Pin diagram with FSC-BW246:
bw246_pin_map
Descriptions
UART Data output
UART Data input
UART clear to send (active low)
UART request to send (active low)
DEBUG_OUT
Debug Interface (Data OUT)
DEBUG_IN
Debug Interface (Data IN)
RESET/CHIP_EN
External reset input, active low.
Set this pin low reset the module.
VDD_3V3
Power supply voltage 2.3~3.3V
VSS
Power Ground
VSS
Power Ground
VSS
Power Ground
Bluetooth is connected to output high
Wi-Fi is connected to output high level
35
VSS
RF Ground
RF signal output
Note: This section provides brief I/O pin descriptions. For detailed descriptions and precautions, please refer to FSC-BW246 Datasheet .
Hardware Interface
  • GPIO
  • PWM
  • UART
  • SPI SLAVE
  • I2S Master/Slave
  • Analog Input/Output
  • The simple test of the module only requires connecting VDD/GND/UART_RX/UART_TX to be used
  • After drawing the schematic diagram, please send it to Feasycom for review to avoid the Bluetooth or Wi-Fi distance not achieving the best effect
