0Hardware Design
Pin diagram with FSC-BW236:
Descriptions |
UART Data output |
UART Data input |
UART clear to send (active low) |
UART request to send (active low) |
9 |
UART_LOG_OUT |
Debugging interface (Data OUT) |
10 |
UART_LOG_IN |
Debugging interface (Data IN) |
RESET/CHIP_EN |
External reset input, active low. |
VDD_3V3 |
Power supply voltage 3.3V |
VSS |
Power Ground |
21 |
VSS |
Power Ground |
22 |
VSS |
Power Ground |
Bluetooth is connected to output high |
Wi-Fi is connected to output high level |
35 |
VSS |
RF Ground |
RF signal output |
Note: This section provides brief I/O pin descriptions. For detailed descriptions and precautions, please refer to FSC-BW236 Datasheet .
Hardware Interface
GPIO
PWM
UART
SPI SLAVE
The simple test of the module only requires connecting VDD/GND/UART_RX/UART_TX to be used
After drawing the schematic diagram, please send it to Feasycom for review to avoid the Bluetooth or Wi-Fi distance not achieving the best effect
