Network Configuration
FeasyBlue Bluetooth Network Configuration
APP Download
User Guide
1.Open the FeasyBlue App and click on Setting - WiFi Parameter Settings to enter the WiFi param setting page.
2.On the WiFi param setting page, Check BLE , scan and select the WiFi param setting page.
3.Select and click on BLE Network to enter the BLE network page.
4.On the BLE network page, enter the enter the SSID 和 password of the Wi-Fi AP to be connected, and click Start network config.
5.After the distribution network is completed, It will show the Distribution network is successful and the IP address .
Example
../_images/bw256x-bt-network-en.png
Throughput Mode Application
What Is Throughput Mode?
FSC-BW256x series Bluetooth & Wi-Fi module features two data transmission modes: Throughput Mode and Command Mode .
The default command mode of the general data transmission application firmware. If you need to switch, you can refer to [FSC-BW256B General Data AT Command Set] , and using the AT+TPMODE command.
The working mechanisms and differences of the two data transmission modes are as follows:
  • Throughput Mode :
    Without Bluetooth or Wi-Fi connection , the data received through the serial port is parsed in the format of AT instructions;
    Bluetooth or Wi-Fi connection has been established , all the data received through the serial port is sent to the remote end as is.
  • Command Mode :
    Bluetooth or Wi-Fi connection has been established , The data received through the serial port is still parsed in the AT instruction format, which means data that needs to be sent to the remote end should be carried by AT commands.
Switch To Throughput Mode
Enter the Throughput Mode: Before establishing Bluetooth or Wi-Fi connection, the FSC-BW256B module can use the command AT+TPMODE=1 to activate the transparent transmission mode.
Send:     >>AT+TPMODE=1                     //Set it to throughput mode
Response: <<OK
When Bluetooth or Wi-Fi connection has been established, exit throughput mode:
Send:     >> +++      //Send "+++". When operating on the host computer's serial port tool, please uncheck "New Line" at this time.
Response: << a                //Received response "a"
Send:     >> a                //Send "a". When operating on the host computer's serial port tool, please uncheck "New Line" at this time.
Response: << +ok      //Successfully exited
  • Throughput Mode only takes effect when connections (such as Bluetooth, TCP/UDP) have been established. Therefore, the methods to exit transparent transmission also only work under such circumstances. When no connections have been established, you can directly use the AT command (AT+TPMODE) to switch modes.
  • The data format for sending and receiving mentioned above differs from that of AT commands. Standard AT commands end with <CR><LF> , while the above-mentioned control commands are strings that do not come with <CR><LF>.
Module to Phone Communication
../_images/bw256x-bt-app-tp-en.png
TCP Server Application
Tools
TCP Server Application Example
../_images/bw256-tcps-en.png
TCP Server Application Flowchart
actor “ ” as person
participant “USER MCU” as mcu
participant MODULE as module
participant " " as nu
participant "TCP Client" as client
person ->> mcu: Start the operation
mcu -> module: AT+ROLE=1
note left
    Switch to STA mode
end note
module -> mcu: OK
mcu -> module: AT+RAP=SSID,PASSWORD
note left
    Connect to AP
end note
module -> mcu: OK
group LOOP Query until the IP address\nis obtained
mcu -> module: AT+LIP
note left
    Query the module's IP
end note
module -> mcu: +LIP=0.0.0.0
note right
    Not connected to AP
end note
end
module -> mcu: +LIP=192.168.0.97
note right
    Connected to AP
end note
mcu -> module: AT+SOCK=TCPS,9100
note left
    Set module
    as TCP Server
end note
module -> mcu: OK
mcu -> module: AT+WLANC=3
note left
    Start TCP Server
end note
module -> mcu: OK
client --> nu: The client \ninitiates a connection
nu --> module: The module is connected
client --> nu: The client send data\n:1234567890
module -> mcu: +WFDATA=0,10,1234567890
note right
    module outputs
    the received data
end note
mcu -> module: AT+WFSEND=0,3,abc
note left
    module sends data
    to the remote end
end note
module -> mcu: OK
nu --> client: abc
TCP Server Application Description
1.Set the module to Wi-Fi mode. If it is already in the current mode, you can skip this step.
Send:     <<AT+ROLE=1
Response: >>OK
2.The module is connected to the AP hotspot.
