FSC-BT1036 AT Command Set
[中文]
This design guide is suitable for engineers to develop FSC-BT1036 series Bluetooth modules, also suitable for BT955, BT936B, BT909C, BT906 series modules
Module Default Settings
FSC-BT1036-XXXX
FSC-BT1036-LE-XXXX
ON
Command Description
Terms
  • Throughout this specification:
  • Content between { } is optional
  • Content behind << represents a COMMAND from Host
  • Content behind >> represents a RESPONSE/EVENT to Host
  • All commands start with “AT”, end with <CR><LF>
  • <CR> means “carriage return”, corresponds to hex value 0x0D
  • <LF> means “line feed”, corresponds to hex value 0x0A
  • If Command has Parameter, Parameter follows behind ‘=’
  • If Command has multiple Parameters, Parameter must be separated by ‘,’
  • If Command has Response, Response starts with <CR><LF>, ends with <CR><LF>
  • Module will always report command’s execution result by using “OK” for success or “ERR<code>” for failure
Example:Read module’s BR/EDR local name
>> +VER=FSC-BT1036-XXXX
Example:Pick up an incoming call when no call incoming actually
>> ERR003
  • All Events start with <CR><LF>, end with <CR><LF>
  • If Event has Parameter, Parameter follow behind ‘=’
  • If Event has multiple Parameters, Parameter must be separated by ‘,’
  • Use command AT+SEP to replace default separator for conflict prevention
Example: Received “1234567890” from mobile phone via SPP profile
Example: Dial number “10086” using a mobile phone when HFP connected
>> +HFPSTAT=4
>> +HFPAUDIO=1
>> +HFPSTAT=6,10086
AT+HELP - Firmware Function/Command Summary
Using help command to get the basic summary information
AT+SEP - Get/Set Event/Response Separator
AT+SEP{=Param}
hex value 0x01~0xFF, default: ‘,’ , specially, using ‘0’ instead of ‘xFF’ for convenience
+SEP=Param
The parameter of events/responses may contain value same to the default separator,
using this command to replace default separator for conflict prevention
(replace the default separator ‘,’ to hex value ‘xFF’ typically)
Example:Read module’s paired record (device name contains ‘,’ already)
>> +PLIST=1,32808,1C5CF226D773, Tony, iPhone12
>> +PLIST=2,40, A0BC30075421, Samsung S8
>> +PLIST=E
Example: Replace separator to ‘0xFF’
<< AT+SEP=0
Example: Read module’s paired record again
>> +PLIST=1<FF>32808<FF>1C5CF226D773<FF>Tony, iPhone12
>> +PLIST=2<FF>40<FF> A0BC30075421<FF>Samsung S8
>> +PLIST=E
AT+VER - Get Firmware Version
Module type
Firmware version
Data of production
The date of production in response will not be changed after firmware upgrade
>> +VER=BT1036,V2.6.1,20220922
230400/256000/460800/512000/921600/1382400
+BAUD=Param1,Param2,Param3
All baudrates supported by current module
Module will change baudrate to target value immediately or
after reboot depending on firmware
Example:Query baudrates supported by current module then change baudrate from 115200 bps to 921600 bps
>> +BAUD=2400,4800,9600,19200,38400,57600,115200,128000,230400,256000,
460800,512000,921600,1382400
<< AT+BAUD=921600
Module switch baudrate to 921600 immediately, host change baudrate as well, query module’s name at new baudrate
>> +NAME=FSC-BT91036-1F26
AT+I2CREG - Read/Write I2C Register
AT+I2CREG=Param1, Param2, Param3 {,Param4}
i2c bus address, 2 byes hex string
i2c register address, 2/4 byes hex string
bytes to read/write (1~64)
value to write
+I2CREG=Param
i2c read return value
Command can be used only if module’s build-in codec is disabled,
the i2c bus is master by default.
