  • 1 x FSC-DB005-HC05 Rapid Development Kit : FSC-DB005 USB-to-Serial Rapid Evaluation Board pre-integrated with FSC-HC05 module (Take FSC-BT836B an example) .
  • 1 x PC (Windows / Mac)
1.Connect the FSC-DB005-HC05 to the PC via USB. The PC will automatically recognize the serial port and create a virtual COM port.
hc05-pc-comx
hc05-at
Communication Test
For more AT commands, please refer to FSC-HC05 General Data AT Command Set .
send:     >>AT\r\n
response: <<\r\nOK\r\n   //Successfully connected.
Example: Read BR/EDR Name
send:     <<AT+NAME\r\n
response: >>\r\n+NAME=FSC-HC05\r\n   //Example, please refer to the actual reading result
response: >>\r\nOK\r\n
Example: Read Current Firmware Version
send:     <<AT+VER\r\n
response: >>\r\n+VER=1.0.0,FSC-HC05\r\n     //Example, please refer to the actual reading result
