FSC-BT1036 应用说明
本设计指南适用于工程师开发 FSC-BT1036 系列蓝牙模组,同样也适合BT6001、BT955、BT936B、BT909C、BT906系列模组
模组默认参数
FSC-BT1036-XXXX |
FSC-BT1036-LE-XXXX |
On |
以FSC-BT1036C为例:
引脚描述
I2S_CLK |
I2S BCLK |
I2S_IN |
I2S DATA IN |
I2S_OUT |
I2S DATA OUT |
I2S_WS |
I2S SYNC |
串口TX |
14 |
串口RX |
串口流控脚(默认不需要接) |
串口流控脚(默认为PA脚) |
配对模式时输出方波,蓝牙已连接输出高电平 |
SPP/GATT未连接输出低电平,连接输出高电平 |
40 |
MIC_RP |
Audio |
MIC0/Line_IN differential R input, positive |
41 |
MIC_RN |
Audio |
MIC0/Line_IN differential R input, negative |
43 |
MIC_LP |
Audio |
MIC0/Line_IN differential L input, positive |
44 |
MIC_LN |
Audio |
MIC0/Line_IN differential L input, negative |
45 |
MIC_BASE |
Audio |
MIC Power Supplies |
46 |
SPK_RN |
Audio |
Headphone/speaker differential R output, negative |
47 |
SPK_RP |
Audio |
Headphone/speaker differential R output, positive |
48 |
SPK_LN |
Audio |
Headphone/speaker differential L output, negative |
49 |
SPK_LP |
Audio |
Headphone/speaker differential L output, positive |
51 |
改变天线附近的0欧电阻,可以外接蓝牙天线 |
模组简易测试只需要连接VDD/GND/UART_RX/UART_TX即可使用
画完原理图后请发给飞易通进行审核,避免蓝牙距离达不到最佳效果
SPP (Serial Port Profile)
GATTS (Generic Attribute Profile LE-Peripheral role)
GATTC (Generic Attribute Profile LE-Central role)
HFP-HF (Hands-Free Profile)
HFP-AG (Hands-Free-AG Profile)
A2DP-Sink (Advanced Audio Distribution Profile)
A2DP-Source (Advanced Audio Distribution Profile)
AVRCP-Controller (Audio/Video remote controller Profile)
AVRCP-Target (Audio/Video remote controller Profile)
HID-DEVICE (Human Interface Profile)
PBAP (Phonebook Access Profile)
GATT透传服务
类型 |
UUID |
权限 |
描述 |
Service |
0xFFF0 |
透传服务 |
Write |
0xFFF2 |
Write,Write Without Response |
APP发给模组 |
Notify |
0xFFF1 |
Notify |
模组发给APP |
应用场景
Profile初始化及修改参数
下图展示了Profile初始化以及修改名称
MCU 修改设备名CARKIT参考代码,修改任何参数建议先查询再修改最后校验:
3 uart_send("AT+NAME\r\n");
4 if(uart_read("+NAME",name_buf))
5 {
6 if(memcmp(name_buf,"CARKIT",6))
7 {
8 uart_send("AT+NAME=CARKIT,0\r\n"); //defalut disable MAC address suffix
9 uart_send("AT+NAME\r\n"); // read bt name
10 if(uart_read("+NAME",name_buf))
11 {
12 if(memcmp(name_buf,"CARKIT",6))
13 {
14 //change name fail
15 }
16 else
17 {
18 //change name success
19 }
20 }
21 }
22 }
接收模式连接
出厂固件如果是收发一体程序,程序默认profile=339, 需发送AT+PRFOILE=1195配置成音频接收模式 (打开SPP,GATT Server,HFP Sink,A2DP Sink,AVRCP-Controller,PBAP) 部分模块收发一体程序不支持PBAP,如BT955模块
发射模式连接
发射模式连接需将模块配置到A2DP Source 、 HFP Source, 程序默认连接耳机、音箱后不会主动进入音频发射模式或通话(对讲)模式,需发送指令: 启动音频发射(AT+AUDROUTE=1) 启动通话(AT+AUDROUTE=2)
MCU 连接AirPods,并启动音频发射 参考代码:
1#define PROFILE_HFP_HF (uint16)(BIT3)
2#define PROFILE_HFP_AG (uint16)(BIT4)
3#define PROFILE_A2DP_SINK (uint16)(BIT5)
4#define PROFILE_A2DP_SOURCE (uint16)(BIT6)
6void bt_connect(void)
7{
8 //enable hfp source,a2dp source,avrcp tg,spp,gatt
9 uart_send("AT+PROFILE=339\r\n"); //if profile changes,module will auto reboot,
10 wait_ms(500);
11 uart_send("AT+PROFILE\r\n");
12 uint32 profiles = uart_read("+PROFILE",profiles);
13 if(profiles & (PROFILE_A2DP_SOURCE|PROFILE_HFP_AG))
14 {
15 uint8 addr[6];
16 uint8 buf[30]={0};
17 uint8 a2dp_state=0
18 uart_send("AT+SCAN=1\r\n");
19 uart_read_scan_addr("+SCAN",addr);
20 sprintf(buf,"AT+A2DPCONN=%s\r\n",addr);
21 uart_send(buf); //send a2dp connect
23 uart_read("+A2DPSTAT",a2dp_state);
24 if(a2dp_state == 3) //a2dp connected
25 {
26 uart_send("AT+AUDROUTE=1"); // start a2dp audio
27 }
28 uart_read("+A2DPSTAT",a2dp_state);
29 if(a2dp_state == 5)
30 {
31 //a2dp streaming
32 }
33 }
34 else
35 {/*not support master*/}
36}
HFP三方通话操作
BT1036、BT955等模块未打开三方通话功能,若需要测试该功能请和飞易通联系
AVRCP文件系统浏览
BT1036、BT955等模块未打开此功能,若需要测试该功能请和飞易通联系
AVRCP专辑图片下载
专辑图片下载仅车载协议栈模块支持,SOC音频模块不支持
Phonebook/Contact photo下载
Contact photo 仅车载协议栈模块支持,SOC音频模块不支持 部分固件不支持下载时,自动连接PBAP, 需发送AT+PBCONN连接PBAP再下载
