硬件设计
1. 模块引脚图
以FSC-BT1026C为例:
2. 引脚描述
I2S_CLK |
I2S BCLK |
I2S_IN |
I2S DATA IN |
I2S_OUT |
I2S DATA OUT |
I2S_WS |
I2S SYNC |
串口TX |
14 |
串口RX |
串口流控脚(默认不需要接) |
串口流控脚(默认为PA脚) |
配对模式时输出方波,蓝牙已连接输出高电平 |
SPP/GATT未连接输出低电平,连接输出高电平 |
34 |
VREG_IN |
开关机脚 |
VDD_IO |
pio supply |
43 |
MIC_LP |
Audio |
MIC0/Line_IN differential L input, positive |
44 |
MIC_LN |
Audio |
MIC0/Line_IN differential L input, negative |
45 |
MIC_BIAS |
Audio |
MIC Power Supplies |
46 |
SPK_RN |
Audio |
Headphone/speaker differential R output, negative |
47 |
SPK_RP |
Audio |
Headphone/speaker differential R output, positive |
48 |
SPK_LN |
Audio |
Headphone/speaker differential L output, negative |
49 |
SPK_LP |
Audio |
Headphone/speaker differential L output, positive |
51 |
改变天线附近的0欧电阻,可以外接蓝牙天线 |
3. 上电电路设计
FSC-BT1026X系列模块上电开机方式有三种可选项,分别为:延时开机电路、按键开关机电路、MCU控制开关机电路。如下图所示:
4. 硬件设计说明
模块简易测试环境,只需要连接 VDD / VDD_IO / VREG_IN / GND / UART_RX / UART_TX 即可使用
VREG_IN默认为按键开关机方式。开机:短按1秒. 关机:长按3秒。
若不需要按键开关机,上电延时100ms再拉高VREG
在画完PCB电路原理图后,请发给飞易通进行审核,避免蓝牙距离达不到最佳效果
