Module Pin Description
FSC-BT9101AI
Module Pin Diagram:
bt9101
Pin Description:
Descriptions
UART Data Out.
UART Data In.
UART Clear to Send (active low).
UART Request to Send (active low).
Tran/CMD
Host MCU change UART transmission mode.(Default)
H = Command mode.
L = Throughput mode.
Disc
Host MCU disconnect Bluetooth.(Default)
External reset input: Active LOW.
Set this pin low reset to initial state.
Power supply voltage 3.3V~3.6V.
Vss
Power Ground
FW_URXD
Firmware download RXD.
FW_UTXD
Firmware download TXD.
29
I2C_SCL
I2C_SCL
30
I2C_SDA
I2C_SDA
31/32
PA5
Power On: Light Slow Shinning.
Connected: Steady Lighting.
PA4
BT Status
Connected: High.
Not connected: low
RF signal output.
If you need to use an external antenna, you can shield the onboard antenna by modifying the module on the 0R resistor. Or contact Feasycom to modify.
FSC-BT9104DI
Module Pin Diagram:
BT9104
Pin Description:
Power Ground
PA9
BT Status,
H=Connected,
L=No connection.
FW_URXD
FW_UTXD
Vss
Power Ground
VDD_3V3
RST
UART data input.
UART data output.
UART request to send active low.
UART clear to send active low.
Vss
Power Ground
RF
RF_IN/OUT
Bluetooth 50ohm transmitter output/receiver input.
NC if using internal anternna(default).
Connect to external antenna(optional).
  • In simple test environment, the module can be used for basic testing and operation by simply connecting VDD, GND, UART_RX, and UART_TX.
  • If the MCU needs to obtain the connection status of the Bluetooth module, it needs to be connected to the STATUS pin.
  • After drawing the schematic diagram, please send it to Feasycom for review to avoid Bluetooth distance not achieving the best effect.
