FSC-BT1036 User Instructions
This design guide is suitable for engineers to develop FSC-BT1036 series Bluetooth modules, also suitable for BT955, BT936B, BT909C, BT906 series modules
Module Default Settings
FSC-BT1036-XXXX
FSC-BT1036-LE-XXXX
ON
Hardware Description
Pin Diagram
FSC-BT1036C as an example:
_images/BT1036_pin_map.png
I2S_CLK
I2S BCLK
I2S_IN
I2S DATA IN
I2S_OUT
I2S SYNC
External reset input: active Low
UART TX
UART RX
UART CTS
UART RTS(default: PA mute pin)
Output square wave in pairing mode,
output high level when bluetooth is connected
SPP/GATT is not connected to output low level,
connected to output high level
Power supply for I/O ports, DC 3.3V
40
MIC_RP
MIC0/Line_IN differential R input, positive
41
MIC_RN
MIC0/Line_IN differential R input, negative
MIC_BASE
48
Change the 0 ohm resistance near the antenna,
you can connect an external Bluetooth antenna
Hardware Design Notes
  • The simple test of the module only needs to connect VDD/GND/UART_RX/UART_TX to use
  • After drawing the schematic diagram, please send it to Feasycom for review,so as to avoid the Bluetooth distance not reaching the best effect
GATT Default service and characteristic
Characteristic
throughput services
app send to module
module send to app
Application scenarios
profiles initializing and change parameter
The following figure shows Profile initialization and name modification
bt -> host: +DEVSTAT=0
bt -> host: +PWRSTAT=1
bt -> host: +VER=BT1036,V2.0.1,20210922
bt -> host: +PROFILE=1195
bt -> host: +PBSTAT=1
bt -> host: +DEVSTAT=7 (auto discoverable,phone can find and connect to us)
rnote over host, bt: change name to "CARKIT",disable suffix. and verify readback
bt -> host: AT+NAME=FSC-BT1036-1E49
modify any parameters, it is recommended to query first and then modify the final verification
Sink mode connection
If the factory firmware is an integrated transceiver program, the program default profile=339, Need to send AT+PRFOILE=1195 to configure audio receiving(sink) mode (Enable SPP, GATT Server, HFP Sink, A2DP Sink, AVRCP-Controller, PBAP). Some module transceiver programs do not support PBAP, such as BT955 module
rnote over host, bt: Mobile phone search and connect to us
bt -> host: +A2DPSTAT=3 (A2DP connected)
bt -> host: +AVRCPSTAT=3 (AVRCP connected)
bt -> host: +HFPSTAT=3 (HFP connected)
bt -> host: +HFPSIG=3
bt -> host: +HFPBATT=4
host -> bt: +HFPDIAL=10086 (dial number "10086")
bt -> host: +HFPSTAT=4,10086
bt -> host: +HFPAUDIO=1 (audio established)
host -> bt: AT+HFPCHUP(hung up)
bt -> host: +HFPAUDIO=0 (audio release)
host -> bt: AT+PLAY(start media player)
bt -> host: +A2DPSTAT=5 (media streaming)
bt -> host: +PLAYSTAT=1 (player playing)
bt -> host: +TRACKINFO=song,artist,album (track id3 info)
bt -> host: +TRACKSTAT=1,1,240 (progress,report every second)
bt -> host: +TRACKSTAT=1,2,240
host -> bt: AT+PAUSE(pause media player)
bt -> host: +A2DPSTAT=4
Source mode connection
The transmission(source) mode connection needs to configure the module to A2DP Source, HFP Source, The program will not automatically enter the audio transmission mode or the call (intercom) mode after connecting the headset and speaker by default, you need to send the command: Start audio transmission (AT+AUDROUTE=1) Start HFP (AT+AUDROUTE=2)
bt -> host: +PROFILE=339
rnote over host, bt: search nearby devices and connect to airpods
host -> bt: AT+SCAN=1
bt -> host: +SCAN=1,-87,0,DC0D30001E49,FSC-BT1036-1E49,5A020C
bt -> host: +SCAN=2,-78,0,7C9A1DA36B41,AirPods,240404
host -> bt: AT+A2DPCONN=7C9A1DA36B41
bt -> host: +A2DPDEV=7C9A1DA36B41,AirPods
bt -> host: +HFPSTAT=2
bt -> host: +HFPDEV=7C9A1DA36B41,AirPods
rnote over host, bt: Established A2dp audio
host -> bt: AT+AUDROUTE=1
bt -> host: +AUDMODE=1
rnote over host, bt: Release A2dp audio
host -> bt: AT+AUDROUTE=0
bt -> host: +AUDMODE=0
rnote over host, bt: Established HFP audio
host -> bt: AT+AUDROUTE=2
bt -> host: +AUDMODE=2
rnote over host, bt: Release HFP audio
MCU connects to AirPods and starts audio transmission Reference code:
 1#define PROFILE_HFP_HF              (uint16)(BIT3)
 2#define PROFILE_HFP_AG              (uint16)(BIT4)
 3#define PROFILE_A2DP_SINK           (uint16)(BIT5)
 4#define PROFILE_A2DP_SOURCE         (uint16)(BIT6)
 6void bt_connect(void)
 7{
 8    //enable hfp source,a2dp source,avrcp tg,spp,gatt