Example:Read external i2c slave device, address:0x34, register 0003, bytes:2; then modify value to 0xA13B
<< AT+I2CREG= 34,0003,2
>> +I2CREG=805F
<< AT+I2CREG= 34,0003,2,A13B
AT+I2SCFG - Get/Set I2S Settings
A base-10 representation of a bit field, default:0, for each bit
0:disable; 1:enable
0:master; 1:slave
0:FS=48000Hz;1:FS=44100Hz
BIT[3-4]
00: I2S standard format
10: PCM short frame format
BIT[5-6]
10: bit depth=32bits (only 16bits of MSB effective)
11: bit depth=32bits (only used for PCM mode)
The BT90X modules support serval external codecs by default,
e.g. ES8388, TLV320AIC3204 and etc. BT1036/BT955 built-in codec
If +I2SCFG=0, module will auto detect on of them on booting
Use command AT+HFPSR for setting HFP voice call sample rate
Example:usual configuration and description
Analog mode, module will probe internal/external codecs via I2C on booting,
and will report +CODEC= id to indicate user which codec has been recognized
65
67
113
PCM Master; Sample rate=48000Hz; Resolution=16bits; Bit clock= 48000*16*2ch=1.536Mhz
AT+MICGAIN - Get/Set Analog Input Gain
AT+MICGAIN{=Param}
Gain (0~15, default:8)
Adjust codec analog input gain,
only work for module with codec build in (unavailable for I2S input)
AT+SPKVOL - Get/Set Analog Output Volume
AT+SPKVOL{=Param1,Param2}
Volume for A2DP Streaming (0~15, default:8)
Volume for HFP Call (0~15, default:8)
Adjust codec analog output gain,
only work for module with codec build in (unavailable for I2S output)
AT+REBOOT - Soft Reboot
Module release all Bluetooth connections with remote device then reboot
AT+BTEN - Bluetooth On/Off
0-Power off 1-Power on
AT+PROFILE - Bluetooth Profile Selection
A base-10 representation of a bit field, for each bit:
SPP (Serial Port Profile)
BIT[15]
iAP2 (For iOS devices)
GATT Server and Client, HFP Sink and Source, A2DP Sink and Source, AVRCP Controller
and Target cannot be enabled simultaneously because of mutual exclusion.
Example:Read current profile selection
>> +PROFILE=1195
Example:Enable SPP, GATT Server, HFP Source, A2DP Source profile, disable the others
<< AT+PROFILE=83
Example:Enable SPP, A2DP Sink, disable the others
<< AT+PROFILE=33
AT+AUTOCONN - Power On Auto Reconnect Profile Selection
A base-10 representation of a bit field, format same with AT+PROFILE
Module will attempt to establish connection to devices in paired list after power on.
AT+STAT - Get All Profile State
Query all current enabled profile’s state
Example: Read current profile selection
>> +PROFILE=83
Example:Read profile state
<< AT+STAT
+STAT=3,1,2,5
_images/profile_state.png
AT+DEVSTAT - Read Device State
Example:usual combination and description
AT+ADDR - Get BR/EDR MAC Address
Module’s BR/EDR MAC address (12 Bytes ASCII)
Module’s LE MAC address (12 Bytes ASCII)
BR/EDR local name(1~31 Bytes ASCII)
1: Enable suffix “-XXXX” (lower 4 bytes of MAC address) after local name
Write local name if parameter exist, otherwise read current local name
Example:Read current BR/EDR local name
>> +NAME=FSC-BT1036-XXXX
Example:Change module’s BR/EDR local name to “ABC”,and disable suffix
Example:Change module’s BR/EDR local name to “ABC” and enable suffix
BLE local name(1~25 Bytes ASCII)
0-Disable suffix
AT+SSP - Get/Set BR/EDR Pairing Mode
Pairing mode (0~3, default:2)
need reboot
AT+PIN - Get/Set BR/EDR Pin Code
Pin code only work in legacy pairing mode, see AT+SSP
Example:Read module’s pin code
Example: Change module’s pin code to “1234”
AT+CFM - Accept/Reject Remote Pairing Request
AT+CFM=Param1, Param2
12 Bytes MAC address of remote device
0-Reject remote pairing request
1-Accept remote pairing request
Only used for pairing request in pairing mode 3, see AT+SSP
AT+COD: Get/Set Device Class
Class of device(6 bytes ASCII, default:240408 Handsfree device)
Related configuration reference: COD.
