Functional Description
Default Configuration
FSC-BT618
GPIO Indications
PIN
Status
PIN 32
1 Hz square wave
Bluetooth disconnected
PIN 32
High Level
Bluetooth connected
BT Connection Status
PIN
Status
PIN 33
Low Level
Bluetooth Disconnected
PIN 33
High Level
Bluetooth Connected
Working Mode
Throughput Mode
  • Bluetooth Not Connected: Data received via UART is parsed as AT commands.
  • Bluetooth Connected: All data received via UART is sent as-is to the remote Bluetooth device.
Command Mode
  • Bluetooth Connected: Data received via UART is still parsed as AT commands. Data must be sent to the remote device using AT commands, e.g., AT+LESEND.
GATT Service
Operation
Throughput transmission service
Write,
Write Without Response
APP to module
Module to APP
Performance Parameters
Time
Power-On Time
230ms
UART response enable time
Wake-Up Time
200ms
Calculation starts after the UART finishes sending wake-up data
Data Rate (Typical)
Baudrate
Data Packet
Transmission Interval
Connection Interval
Transmission Mode
Rate
230400
244
11ms
15ms
23000 Byte/s
Low-Power Mode
FSC-BT618x module supports two Low Power Modes (LPM): UART Wake-up Mode and I/O Pin Wake-up Mode.
The low power function can be enabled or disabled via the AT command AT+LPM{=Param}.
Low-Power Mode Operation Strategy
  • UART Wake-up Mode
    • Configuration Command : AT+LPM=1
    • Hardware Connection : No need to connect WAKE_MCU and WAKE_BT.
    • Sleep Method :
      The module automatically enters sleep mode if there is no UART data communication for more than 5 seconds. It exits sleep mode when the first frame of data is received via UART after sleeping.
    • Derscription :
      The first frame of data upon wake-up will be lost; simple logic and IO resource-saving.
  • I/O Pin Wake-up Mode
    • Configuration Command : AT+LPM=2
    • Hardware Connection : Need to connect WAKE_MCU and WAKE_BT.
    • Sleep Method :
      When WAKE_BT is at high level, the Bluetooth module enters sleep mode.
      When WAKE_BT is at low level, the Bluetooth module exits sleep mode.
      WAKE_MCU at high level notifies the MCU to exit sleep mode.
      WAKE_MCU at low level notifies the MCU to enter sleep mode.
    • Derscription :
      Supports MCU wake-up.
      Requires 2 additional pin connections in the circuit.
