Profile Initialization
Module Profile initialization, examples:
Parameter Modification
Modify Bluetooth Name
Examples: Modify Bluetooth name to CARKIT(without address code suffix) and verify it.
Code Examples
Before the MCU modifies any parameters, it is recommended to first query, then modify, and finally verify.
For the MCU to modify the device name to CARKIT, the reference code example is as follows:
3 uart_send("AT+NAME\r\n");
4 if(uart_read("+NAME",name_buf))
5 {
6 if(memcmp(name_buf,"CARKIT",6))
7 {
8 uart_send("AT+NAME=CARKIT,0\r\n"); //defalut disable MAC address suffix
9 uart_send("AT+NAME\r\n"); // read bt name
10 if(uart_read("+NAME",name_buf))
11 {
12 if(memcmp(name_buf,"CARKIT",6))
13 {
14 //change name fail
15 }
16 else
17 {
18 //change name success
19 }
20 }
21 }
22 }
Throughput Mode Application
What is Throughput Mode?
There are two data transmission modes for FSC-BT909C: Throughput Mode and Command Mode. Please refer to the FSC-BT909C General Data AT Command Set and use the AT command AT+TPMODE to query and switch the working mode.
The differences between the two work modes are as follows:
Throughput Mode :
Bluetooth Not Connected : Data received via UART is parsed as AT commands.
Bluetooth Connected : All data received via UART is sent as-is to the remote Bluetooth device. It does not contain any data headers or framing and does not require AT commands to send data.
Command Mode :
Bluetooth Connected : Data received via UART is still parsed as AT commands. It will contain specific response indication headers and framing. Data must be sent to the remote device using AT commands, such as
AT+LESENDorAT+SPPSEND.
The timing sequence for the module to enter the throughput mode is as follows:
SPP Master and Slave Application
FSC-BT909C Universal Bluetooth dual-mode data transmission Application Firmware supports both SPP Master and SPP Slave functions simultaneously. When AT commands for the SPP Master function are used, the module acts as the Master role, otherwise, it acts as the Slave role.
Key AT Commands List for SPP Master Mode Function:
AT Commands |
AT+SCAN |
Search for nearby Bluetooth devices |
AT+SPPCONN |
Establish SPP connection |
AT+SPPSTAT |
Read SPP status |
AT+SPPDISC |
Disconnect the SPP connection |
AT+SPPSEND |
Send data via SPP |
Example of SPP master interaction (AT command mode):
Auido Sink Mode Application
If the factory firmware of the module is transceiver-in-one program, the default +PROFILE=339. You need to send the AT command AT+PROFILE=1195 to configure it to audio sink mode (enabling SPP, GATT Server, HFP Sink, A2DP Sink, AVRCP-Controller, and PBAP).
Auido Source Mode Application
Application Examples
It is necessary to configure the module to A2DP Source and HFP-AP.
After connecting to the remote device, the module needs to select the audio route: send audio (AT+AUDROUTE=1) and make calls (AT+AUDROUTE=2).
Code Examples
Connect to AirPods and start audio transmission
1#define PROFILE_HFP_HF (uint16)(BIT3)
2#define PROFILE_HFP_AG (uint16)(BIT4)
3#define PROFILE_A2DP_SINK (uint16)(BIT5)
4#define PROFILE_A2DP_SOURCE (uint16)(BIT6)
6void bt_connect(void)
7{
8 //enable hfp source,a2dp source,avrcp tg,spp,gatt
9 uart_send("AT+PROFILE=339\r\n"); //if profile changes,module will auto reboot,
10 wait_ms(500);
11 uart_send("AT+PROFILE\r\n");
12 uint32 profiles = uart_read("+PROFILE",profiles);
13 if(profiles & (PROFILE_A2DP_SOURCE|PROFILE_HFP_AG))
14 {
15 uint8 addr[6];
16 uint8 buf[30]={0};
17 uint8 a2dp_state=0
18 uart_send("AT+SCAN=1\r\n");
19 uart_read_scan_addr("+SCAN",addr);
20 sprintf(buf,"AT+A2DPCONN=%s\r\n",addr);
21 uart_send(buf); //send a2dp connect
23 uart_read("+A2DPSTAT",a2dp_state);
24 if(a2dp_state == 3) //a2dp connected
25 {
26 uart_send("AT+AUDROUTE=1"); // start a2dp audio
27 }
28 uart_read("+A2DPSTAT",a2dp_state);
29 if(a2dp_state == 5)
30 {
31 //a2dp streaming
32 }
33 }
34 else
35 {/*not support master*/}
36}
PhoneBook Download
During PBAP(Phone Book Access Profile) download, some firmware versions may not support automatic PBAP connection. It is necessary to first send the AT command AT+PBCONN to establish the connection before performing the PBAP download.