AT+PAIR: Get/Set BR/EDR/BLE Visibility
Module will always be discoverable if no device connected (BR/EDR or BLE),
and be undiscoverable if connected with remote device, unless received this command
AT+PAGE: Get/Set BR/EDR Connectability
AT+PAGE=Param
Module will always be connectable mode if no device connected,
and be unconnectable if connected with remote device, unless received this command
AT+SCAN - Scan Nearby Devices
AT+SCAN=Param1{,Param2{,Param3}}
scan type(0~3)
0: Stop scan
1: Scan nearby BR/EDR devices
2: Scan nearby BLE devices
3: Scan nearby BR/EDR/BLE devices
(1~48)Scan period. unit:1.28s, default:12.8s
(1~25 Bytes ASCII)Name filter. Filter scan results with name if set
Format description reference: +SCAN - Scan Result
AT+RSSI: Get BR/EDR Signal Strength
AT+RSSI=Param
12 Bytes MAC address of current connected device
RSSI value (-127 ~ 0)
(0) Clear all paired record
(1~8) Clear specific paired record with index
(MAC) Clear specific paired record with MAC address
(1~8) Paired device’s index
A base-10 representation of a bit field, support profiles of device, see AT+PROFILE
(MAC) Paired device’s MAC address
(UTF8) Paired device’s name
+PLIST=E End of the paired record
>> +PLIST=1,32808,1C5CF226D773, iPhone12
Example:Clear module’s paired record
AT+AUDROUTE - Audio Route Manager
AT+AUDROUTE{=Param}
Note: HF1 & HF2 means peer Bluetooth headphones
0 Stop audio routing
1 Route music (a2dp streaming) from Module to HP1/HP2 simultaneously
2 Route voice call (hfp sco) between Module and HP1
3 Route voice call (hfp sco) between Module and HP2
4 Route voice call (hfp sco) between HP1 and HP2 (intercom mode)
5 Route voice call (hfp sco) from Module to HP1/HP2 simultaneously
6 Route music (a2dp streaming) from Module to HP1 only
7 Route music (a2dp streaming) from Module to HP2 only
Some route mode require specify firmware version.
AT+TPMODE - Turn On/Off Throughput Mode
Throughput mode(0~1,default:0) 0: Turn Off 1: Turn On
When SPP/GATT profile connected and throughput mode is on,
every byte received via physical UART will be sent to air, vice visa
AT+TXPOWER - tx power configuration
AT+TXPOWER{=Param}
(value:0-15, default:15)
Value
Power(dBm)
-36.1
4.1
5.4
6.5
8.0
8.6
9.1
9.4
10.0
10.2
HFP Commands
AT+HFPSTAT - Read HFP State
+HFPSTAT=Param1{,Param2{,Param3}}
Format description reference: +HFPSTAT - HFP State
AT+HFPSR - Get/Set HFP Sample Rate
AT+HFPSR{=Param}
Sample rate (Hz) for HFP voice call, available value: 0/8000/16000/48000
Resample HFP voice call to specify rate in I2S mode,
the parameter will override settings in AT+I2SCFG for voice call
AT+HFPCFG - Get/Set HFP Configuration
AT+HFPCFG{=Param}
A base-10 representation of a bit field, default:2, for each bit:
When the HFP is abnormally disconnected,Reconnect to last disconnected device
0-disable echo cancellation, 1-enable echo cancellation
0-HFP 3-way-calling function disable, 1-HFP 3-way-calling function enable
AT+HFPCONN - Establish HFP Connection
MAC address of target device (12 Bytes ASCII)
Reconnect to last HFP device if parameter not exist
Example:Connect to last HFP device
<< AT+HFPCONN
Example:Connect to specific HFP device with MAC address
<< AT+HFPCONN=1C5CF226D773
AT+HFPDISC - Release HFP Connection
Release current HFP connection with remote device
AT+HFPDIAL - Dial/Redial Phone Number
AT+HFPDIAL{=Param}
Phone number (1~25 Bytes ASCII)
