bt691-pin-map
UART transmit pin
UART receive pin
MODE
Low level for transparent transmission mode, high level for command mode
Low level for reset
3.3V power supply; LDO power supply is recommended
DISCONNECT
High level to disconnect (Bluetooth must be connected first)
Outputs square wave when Bluetooth is disconnected; outputs high level when Bluetooth is connected
Outputs low level when Bluetooth is disconnected; outputs high level when Bluetooth is connected
20
An external Bluetooth antenna can be connected by changing the 0-ohm resistor near the antenna
  • The module can be used by connecting only the VDD, GND, STATUS, UART_RX, and UART_TX pins.
  • If the MCU needs to obtain the connection status of the Bluetooth module, the STATUS pin (Pin 18) must be connected.
  • If the user wants to check the working status of Bluetooth, an LED light can be connected to the LED pin (Pin 17).
  • After completing the schematic diagram, please send it to Feasycom for review to ensure the Bluetooth range reaches the optimal performance.
