Profile Initialization
Module Profile initialization, response event examples are as follows:
bt -> host: +DEVSTAT=0
bt -> host: +PBSTAT=1
bt -> host: +VER=FSC-BT1026C,V4.9.4,20230428
bt -> host: +DEVSTAT=7
bt -> host: +PROFILE=1195
Parameter Modification
Modify Bluetooth Name
rnote over host, bt: Change Bluetooth name
bt -> host: +NAME=FSC-BT1026C
host -> bt: AT+NAME=My_Bluetooth,1
bt -> host: +NAME=My_Bluetooth0012
Before the MCU modifies any parameters, it is recommended to first query, then modify, and finally verify. For the MCU to modify the device name to CARKIT, the reference code example is as follows:
void change_name(void)
    uart_send("AT+NAME\r\n");
    if(uart_read("+NAME",name_buf))
        if(memcmp(name_buf,"CARKIT",6))
            uart_send("AT+NAME=CARKIT,0\r\n");  //defalut disable MAC address suffix
            uart_send("AT+NAME\r\n"); // read bt name
                    //change name fail
                else
                    //change name success
Auido Sink Mode Application
Profile Connection
rnote over host, bt:Mobile phone search and connect to BT1026x
bt -> host: +PAIRED=44DA30391295
bt -> host: +HFPSTAT=2
bt -> host: +AVRCPSTAT=2
bt -> host: +A2DPSTAT=3(A2DP connection established)
bt -> host: +DEVSTAT=5
bt -> host: +A2DPDEV=44DA30391295,Rickphone
bt -> host: +HFPIBR=1
bt -> host: +AVRCPSTAT=3(AVRCP connection established)
bt -> host: +AVRCPDEV=44DA30391295
bt -> host: +HFPSIG=5
bt -> host: +HFPBATT=4
bt -> host: +HFPDEV=44DA30391295,Rickphone
bt -> host: +HFPSTAT=3((HFP connection established))
bt -> host: +A2DPDEC=3
Play and Pause Music
rnote over host, bt: Play and Pause
host -> bt: AT+PLAY
bt -> host: +A2DPSTAT=4
bt -> host: +PLAYSTAT=1
bt -> host: +TRACKINFO=beautiful
bt -> host: +TRACKSTAT=1,73174,392874
bt -> host: +TRACKSTAT=1,74202,392874
bt -> host: +TRACKSTAT=1,75272,392874
host -> bt: AT+PAUSE
Take and Hang up Call
rnote over host, bt: Make and hang up calls
host -> bt: AT+HFPDIAL=10086
bt -> host: +HFPAUDIO=1
bt -> host: +HFPSTAT=4
bt -> host: +HFPCID=10086
bt -> host: +HFPCIE=10086
bt -> host: +HFPSTAT=6
host -> bt: AT+HFPCHUP
bt -> host: +HFPAUDIO=0
Phonebook Download
Application Process Operation Examples:
HFP connection has been established
Response: <<+PWRSTAT=1
Response: <<+VER=FSC-BT1026C,V4.9.4,20230428     // Example, please refer to the actual version
Response: <<+PROFILE=1195            // General default, enable SPP, GATT Server, HFP-HF, A2DP Sink, AVRCP Controller, PBAP Server profiles
Response: <<+SPPSTAT=1
Response: <<+GATTSTAT=1
Response: <<+A2DPSTAT=1
Response: <<+AVRCPSTAT=1
Response: <<+HFPSTAT=1
Response: <<+PBSTAT=1
Response: <<+DEVSTAT=1
Response: <<+DEVSTAT=7            // Enables device discoverability; mobile phones can find this Bluetooth device and establish a connection
Download all phonebooks
Send :>>AT+PBDOWN=1
Response: <<OK
Response: <<+PBSTAT=2
Response: <<+PBSTAT=3         // PBAP connected
Response: <<+PBSTAT=4         // PBAP downloading
Response: <<+PBDATA=1<FF>Local Number<FF>+8618620277272
Response: <<+PBDATA=1<FF>Zhang San<FF>0571-85592192
Response: <<+PBDATA=1<FF>Jerry<FF>18909731215
Response: <<+PBDATA=E         // Download completed
Download 50 call records
Send: >>AT+PBWODN=5,50
Response: <<ok
Response: <<+PBDATA=3<FF>yidong<FF>+10086<FF>20200213T114247
Response: <<+PBDATA=2<FF>andy<FF>85592192<FF>20200212T104202
