BT986
Serial Transmitter Data
Serial Receiver Data
UART Clear to Send(no connection request)
UART Request to Send(no connection request)
24
Tran/USB_DP/PIO1
UART mode control pin, H=command mode ,L=throughput mode
23
Disc/USB_DM/PIO0
Disconnect the connecting pin
Active-low reset input
Power supply voltage 3.3V, LDO power supply preferred
ICE
Writing firmware pin
Bluetooth not connected to output square wave, Bluetooth connected to output high level
Connection state, output. H=Connected , L=No connection
Changing the 0 ohm resistance near the antenna, it is possible to connect a Bluetooth antenna externally
Note:
To use the PIN23 and PIN24 control modules AT+PIOCFG command is required to enable the function
  • In simple test environment, the module can be used for basic testing and operation by simply connecting VDD, GND, UART_RX, and UART_TX.
  • If the MCU needs to obtain the connection status of the Bluetooth module, it needs to be connected to the STATUS pin.
  • After drawing the schematic diagram, please send it to Feasycom for review to avoid Bluetooth distance not achieving the best effect.
