  • 1 x FSC-DB105-BW246 Development Kit : FSC-DB105 USB-to-Serial Port quick evaluation board integrated with FSC-BW246.
  • 1 x Computer(Windows / Mac)
  • UART Configuration : 921600/8/N/1
1.Connect the FSC-DB105-BW246 quick development kit to the PC via USB. The PC will automatically recognize the serial port and generate a virtual COMx port.
db105-bw246
2.Run Feasycom Serial Port Tool on the PC, set the correct COM and Baud,and check the New line.
db105-bw246
Communication test
The following lists a few basic general AT command test examples.
For more commands, please refer to FSC-BW246 General Data AT Command Set .
Send:     <<AT\r\n
Response: >>\r\nOK\r\n     //successfully connected
AT+NAME - Read the BR/EDR Bluetooth name
Send:     <<AT+NAME\r\n
Response: >>\r\n+NAME=FSC-BW246\r\n      //Example, please refer to the actual reading result
AT+VER - Read the current firmware version
Send:     <<AT+VER\r\n
Response: >>\r\n+VER=FSC-BW246,V45.1.5\r\n      //Example, please refer to the actual reading result