 9    uart_send("AT+PROFILE=339\r\n"); //if profile changes,module will auto reboot,
10    wait_ms(500);
11    uart_send("AT+PROFILE\r\n");
12    uint32 profiles = uart_read("+PROFILE",profiles);
13    if(profiles & (PROFILE_A2DP_SOURCE|PROFILE_HFP_AG))
14    {
15        uint8 addr[6];
16        uint8 buf[30]={0};
17        uint8 a2dp_state=0
18        uart_send("AT+SCAN=1\r\n");
19        uart_read_scan_addr("+SCAN",addr);
20        sprintf(buf,"AT+A2DPCONN=%s\r\n",addr);
21        uart_send(buf); //send a2dp connect
23        uart_read("+A2DPSTAT",a2dp_state);
24        if(a2dp_state == 3) //a2dp connected
25        {
26            uart_send("AT+AUDROUTE=1"); // start a2dp audio
27        }
28        uart_read("+A2DPSTAT",a2dp_state);
29        if(a2dp_state == 5)
30        {
31            //a2dp streaming
32        }
33    }
34    else
35    {/*not support master*/}
36}
HFP three way calling operations
BT1036, BT955 and other modules have not enabled the three way calling function. If you need to test this function, please contact Feasycom
rnote over host, bt: HFP connected
rnote over host, bt: dial number "10086"
host -> bt: AT+HFPDIAL=10086
bt -> host: +HFPSTAT=4,10086 (phone dialing)
rnote over host, bt: third call waiting
bt -> host: +HFPSTAT=8,10086,18620277271
host -> bt: AT+HFPMCAL=2 (Hold active call and accept another call)
bt -> host: +HFPSTAT=9,18620277271,10086 (18620277271 active,10086 hold)
bt -> host: +HFPSTAT=9,10086,18620277271 (10086 active,18620277271 hold)
host -> bt: AT+HFPMCAL=1 (Release active call and accept another call)
bt -> host: +HFPSTAT=6,18620277271 (one call active now)
rnote over host, bt: hung up
AVRCP filesystem browsing
rnote over host, bt: A2DP/AVRCP connected
rnote over host, bt: filesystem browsing
bt -> host: +BROWSTAT=3 (browsing channel connected)
host -> bt: AT+GETMP (retrieve media players)
bt -> host: +BROWSTAT=4
bt -> host: +BROWDATA=P,1,1,Music (found browsable media player)
bt -> host: +BROWDATA=E,0
host -> bt: AT+SETMP=1 (select player)
bt -> host: +BROWDATA=R,iPhone (filesystem root:iPhone)
host -> bt: AT+GETFD=1,5 (list folders under root dir)
bt -> host: +BROWDATA=F,0100000000000000,我的音乐 (/iPhone/我的音乐)
bt -> host: +BROWDATA=F,0200000000000000,播放列表 (/iPhone/播放列表)
host -> bt: AT+SETFD=0200000000000000 (list folders under 播放列表)
bt -> host: +BROWDATA=F,0100000000000000,最近添加
bt -> host: +BROWDATA=F,524A57F5E4594DE6,播放历史
bt <--> host: (continue list sub dir until find audio tracks:AT+SETFD=folder id,AT+GETFD=x,y)
bt -> host: +BROWDATA=M,285E9813C3AB900E,New Soul
bt -> host: +BROWDATA=F,C15E9813C3AB900E,BLUE
host -> bt: AT+ADDMP=C15E9813C3AB900E (select audio track and add to media player)
bt --> host: media player playing BLUE now
AVRCP Cover Art image retrieval
Cover Art image download is only supported by the car protocol stack module, not supported by the SOC audio module
rnote over host, bt: download Cover Art image
bt -> host: +BIPSTAT=3 (basic image profile connected)
bt <--> host: music start streaming
bt -> host: +BIPSTAT=4 (blueware auto pulling coverart jpeg image background)
bt -> host: +COVERART=1000090 (download complete)
Phonebook/Contact photo downloading
Contact photo download is only supported by the car protocol stack module, not supported by the SOC audio module When some firmware does not support downloading, it will automatically connect to PBAP, and you need to send AT+PBCONN to connect to PBAP before downloading
rnote over host, bt: download all phonebook
host -> bt: AT+PBDOWN=1
bt -> host: +PBSTAT=2
bt -> host: +PBSTAT=3 (PBAP connected)
bt -> host: +PBSTAT=4 (PBAP downloading)
bt -> host: +PBDATA=1,本机号码,+8618620277272
bt -> host: +PBDATA=1,张三,0571-85592192
bt -> host: +PBDATA=1,jerry,18909731215
bt -> host: +PBDATA=E (Download compete)
rnote over host, bt: download all phonebook with contact photo
host -> bt: AT+PBDOWN=1,,,1
bt <--> host: (if item's photo flag set,photo image number.jpg should be placed in spcecify folder)
bt -> host: +PBDATA=1,本机号码,+8618620277272,1
bt -> host: +PBDATA=1,jerry,18909731215,1
rnote over host, bt: download 50 contacts in recent call history
host -> bt: AT+PBWODN=5,50
bt -> host: +PBDATA=3,yidong,+10086,20200213T114247
bt -> host: +PBDATA=2,andy,85592192,20200212T104202
Download PDF
Download PDF