Dial specific number if parameter exist, otherwise redial
Example:Redial
<< AT+HFPDIAL
Example:Dial number “075527924639”
<< AT+HFPDIAL=075527924639
AT+HFPDTMF - Send DTMF code
AT+HFPDTMF{=Param}
DTMF (0~9/#/*)
Example:Send DTMF code “#” while talking
<< AT+HFPDTMF=#
AT+HFPANSW - Pick Up Incoming Call
AT+HFPCHUP - Reject/Hung up Call
Reject incoming call or hung up outgoing/active call
AT+HFPMCAL - Three way calling Control
AT+HFPMCAL=Param
0: Release held call or reject waiting call
1: Release active call and accept another call
2: Hold active call and accept another call
AT+HFPADTS - Transfer Voice Audio Between Local and Remote Device
AT+HFPADTS=Param
1: Transfer voice audio from module to remote device
2: Transfer voice audio from remote device to module
Transfer voice audio between module and remote device by default if no parameter set
AT+HFPVR - Start/Stop Voice Recognition of Remote Device
AT+HFPVR=Param
0-Stop 1-Start
Start/Stop Voice Recognition of Remote Device (such as Siri for iOS devices)
AT+HFPINFO - Read HFP information
AT+HFPINFO
Return the current HFP status, signal strength, battery, device name, etc.
AT+MICMUTE - Mute Mic
AT+MICMUTE=Param
0-unmute 1-mute
mute mic when call active
A2DP/AVRCP Commands
AT+A2DPSTAT - Read A2DP State
Format description reference: +A2DPSTAT - A2DP State
AT+A2DPCONN - Establish A2DP Connection
Reconnect to last A2DP device if parameter not exist
AT+A2DPDISC - Release A2DP Connection
Release current A2DP connection with remote device
AT+A2DPINFO - Read A2DP information
AT+A2DPINFO
Return the current A2DP status, remote device name , etc.
AT+AVRCPSTAT - Read AVRCP State
Format description reference: +AVRCPSTAT - AVRCP State
AT+AVRCPCFG - Get/Set AVRCP Configuration
AT+AVRCPCFG{=Param}
A base-10 representation of a bit field, default:3, for each bit:
Auto get track ID3 information (title, artist, album) on track changed.default:1
BIT[1-3]
Auto get track play progress if value > 0. default:1 second
Browsing function enable/disable
Auto pull media cover art image to specify folder
Example: Read AVRCP configuration
<< AT+AVRCPCFG
>> +AVRCPCFG=1
Example: Get track play progress every 5 second
<< AT+AVRCPCFG=9
AT+PLAYPAUSE - Track Play/Pause
AT+PLAYPAUSE
Send play or pause command to remote media player according to current play status
AT+PLAY - Track Play
AT+PLAY
Send play command to remote media player
AT+PAUSE - Track Pause
AT+PAUSE
Send pause command to remote media player
AT+STOP - Track Stop
AT+STOP
Send stop command to remote media player
AT+FORWARD - Track Forward
AT+FORWARD
Send forward command to remote media player
AT+BACKWARD - Track Backward
AT+BACKWARD
Send backward command to remote media player
AT+REPEAT - Set Media Player Repeat Mode
AT+REPEAT{=Param}
Repeat mode (0/1) 0-off 1-on
+PLAYMODE=Param1,Param2
Format description reference: +PLAYMODE - Media Player Repeat/ Shuffle Mode
AT+SHUFFLE - Set Media Player Shuffle Mode
AT+SHUFFLE{=Param}
Shuffle mode (0/1) 0-off 1-on
AT+GETMP - List Media Players of Remote Device
AT+GETMP
+BROWDATA=Param1,Param2,Param3,Param4
Format description reference: +BROWDATA - Media Player Filesystem Browsing Data
List media players of remote device, only player with browsable flag set
support browsing. For some phones (e.g. iOS devices),
user may need to launch the player on phone side at the first time.
