FSC-DB200 Development Board User Guide
Overview
The FSC-DB200 development board integrates Type-C (including UART/USB/charging/power supply), audio input/output, microphone, lithium battery, buttons, reset button, 2.54mm pitch pin headers, status indicator lights, etc.
It can be used in conjunction with our company’s serial port assistant and AT commands for functional testing, facilitating customer familiarity with our products, reducing development cycles, and improving efficiency.”
Features
● All-in-One Type-C
● Universal 3.5mm Headphone Jack Input
● Universal 3.5mm Headphone Jack Output
● Built-in microphone for convenient call testing
● Lithium battery/USB powered
● Button controls (power on/off, pause/play, volume adjustment, track selection) and a one-key reset
● 2.54mm pitch pin headers for easy DuPont wire connections
● Multifunctional indicator lights for status indication
● RF interface (not included in the standard package) for convenient RF signal testing
● Built-in USB to serial chip
● Built-in headphone amplifier chip, capable of driving 16/32 ohm headphones
● Reserved Adafruit board connection port
Application Module
● BT1026X
● BT1035
● BT1036C
● BT1032C
● BT955
● BT958
etc
Hardware and Function
Sample Image
_images/DB200.png
Funticon Design
_images/FSC-DB200-%E8%AE%BE%E8%AE%A1%E5%B8%83%E5%B1%80.PNG
NO.
remark
1 *
Type-C
Power the module/communicate with the module/charge the battery through the module
USB/UARTswitch
The UART can be selected to communicate with the module, and the USB function of the module can be selected;
Not all modules have USB capability
microphone
HFP (for outgoing calls, the default channel is L);
And applications that require microphones
Audio input
Standard 3.5mm audio socket
Audio output
Standard 3.5mm headphone output drives 16/32 ohm speakers up to 60mW
Adu board reset button
Reset the extended adu board. The default is empty
Battery powered
Lithium battery interface. 3.7V to 4.2V. Do not exceed the voltage, otherwise the module will be damaged
Volume plus
Short press Volume increase/Long press next track
Volume down
Short press volume decrease/Long press previous track
On-off key
Long press 2s switch machine;
Play music: short press pause/play;
Incoming call: Press to answer and then press to hang up
Adu board expansion row pin
Adu board extension, empty by default
Adu board indicator light
Adu board status indication
Analog audio differential output pin
Expansion pin, empty by default
External IPEX seat son
The module external antenna is connected to the seat
module
Can support BT1026X series/BT1035 / BT1036C/BT1032C BT955 / BT958 and so on
Module pin
Module each pin
TRBI200
TRBI200 burner interface, empty by default
Module reset key
Press the module to reset
19 *
Battery charging/module upgrade
Battery charging in short circuit state, module upgrade/fixed frequency
20 *
Module power supply
Short circuit: Type-C supplies power to the module;
Off: The battery supplies power to the module,
Or charge the battery when the Type-C has input voltage and the “Battery charge/Module upgrade pin” is short circuited
Module indicator
The blue light flashes quickly for pairing, and the long light indicates that it is connected. If the green light is steady on, the SPP/BLE connection is successful
The three marked with * can be combined to achieve battery charging, and the maximum current is 200mA. Generally, this function is disabled by default. Not all modules support battery charging.
Development and Use
Driver
FSC-DB200 Uart Driver
Tools
Feasycom serial debugging assistant, is an official development of Fei Yi Tong to facilitate developers efficient and convenient desktop serial debugging tools.
