bt618x
UART data pin
UART data pin
Serial Port Flow Control Pin
RESTORE
Reset configuration
Active-low reset
3.3V power supply.LDO (Low Dropout Regulator) power supply is recommended
SWCLK
Programming pin
SWDIO
Programming pin
Outputs a square wave when Bluetooth is disconnected.outputs high level when Bluetooth is connected
31
WAKE_MCU
Bluetooth in low-power mode wakes up the MCU
Outputs low level when Bluetooth is disconnected, and high level when Bluetooth is connected
WAKE_BT
MCU in low-power mode wakes up Bluetooth
An external Bluetooth antenna can be connected by changing the 0-ohm resistor near the antenna
  • The module can be used by simply connectingVDD/GND/STATUS/UART_RX/UART_TX
  • If the MCU needs to obtain the connection status of the Bluetooth module, the STATUS pin (Pin 10) must be connected.
  • The module supports GPIO-based wake-up. If the application has low-power consumption requirements, the WAKE_MCU/WAKE_BT pins must be connected.
  • VDD/GND/RESET/SWCLK/SWDIO serve as the programming interface, and test points may be reserved for debugging and testing purposes.
  • After completing the schematic diagram, please send it to Feasycom for review to ensure the Bluetooth communication distance reaches the optimal performance.
