Functional Description
Default Configuration
FSC-BT3431
GPIO Indications
PIN
Status
PIN 21
1Hz Square Wave
Bluetooth Disconnected
PIN 21
High Level
Bluetooth Connected
BT Connection Status
PIN
Status
PIN 22
Low Level
PIN 22
High Level
Bluetooth Connected
GATT Service
Permission
Throughput transmission service
Write,
Write Without Response
Sent from APP to Module
Sent from Module to APP
Working Mode
Throughput Mode
  • Bluetooth Not Connected: Data received via UART is parsed as AT commands.
  • Bluetooth Connected: All data received via UART is sent as-is to the remote Bluetooth device.
Command Mode
  • Bluetooth Connected: Data received via UART is still parsed as AT commands. Data must be sent to the remote device using AT commands, e.g., AT+LESEND.
Low-Power Strategy
Low-Power Mode Setting
The low-power function can be enabled or disabled via the command AT+LPM{=Param}.
Low-Power Operation Strategy
  • AT+LPM=1
    • BT automatically enters low-power mode if no data is received from the BT UART for more than 5 second.
    • The first frame of data from the BT UART wakes up Bluetooth.
    • Does not enter low-power mode after a successful connection.
  • AT+LPM=2
    • When the MCU pulls PIN7 high, BT enters sleep mode.
    • when the MCU pulls PIN7 low, BT exits sleep mode.
    • After Bluetooth connection, BT pulls PIN8 low to notify the MCU to exit sleep mode, and outputs data with a 10ms delay.
    • After Bluetooth disconnection, BT pulls PIN8 high to notify the MCU to enter sleep mode.
Data Rate (Typical)
Baudrate
Data Packet
Transmission Interval
Connection Interval
Transmission Method
Rate
921600
244
20ms
7.5ms
12000 Byte/s