For tools to download and use, visit the following links:
Feasycom serial debugging assistant download and use guide
Take FSC-BT1026C dual-mode Bluetooth audio module and universal firmware as an example to demonstrate the quick operation steps:
(1). Switch the development board to UART serial communication debugging mode:
Switch the USB/UART toggle switch (component number 2) on the development board to the UART
_images/DB200-2-UART-Enable.png
(2). Connect the development board to the PC through a Type-C cable
_images/DB200-1-TypeC.png
(3). After the connection, the PC recognizes the serial port COMx
PC serial port identification:
_images/PC%E4%B8%B2%E5%8F%A3%E8%AF%86%E5%88%AB-en.png
Feasycom serial debugging assistant Serial identification:
_images/%E4%B8%B2%E5%8F%A3%E5%8A%A9%E6%89%8B-COMx%E8%AF%86%E5%88%AB-en.png
(4). The module is powered on
Press the module power supply button (component number 20) to switch to Type-C power supply (Down=USB);
Press and hold the on/off button (component number 10) for 2s;
Indicator LED00 (Component No. 21) The blue indicator blinks: The device is powered on
_images/DB200-10%2621%2620-PowerON-en.png
_images/%E4%B8%B2%E5%8F%A3%E5%8A%A9%E6%89%8B-%E6%8C%87%E4%BB%A4%E5%93%8D%E5%BA%94-%E4%B8%8A%E7%94%B5-en.png
This demonstration, firmware configuration, power-on response configuration data, different firmware may be different, the actual situation shall prevail.
_images/%E4%B8%B2%E5%8F%A3%E5%8A%A9%E6%89%8B-AT%E8%AF%86%E5%88%AB-en.png
Supports the use of modules with AT commands, such as sending AT+VER in response to the firmware version information of the module
(4). Connect the speaker or headphones to the SPK audio output port (component number 5) of the development board through the 3.5mm AUX audio cable.
_images/DB200-5-SPK.png
(5). Scan and connect modules on the mobile phone
Serial port response +HFPSTAT=3 indicates that the HFP protocol is connected (for calls)
Serial port response +A2DPSTAT=3 indicates that A2DP is connected (for music)
(6). Music mode(A2DP)
When the phone plays music, the serial port feedback:
+A2DPSTAT=3 //A2DP connected,Mobile phone playing music
+PLAYSTAT=1
+A2DPSTAT=4
+A2DPSTAT=5 //Media streaming
(7). Call mode (HFP)
When the mobile phone makes a call, the serial port feedback:
+HFPSTAT=3 //Make a call from a mobile phone
+HFPAUDIO=1 //Create HFPAUDIO
+HFPSTAT=4
+HFPSTAT=6 //call active
AT Communication Example
rnote over host, bt: Profile initialize
bt -> host: +PROFILE=1195
bt -> host: +DEVSTAT=7
rnote over host, bt: The phone searches for BT and initiates a connection
bt -> host: +PAIRED=2C780E805C64
bt -> host: +HFPSTAT=2
bt -> host: +HFPIBR=0
bt -> host: +HFPSIG=5
bt -> host: +HFPBATT=2
bt -> host: +HFPDEV=2C780E805C64,Honor H20
bt -> host: +HFPSTAT=3 (HFP Connected)
bt -> host: +HFPMANU=HUAWEI
bt -> host: +HFPNET=China Unicom
bt -> host: +DEVSTAT=5
bt -> host: +A2DPSTAT=3 (A2DP Connected)
bt -> host: +A2DPDEV=2C780E805C64,Honor H20
bt -> host: +A2DPDEC=3
bt -> host: +AVRCPSTAT=2
bt -> host: +AVRCPSTAT=3 (AVRCP Connected)
bt -> host: +AVRCPDEV=2C780E805C64
host -> bt: AT+HFPDIAL=10086 (dial number "10086")
bt -> host: +HFPAUDIO=1 (audio established)
bt -> host: +HFPSTAT=4
bt -> host: +HFPCID=10086
bt -> host: +HFPSTAT=6 (call active)
host -> bt: AT+HFPCHUP (Hang up)
bt -> host: +HFPAUDIO=0 (audio release)
host -> bt: AT+PLAY(start media player)
bt -> host: +A2DPSTAT=5(media streaming)
bt -> host: +PLAYSTAT=1(player playing)
bt -> host: +TRACKINFO=song,artist,album(track id3 info)
bt -> host: +TRACKSTAT=1,1000,240000(progress,report every secon)
bt -> host: +TRACKSTAT=1,2000,240000
host -> bt: AT+PAUSE(pause media player)
bt -> host: +A2DPSTAT=4
appendix
FSC-DB200(BT1026)Schematic diagram
FSC-BT1026 Instruction Manual
FSC-BT1026 programming user guide
Download PDF version
