bt1038x-pin
BT1038x
I2S_CLK
I2S BCLK
I2S_IN
I2S DATA IN
I2S_OUT
I2S SYNC
Low level reset
UART flow control pin (not required by default)
default as power amplifier control pin
General-purpose analog/digital input or output.
3.3V power supply, it is recommended to use LDO
VREG_IN
Power on/off pin
VDD_IO
pio supply
48
External antenna connect pin
Power-on Circuit Design
The FSC-BT1038X module has three options for power on, which are: delayed power on circuit, button on/off circuit, and MCU controlled power on/off circuit. As shown in the following figure:
bt1038x
  • simple testing environment, just connect VDD / VDD_IO / SYS_CTRL / GND / UART_RX / UART_TX.
  • After drawing the PCB circuit schematic, please send it to Feasycom for review to avoid suboptimal Bluetooth distance.
