1 x FSC-DB008-BT909C Rapid Development Kit : FSC-DB008 Rapid Development Kit pre-integrated with the FSC-BT909C Bluetooth Audio Module
1 x Windows PC
Feasycom Serial Port Tool : A serial port communication analysis tool based on Windows PC.
Communication Interface : UART
UART Configuration : 115200/8/N/1
1.Connect the FSC-DB008-BT909C to the PC via a USB-to-Type-C data cable. The PC will automatically recognize the serial port and generate a virtual COMx port.
Communication Test
For more AT commands, please refer to FSC-BT909C General Audio AT Command Set .
AT\r\n |
\r\nOK\r\n |
Test the UART communication between HOST and Module after power on, baudrate changed, etc. |
Send: >>AT\r\n
Response:<<\r\nOK\r\n
Send: <<AT+NAME\r\n
Response: >>\r\n+NAME=FSC-BT909C-0BB5\r\n //Example, please refer to the actual reading
Response: >>\r\nOK\r\n
Send: <<AT+LENAME\r\n
Response: >>\r\n+LENAME=FSC-BT909C-LE-0BB5\r\n //Example, please refer to the actual reading
AT+VER - Read the Current Firmware Version
Send: <<AT+VER\r\n
Response: >>\r\n+VER=BT909C,V2.2.1,20230103\r\n //Example, please refer to the actual reading