AT+SETMP - Select Media Player
AT+SETMP=Param
Media Player index
Select the media player to browse, player’s browsable flag must be set,
we will enter the root directory after player selected.
AT+GETFD - List Sub Folders/Tracks of Selected Folder
AT+GETFD=Param1,Param2
Start position, (1~65535)
End position, (1~65535), Param2 >= Param1
List sub folders or media items in current folder.
AT+SETFD - Select and Enter Folder
AT+SETFD=Param
(0):Enter up level folder (other): Enter selected folder
Select and enter the folder to browse.
AT+GETNP - List Tracks in Now Playing List
AT+GETNP=Param1,Param2
(1~65535), Start position
(1~65535), End position, Param2 >= Param1
+BROWDATA=M,Param1,Param2,Param3
AT+ADDMP - Add Track to Media Player
AT+ADDMP=Param
Track ID
Add selected track to media player and start to play.
PBAP Commands
AT+PBSTAT - Read PBAP state
AT+PBSTAT
+PBATAT=Param
Format description reference: +PBSTAT - PBAP State
AT+PBCONN - Establish PBAP Connection
AT+PBCONN{=Param}
Module will use current HFP device’ MAC address if parameter not exist
For some firmware release, module will establish PBAP connection
automatically on received command AT+PBDOWN
AT+PBDISC - Release PBAP Connection
AT+PBDISC
Release current PBAP connection with remote device
AT+PBDOWN - Download Phonebook
Param1{, Param2{, Param3{, Param4}}}
Phonebook type(0-5)
Max items (1~65535, default:3000 for phonebook; 50 for call log)
Phonebook format (defaut:0)
(0) Family Name, Middle Name, Given Name
(1) Given Name, Middle Name, Family Name
(2) Raw vCard 2.1
Contact photo required (0/1)
For some phones (e.g. iPhone), the contact download permission
must be turned on in phone’s Bluetooth settting
AT+PBABORT - Abort Downloading
AT+PBABORT
Abort downloading
SPP Commands
AT+SPPSTAT - Read SPP State
Format description reference: +SPPSTAT - SPP State
Release current SPP connection with remote device
Payload (1~492 Bytes UTF8)
Example: Send data “1234567890” to remote device via SPP
GATT Commands
AT+GATTSTAT - Read GATT State
Format description reference: +GATTSTAT - GATT State
Release current GATT connection with remote device
Example: Send data “1234567890” to remote device via GATT
HID Commands
AT+HIDSTAT - Read HID State
AT+HIDSTAT
+HIDATAT=Param
Format description reference: +HIDSTAT - HID State
AT+HIDCONN - Establish HID Connection
AT+HIDCONN{=Param}
AT+HIDDISC - Release HID Connection
AT+HIDDISC
Release current HID connection with remote device
AT+HIDMODE - Get/Set HID Input Mode
AT+HIDMODE{=Param}
HID keyboard input mode (0~1), default 1
(0) Hex key code
(1) Ascii key code (English)
Module can support various keyboard language with specify firmware,
such as:TURKEY SPAIN PORTUGAL FRANCE GERMANY ITALY CZECH JAPAN
AT+HIDDLY - Get/Set HID Report Period
AT+HIDDLY{=Param}
AT+HIDSEND - Send HID Keyboard Report
AT+HIDSEND=Param1,Param2
Report length
Report payload
Example: Send key code ‘A’ to remote device (on AT+HIDMODE=1)
>> AT+HIDSEND=1,A
<< OK
Example: Send key code ‘A’ to remote device (on AT+HIDMODE=0)
<< AT+HIDSEND=4, xA1 x01 x00 x04
Note: As payload is hex value, hence actual command is:
41 54 2B 48 49 44 53 45 4E 44 3D 34 2C A1 01 00 04 0d 0a
