Functional Description
Module Default Configuration
FSC-BT2064 |
FSC-BT2064-LE |
Off |
GPIO Indicators
PIN |
Status |
PIN21 |
Slow Blinking |
Power-on & Bluetooth Disconnected |
PIN21 |
Steady On |
Bluetooth Connected |
BT Connection Status
PIN |
Status |
PIN22 |
Low Level |
PIN22 |
High Level |
Work Modes
Throughput Mode
Bluetooth Connected: All data received via UART is sent as-is to the remote Bluetooth device.
Command Mode
Bluetooth Connected: Data received via UART is still parsed as AT commands. Data must be sent to the remote device using AT commands, e.g.,
AT+SPPSENDorAT+LESEND.
GATT Service
UUID |
Operation |
Service |
0xFFF0 |
Throughput transmission service |
Write |
0xFFF2 |
Write, |
APP to Module |
Notify |
0xFFF1 |
Notify |
Module to APP |
