BT1104QI:
Vss
Power Ground
SYS_CTRL
MIC1_P
MIC1/Line1_IN differential input, positive
MIC1_N
MIC1/Line1_IN differential input, negative
MIC2_N
MIC2/Line2_IN differential input, negative
MIC2_P
MIC2/Line2_IN differential input, positive
Mic bias output
Differential line output 1, positive
Differential line output 1, negative
VDD_IO
IO VDD 1.8V/3.3V
I2C_SDA
I2C_SDA
I2C_SDA
I2C_SDA
Differential line output 2, negative
Differential line output 2, positive
I2S_DOUT
I2S_DOUT
I2S_BCLK
I2S_BCLK
I2S_DIN
I2S_DIN
19
I2S_MCLK
I2S_MCLK
20
VDD_IO
Vdd
3V3
Vss
Power Ground
23
24
Low-level Reset
25
VBUS
USB audio input function supported, 5V input
26
Vss
Power Ground
27
USB_DP
28
USB_DN
UART_TXD
UART_TXD
UART_RXD
UART_RXD
35
Vss
Power Ground
RF_ANT
RF
39
VDD_USB
/3V3_OUT
40
LINE3/MIC3_N
MIC3/Line3_IN differential input, negative
41
LINE3/MIC3_P
MIC3/Line3_IN differential input, positive
42
48
LINE4/MIC4_P
MIC4/Line4_IN differential input, positive
LINE4/MIC4_N
62
LED2
Outputs low level when CIS is disconnected,
68
LED4
General-purpose analog/digital input or open drain LED output.
74
CHG_EXT
75
LED3
76
LED5
78
VDD_PADS_356
VDD 1.8V/3.3V
82
1V8_SMPS
1.8V pio output
84
VCHG_SENSE
Analog
85
VBAT_SENSE
Analog
Battery voltage sense input
Hardware design notes
  • The simple test of the module only needs to connect VDD/VDD_IO/VBUS/GND/UART_RX/UART_TX to use
  • After drawing, please send it to feasy.com for review so as not to have the best bluetooth distance
Functional Notes
  • MAP (Message Access Profile)
  • LEA (LE Audio)
  • BIS (Broadcast Isochronous Stream)
  • CIS (Connected Isochronous Stream)
GATT Service
Characteristic
Throughout Service
From Module to APP
From APP to Module
Application Scenarios
Profile Initialization and Set Device Name
The figure below shows Profile initialization and name modification
rnote over host, bt: Profile初始化
bt -> host: +VER=FSC-BT1038,V1.1.2,20250118
bt -> host: +PROFILE=328875
bt -> host: +HFPSTAT=2
bt -> host: +BISSTAT=1
bt -> host: +CISSTAT=1
bt -> host: +DEVSTAT=7 (enter discoverable,phone can find and spp/gatt connect to us)
rnote over host, bt: Set name to "CARKIT",disable suffix. and verify readback
bt -> host: +NAME=FSC-BT1038-1E49
MCU reference code for modifying the device name CARKIT. It is recommended to query first, then modify, and finally verify when changing any parameters:
BR/EDR Bluetooth Receive Mode Connection
bt -> host: +PROFILE=1195
rnote over host, bt: Mobile phone scan BT and initiates the connection
bt -> host: +A2DPSTAT=3 (A2DP connected)
bt -> host: +AVRCPSTAT=3 (AVRCP connected)
bt -> host: +HFPSTAT=3 (HFP connected)
bt -> host: +HFPSIG=3
bt -> host: +HFPBATT=4
host -> bt: +HFPDIAL=10086 (Dial "10086")
bt -> host: +HFPSTAT=4,10086
bt -> host: +HFPAUDIO=1 (Establish voice audio)
host -> bt: AT+HFPCHUP(End Call)
bt -> host: +HFPAUDIO=0 (Disconnect voice audio)
host -> bt: AT+PLAY(Play Music)
bt -> host: +A2DPSTAT=5
bt -> host: +PLAYSTAT=1
bt -> host: +TRACKSTAT=1,1000,240000
bt -> host: +TRACKSTAT=1,2000,240000
host -> bt: AT+PAUSE(Pause Music)
LE Audio Broadcast Scan and Connect
rnote over host, bt: The module initiates broadcast source scanning
host -> bt: AT+SCAN=3
bt -> host: +BIS=1,-61,15,98,DC0D30000062,FSC-BP410-0062
bt -> host: +BIS=2,-48,15,43356,00025B00FF0E,FSC-BP415-ff0e
rnote over host, bt: The command for the module to initiate connection to the broadcast source
host -> bt: AT+BISCONN=15,43356
bt -> host: +BISADD=15,43356
bt -> host: +BISSTAT=4
bt -> host: +BISSTAT=5
Phonebook Download
rnote over host, bt: HFP connected
rnote over host, bt: Download all phonebooks
host -> bt: AT+PBDOWN=1
bt -> host: +PBSTAT=2
bt -> host: +PBSTAT=3 (PBAP connected)
bt -> host: +PBSTAT=4 (PBAP downloading)
bt -> host: +PBDATA=1,Local number,+8618620277272
bt -> host: +PBDATA=1,Zhang San,0571-85592192
bt -> host: +PBDATA=1,jerry,18909731215
bt -> host: +PBDATA=E (Download completed)
rnote over host, bt: Download 50 call records
host -> bt: AT+PBWODN=5,50
bt -> host: +PBDATA=3,yidong,+10086,20200213T114247
bt -> host: +PBDATA=2,andy,85592192,20200212T104202
Contact Information
Shenzhen Feasycom Co.,Ltd.
Address : Rm 508, Building, Fenghuang Zhigu, NO.50, Tiezai Road, Xixiang, Baoan Dist, Shenzhen, 518100, China.
Telphone : 86-755-23062695
Sales Service : sales@feasycom.com
Support : support@feasycom.com
Home Page : www.feasycom.com
Support Forum : forum.feasycom.com
PDF Download
PDF Download