Where:
A1 : report start
01 : page id 1
00 : modifier
04 : key code
Module will auto send debounce key code by itself
AT+HIDCMD - Send HID User Report
AT+HIDCMD=Param
2 bytes hid user report
e.g., for iPhone:
Play/Pause: 00 CD
Stop: 00 B7
Forward: 00 B5
Backward: 00 B6
Fast Forward: 00 B3
Rewind:00 B4
Record:00 B2
VolumpUp:00 E9
VolumpDn:00 EA
Mute:00 E2
On screen keyboard Toggle:01 AE
Example: Send Volume Up to iPhone
<< AT+HIDCMD= x00 xE9
Note: As the payload is hex value, hence actual command is:
41 54 2B 48 49 44 43 4D 44 3D 00 E9 0D 0A
Events Table
General Events
+PWRSTAT - Powering State
+PWRSTAT=Param
0-Powering off 1-Powering on(booting)
AT Command is not recommended to be used while powering on/off state
+SCAN - Scan Result
Index
Device address type (0~3)
(0) BR/EDR address
(1) LE public address
(2) LE random address
Device Name for BR/EDR devices or advertising data for LE devices
Class of device(6 Bytes ASCII)
+SCAN=E: Scan stopped
Example: Scan BR/EDR nearby devices
>> +SCAN=1,-32,3,B019C66209FA,wt-iphone,7A020C
>> +SCAN=2,-74,0,DC0D30000053,BW226,040680
>> +SCAN=3,-43,0,00158354F994,LAPTOP-3L,120104
>> +SCAN=E
+PAIRREQ - Pair Request
+PAIRREQ=Param1,Param2{,Param3}
Passkey (000000~999999)
MAC address (12 Bytes ASCII) of current pairing device
Name of current pairing device
+PAIRED - Pair Result
+PAIRED=Param1,Param2
Pair result (0)-Success (1~255)-Failed reason
+CODEC - Codec ID
+CODEC=Param
Code id
(1) NAU88L25B
(2) TI TLV32AIC3204
(3) ES8388
Firmware integrated I2C drivers of several codecs,
such as NAU88L25B/ TLV32AIC3204/ ES8388, and probe one of them on booting。
BT1036, BT955, BT936 chips have built-in Codec, and do not report Codec instructions
HFP Events
(0~10)
(7) Active held (3-way-calling)
(8) First call active, second call waiting (3-way-calling)
(9) First call active, second call held (3-way-calling)
(10) First call outgoing, second call held (3-way-calling)
Call number, only present for state > 3
Call number(Three-way calling)
Example: Dial number 10086
<< AT+HFPDIAL=10086
>> +HFPSTAT=3
>> +HFPSTAT=4,10086
>> +HFPAUDIO=1
Example: Incoming call with number 13265463800
>> +HFPSTAT=5, 13265463800
>> +HFPAUDIO=1
+HFPDEV - HFP Remote Device Information
(12 Bytes ASCII), Remote MAC address of current HFP connection
(UTF8), Remote device name of current HFP connection
Example: HFP connect success with device
+HFPAUDIO - HFP Voice Audio State
(0) HFP voice audio disconnected, audio input/output routed to remote device
(1) HFP voice audio connected, audio input/output routed to module
+HFPSIG - HFP Remote Device Network Signal Strength
+HFPSIG=Param
(0~5)Network signal strength of remote device
+HFPROAM - HFP Remote Device Roaming State
+HFPROAM=Param
(0/1) Roaming state of remote device
(0~5) Battery level of remote device
+HFPNET - HFP Remote Device Network Operator Selection
+HFPNET=Param
(UTF8)Network operator selection of remote device
+HFPMANU - HFP Remote Device Manufacture
+HFPMANU=Param
(UTF8)Manufacture name of remote device
+HFPNUM - HFP Remote Device Phone Subscriber Number
+HFPNUM=Param
(ASCII)Phone subscriber number of remote device
