Different firmware have different functional configurations.This guide provides functional descriptions based on the general Dual-Mode data transmission application firmware program.
Default Configuration
Using FSC-BT836B as example:
FSC-BT836B
FSC-BT836B-LE
On
GPIO Indicators
Module Operation Status
Status
Pin 32
1Hz square wave
Bluetooth Disconnected
Pin 32
High level
Bluetooth Connected
BT Connection Status
Status
Pin 33
Low Level
Pin 33
High Level
Bluetooth Connected
Data Transmission Mode
Status
Pin 24
Low Level
Throughput Mode
Pin 24
High Level
Command Mode
Work Modes
Throughput Mode
  • Bluetooth Not Connected: Data received via UART is parsed as AT commands.
  • Bluetooth Connected: All data received via UART is sent as-is to the remote Bluetooth device.
Command Mode
  • Bluetooth Connected: Data received via UART is still parsed as AT commands. Data must be sent to the remote device using AT commands, e.g., AT+SPPSEND.
4. GATT Service
Operation
Throughput transmission service
Write,
Write Without Response
APP to Module
Module to APP
