Default Configuration
FSC-HC05 |
FSC-HC05-LE |
1234 |
On |
9600/8/N/1 |
GPIO Indicators
Module Operation Status
Status |
Pin 23 |
Low Level |
Pin 23 |
High level |
Bluetooth Disconnected |
Data Transmission Mode
Status |
Pin 24 |
Low Level |
Throughput Mode |
Pin 24 |
High level |
Command Mode |
Status |
Pin 32 |
1Hz square wave |
Pin 32 |
High level |
Bluetooth Connected |
BT Connection Status
Status |
Pin 33 |
Low Level |
Pin 33 |
High level |
Work Modes
Throughput Mode
Bluetooth Connected: All data received via UART is sent as-is to the remote Bluetooth device.
Command Mode
Bluetooth Connected: Data received via UART is still parsed as AT commands. Data must be sent to the remote device using AT commands, e.g.,
AT+SPPSEND.
GATT Service
UUID |
Operation |
Service |
0xFFF0 |
Throughput transmission service |
Write |
0xFFF2 |
Write, |
APP to Module |
Notify |
0xFFF1 |
Notify |
Module to APP |