+HFPIBR - HFP Remote Device In-band-ring Support
+HFPIBR=Param
(0/1) In-band-ring support
Report whether the current connected phone support in-band-ring
+HFPRING - HFP Remote Device Ringing
+HFPRING=Param
(0/1) In-band-ring off/on
Phone is ringing when call incoming, the host platform should play a local ringtone
if in-band-ring not supported by remote mobile phone
A2DP/AVRCP Events
+A2DPDEV - A2DP Remote Device Information
(12 Bytes ASCII), Remote device’s MAC address of current A2DP connection
(UTF8), Remote device’s name of current A2DP connection
+PLAYSTAT - Media Player State
Repeat Mode (1~4)
(1) Off
(2) Single Track
(3) All Tracks
(4) Group
Shuffle Mode (1~3)
(1) Off
(2) All Tracks
(3) Group
+TRACKSTAT - Media Player Play Progress
(0~4), Media Player State, see +PLAYSTAT
(Decimal ASCII),Elapsed time of current track in second
(Decimal ASCII),Total time of current track in second
Example: Read media player play progress every 1s
>> +TRACKSTAT=1,54,322
>> +TRACKSTAT=1,55,322
>> +TRACKSTAT=1,56,322
+TRACKINFO - Media Track Information
title
artist
album
Example: Phone playing song “Creep-Radio Head”
+BROWSTAT - Media Browsing State
+BROWSTAT=Param
(4) Browsing
+BROWDATA=Param1, Param2 {, Param3{, Param4}}
Browsing type, for each type, the following data means:
P
Parame1: media player information
Parame2: 0 – support browsing; 1- not support browsing
Parame3: media player id
Parame4: media player name
R
Parame1: root dictionary name
Parame2: root dictionary name
F
Parame1: folder ID and name
Parame2: folder ID
Parame3: folder name
M
Parame1: media track ID and name
Parame2: media track ID
Parame3: media track name
E
Parame1: browsing operation result code
Parame2: 0 - browsing success; other - browsing error code
+BIPSTAT - BIP State
+BIPSTAT=Param
BIP Profile only used for media player cover art image downloading now
+COVERART - Media Track Cover Art Download Success
+COVERART=Param
Image ID
Phonebook Access Events
+PBSTAT=Param
+PBCNT - Phonebook Entries of Remote Device
+PBCNT=Param
Phonebook entries of remote device
+PBDATA - Phonebook Data
+PBDATA=Param1,Param2,Param3{,Param4}
Number
(15 Bytes ASCII), Call time if current download type is call log
Param4-2
Contact photo download compete flag if current download type is Phonebook,
otherwise this parameter will not exist
+PBDATA=E: Download complete
Call time may not exist for some mobile phones
Example: Download all phonebook
<< AT+PBDOWN=1
>> +PBCNT=234
+PBDATA=1 , Jack , 18219146201
+PBDATA=1 , kenan , 8613771972680
+PBDATA=E
Example: Download 10 dialed call log
<< AT+PBDOWN=3,10
>> +PBDATA=3 , China Mobile , 10086 , 20171013T103516
+PBDATA=3 , Jerry , 18688967507 , 20171012T152826
+PBDATA=E
SPP Events
Events for iAP2 (Apple Accessory Protocol) and AAP (Android Auto Protocol) are almost the same with SPP, which are:
  • +IAPSTAT, +IAPDATA for iAP2 profile
  • +AAPSTAT, +AAPDATA for AAP profile
Document will omit these events.
Example: Received data “1234567890” from remote device via SPP
GATT Events
Example: Received data “1234567890” from remote device via GATT
HID Events
+HIDSTAT=Param
Download PDF
Download PDF
