FAQs
Why is an APP required on a mobile phone for Bluetooth connection and communication?
The native Bluetooth function of mobile phones only supports general scenarios, such as audio transmission and file transmission. Some Bluetooth peripheral devices can be connected via the built-in settings program of the mobile phone, such as Bluetooth speakers, Bluetooth headsets, Bluetooth keyboards, Bluetooth mice, etc. When a Bluetooth peripheral device cannot be connected by the mobile phone's native settings program (for example, the Bluetooth module only supports SPP/GATT protocols), to connect such a module, it is generally necessary to install a specific mobile application on the mobile phone, such as the FeasyBlue application.
How to obtain Bluetooth MAC address on iOS device?
For security reasons, the iOS system converts the Bluetooth MAC address into a UUID at the underlying layer and sends it to upper-layer applications. Therefore, the APP cannot obtain the device’s MAC address.
FSC-BT691 Bluetooth module will place the MAC address in the broadcast by default, and the APP can obtain the MAC address from the broadcast packet through the following methods.
// tempByte The following parameter is the Bluetooth address.
