Functional Description
Default Configuration
Feasycom
GPIO Indications
Status
Pin 17
2Hz Square Wave
Bluetooth Disconnected
Pin 17
High Level
Bluetooth Connected
Connection Status
Status
Pin 18
Low Level
Pin 18
High Level
Bluetooth Connected
GATT Service
Permission
Throughput transmission service
Write,
Write Without Response
Sent from APP to Module
Sent from Module to APP
Working Mode
Throughput Mode
  • Bluetooth Not Connected: Data received via UART is parsed as AT commands.
  • Bluetooth Connected: All data received via UART is sent as-is to the remote Bluetooth device.
Command Mode
  • Bluetooth Connected: Data received via UART is still parsed as AT commands. Data must be sent to the remote device using AT commands, e.g., AT+LESEND.
Low Power Consumption
The module supports one low-power mode: UART Wake-up Mode.
UART Wake-up Mode
  • Command Configuration : AT+LPM=1
  • Sleep Method :
    If there is no data communication via the UART for more than 5 seconds, it will automatically enter sleep mode.
    After entering sleep mode, the UART will exit sleep mode when the first frame of data is received.
  • Description :
    The first frame of data upon wake-up will be lost.
    Simple logic, saving IO resources.
Data Transmission Rate
Baud Rate
Data Packet (Size)
Transmission Interval
Connection Interval
Transmission Method
Rate
921600
244
20ms
7.5ms
12000 Byte/s
