bt1036x-pin
BT1036A
BT1036B
BT1036C
I2S_CLK
I2S BCLK
19
I2S_IN
I2S DATA IN
20
I2S_OUT
I2S SYNC
Low level reset
UART flow control pin (not required by default)
default as power amplifier control pin
24
In pairing mode, a square wave is output. When Bluetooth is connected, the output is a high level.
33, 34
SPP/GATT is not connected. The output is at low level. When connected, the output is at high level.
3.3V power supply, it is recommended to use LDO
28
40
MIC_RP
MIC0/Line_IN differential R input, positive
41
MIC_RN
MIC0/Line_IN differential R input, negative
29
9, 17
30
19, 23
SPK_L
Line out, left (16/32 0 load cannot be connected)
20, 24
SPK_R
Line out, right(16/32 0 load cannot be connected)
31
27
External antenna connect pin
Power-on Circuit Design
  • The power supply needs to be stable at 3.3V.,If the power supply is unstable, the module will not be able to start properly, or there will be abnormalities in the function application.
  • If it is a 5V to 3.3V power supply, you can refer to the following optional schematic design suggestions:
bt1036x
  • Simple testing environment, just connect VDD / GND / UART_RX / UART_TX.
  • After drawing the PCB circuit schematic, please send it to Feasycom for review to avoid suboptimal Bluetooth distance.
