Module Pin Description
I2S_CLK
I2S bit clock
I2S_IN
I2S data input
I2S_OUT
I2S data output
Frame Sync Clock
active-low reset
UART TX
UART RX
Bluetooth Status Indication
3.3V power supply
Left MIC Differential Input Positive
Left MIC Differential Input Negative
microphone bias voltage
Analog Output Right Channel Negative
Analog Output Right Channel Positive
48
Analog Output Left Channel Negative
Analog Output Left Channel Positive
external Bluetooth antenna
Power-on Circuit Design
  • To ensure the stable operation of the Bluetooth module, the power supply for the VDD_3V3 pin must reserve a current of ≥ 300mA for the Bluetooth module.
  • If the power supply is converted from 5V to 3.3V, you can refer to the following optional recommended schematic diagram for design:
5v-3.3v-op
Antenna Note
PIN
PIN51
To avoid signal discrepancies, external Bluetooth antenna is required
  • For the module’s simple test environment, you only need to connect VDD / GND / UART_RX / UART_TX to test and use it.
  • After completing the PCB circuit schematic, please contact the staff of Feasycom for review to prevent the Bluetooth range from failing to reach the optimal performance.
