FeasyBeacon Advertising Protocol
v1.1
FeasyBeacon device is capable of advertising up to 10 frames of advertisement simultaneously, therefore, if the developers use an mobile app or an central device to scan the nearby FeasyBeacon device, they may receive more than one advertising frame.
FeasyBeacon mobile SDK and app are designed to be able to parse all of the FeasyBeacon Advertising Frames, the FeasyBeacon mobile SDK and app are completely free and would be kept updating periodically by Feasycom.
General Advertising Frame
FeasyBeacon General Advertising Frame includes content like Firmare Version, MAC Address, Battery Life and so on. This advertisement is not configurable, it’s readonly advertisement.
General Advertising Frame can be find in Service Data( Tag 0x16 ):
Len(1Byte)
Tag(1Byte)
Service(2Byte)
Model(1Byte)
Version(2Byte)
Feature(1Byte)
MAC (6Byte)
Battery Level(1Byte)
0x0D
0x16
Len : 1 byte, the length of the frame that exclude the Len word.
Tag : 1 byte, type of frame, 0x16 represents General Advertising Frame
Service : 2 bytes, 0xFFF0
Model : 1 byte, device model number:
Value
Model Number
0x15
FSC-BP102
0x19
FSC-BP109
0x1A
FSC-BP103
0x1B
FSC-BP104
0x1C
FSC-BP201
0x1D
FSC-BP106
0x1E
FSC-BP101
0x24
FSC-BP120
0x27
FSC-BP108
0x28
FSC-BP108N
Version : 2 bytes, device firmware version
Feature : 1 byte, features that are supported:
Bits
Definition
Bit0 ~ bit1
Connectivity state
0: Not connectable
1: Connectable, no password required
2: Connectable, password required
Bit2 ~ bit3
Reserved
must set to 0
Bit4
LED availability
0: No LED applied
1: LED is applied
Bit5
buzzer availability
0: No buzzer applied
1: Buzzer is applied
Bit6
G-sensor availability
0: No G-sensor applied
1: G-sensor is applied
Bit7
Button availability
0: No button applied
1: Button is applied
MAC : 6 bytes, the MAC address of the device
Battery Level : 1 byte, the current battery level
Value
Model Number
0x00 – 0x64
0~100%
0x65
non-battery power supply
An advertisement that containing General Advertising Frame
Byte offset
value
Properties
0x02
Data length – 2 bytes
readonly
0x01
Data type – flags
readonly
0x06
LE and BR/EDR flag
readonly
3 Note1
0x0E
Data length – 26 bytes
readonly
0x16
Data type - manufacturer specific data
readonly
0xF0
16-bit Service UUID 1st byte
readonly
0xFF
16-bit Service UUID 2nd byte
readonly
0x1A Note2
Model Number
readonly
0x02
Firmware version 1st byte
readonly
0x05
Firmware version 2nd byte
readonly
0x02
Feature
readonly
0xDC
MAC address 1st byte
readonly
0x0D
MAC address 2nd byte
readonly
0x30
MAC address 3rd byte
readonly
0x00
MAC address 4th byte
readonly
0x1F
MAC address 5th byte
readonly
0xA5
MAC address 6th byte
readonly
0x64
Battery level
readonly
Note1 : From byte 3 to byte 17 is the data block of General Advertising Frame, the byte order of it is constant, but the byte order of the whole advertisement may vary by model.
Note2 : Bytes like model number, firmware version, feature, MAC, and battery level may vary by beacon.
iBeacon Advertising Frame
iBeacon Advertising packet structure
Byte offset
Default value
Properties
0x02
constant preamble
0x01
Data type – flags
constant preamble
0x06
LE and BR/EDR flag
constant preamble
0x1A
constant preamble
0xFF
constant preamble
0x4C
Manufacturer data
constant preamble
0x00
Manufacturer data
constant preamble
0x02
Manufacturer data
constant preamble
0x15
Manufacturer data
constant preamble
0xFD
Proximity UUID 1st byte
set user UUID
0xA5
Proximity UUID 2nd byte
set user UUID
0x06
Proximity UUID 3rd byte
set user UUID
0x93
Proximity UUID 4th byte
set user UUID
0xA4
Proximity UUID 5th byte
set user UUID
0xE2
Proximity UUID 6th byte
set user UUID
0x4F
Proximity UUID 7th byte
set user UUID
0xB1
Proximity UUID 8th byte
set user UUID
0xAF
Proximity UUID 9th byte
set user UUID
0xCF
Proximity UUID 10th byte
set user UUID
19
0xC6
Proximity UUID 11th byte
set user UUID
20
0xEB
Proximity UUID 12th byte
set user UUID
0x07
Proximity UUID 13th byte
set user UUID
0x64
Proximity UUID 14th byte
set user UUID
23
0x78
Proximity UUID 15th byte
set user UUID
24
0x25
Proximity UUID 16th byte
set user UUID
25
0x27
Major 1st byte
set major value
26
0x51
Major 2nd byte
set major value
27
0x65
Minor 1st byte
set minor value
28
0xC1
Minor 2nd byte
set minor value
29
0xB5
Signal power (calibrated RSSI@1m)
signal power value
Eddystone Advertising Frame
You can read the complete specification of all Eddystone packets on Google’s GitHub (https://github.com/google/eddystone).
Sensor Data Frame
Sensor Data Frame includes content like temperature, humidity and so on. This advertisement is not configurable, it’s readonly advertisement.
General Advertising Frame can be find in vendor specified field ( Tag 0xFF ) :
Len (1 Byte)
Tag (1 Byte)
Company (2 Bytes)
Version (1 Byte)
Data (N Bytes)
0xFF
0x01
Tag1 + Tag2 +…
Tag : 1 byte, type of frame, 0xFF represents vendor specified field
Company : 2 bytes, 0xFFF0
Version : 1 byte, protocol version, start from 0x01
Data : N bytes, sensor data, use Tag structure (len + tag + data)
Temperature and Humidity Sensor
Len (1 Byte)
Tag (1 Byte)
Temperature (2 Bytes)
Humidity (2 Bytes)
0x05
0x01
Len : 1 byte, the length of the tag-frame that exclude the Len word.
Tag : 1 byte, type of frame, 0x01 represents temperature and humidity.
Temperature : 2 bytes, the first byte represents the integer portion and it’s a signed number (can be nagative or positive), the second byte represents the fractional portion, the unit is centigrade.
Humidity : 2 bytes, the first byte represents the integer portion, the second byte represents the fractional portion, the unit is percentage.
PDF Download