Send:     <<AT+RAP=SSID,PASSWORD
Response: >>OK
3.Query the IP address of the module to confirm that it has been connected to the network.
Send:     <<AT+LIP
Response: >>+LIP=192.168.0.97  //For local examples, please refer to the actual IP address obtained by connecting to the AP
Response: >>OK
4.Set the module to TCP server with port 9100.
Send:     <<AT+SOCK=TCPS,9100
Response: >>OK
5.To create a TCP server for the module.
Send:     <<AT+WLANC=3
Response: >>OK
6.The PC and the module (FSC-BW256B) are connected to the same AP hotspot. On the PC, a third-party network debugging tool is used to create an IP address for the TCP connection to the TCP Server (module) as a TCP client. And after establishing a TCP connection, send TCP data to the TCP Server (module), such as 1234567890.
../_images/bw256x-tcps-tcptool-tcpc-en.png
7.The module receives TCP data sent by the TCP Client. In instruction mode, an example of the received data format serial port response is as follows:
Response: >>+WFDATA=0,10,1234567890   //Supports simultaneously receiving data sent from multiple TCP clients to the TCP Server, with the first parameter being the connection ID
Response: >>+WFDATA=1,10,1234567890
Response: >>+WFDATA=2,10,1234567890
8.The module supports the simultaneous reception of data sent from multiple TCP clients to the TCP Server. The first parameter is the connection ID. In command mode, an example of the AT command operation is as follows:
Send:     <<AT+WFSEND=0,3,abc
Response: >>OK
TCP Client Application
Tools
TCP Client application Example
../_images/bw256x-tcpc-en.png
TCP Client Application Flowchart
actor “ ” as person
participant "TCP Server" as server
note left
    Switch to STA mode
end note
module -> mcu: OK
note left
    Connect to AP
end note
module -> mcu: OK
note left
end note
note right
    Not connected to AP
end note
end
note right
    Connected to AP
end note
mcu -> module: AT+SOCK=\nTCPC,9100,192,168.0.100,6000
note left
    Set module
    as TCP Client
end note
module -> mcu: OK
note left
    Start TCP Client
end note
module -> mcu: OK
module --> nu: Module initiates\nconnection
server --> nu: Module is connected
server --> nu: The server send data
module --> mcu: +WFDATA=3,10,1234567890
note right
    module outputs
    the received data
end note
mcu -> module: AT+WFSEND=3,3,abc
note left
    module sends data
    to the remote end
end note
module -> mcu: OK
nu --> server: abc
TCP Client Application Description
Send:     <<AT+ROLE=1
Response: >>OK
2.Connect the module to the AP hotspot.
Response: >>OK
3.To query the IP address of the module.
Send:     <<AT+LIP
Response: >>OK
4.Connect the PC and the module to the same AP hotspot. Use a third-party network debugging tool on the PC to create a TCP Server.
For example, the IP address of the TCP Server is 192.168.0.79 and the port number is 8080.
5.Set the module as TCP client and configure the IP and port number of the remote TCP Server.
Send:     <<AT+SOCK=TCPC,9100,192.168.0.79,8080
Response: >>OK
6.The module acts as a TCP client to initiate the establishment of a TCP connection with the remote TCP Server.
Send:     <<AT+WLANC=3
Response: >>OK
7.After the TCP connection is successfully established, the PC-end network debugging tool will display the successful connection, as well as the data sending area and receiving area. TCP data sending and receiving can be carried out, such as sending data 1234567890 to the remote TCP Client module
8.The module receives TCP data sent from the TCP Server. In instruction mode, an example of the received data format response is as follows:
Response: >>+WFDATA=3,10,1234567890
UDP Application
UDP Application Flowchart
actor “ ” as person
participant "UDP" as udp
note left
    Switch to STA mode
end note
module -> mcu: OK
note left
    Connect to AP
end note
module -> mcu: OK
note left
end note
note right
    Not connected to AP
end note
end
note right
    Connected to AP
end note
mcu -> module: AT+SOCK=UDP,4000
note left
    Set module
    as UDP
end note
module -> mcu: OK
note left
    Start UDP
end note
module -> mcu: OK
udp --> nu: The remote end\ninitiates a connection
nu --> module: Module is connected
udp --> nu: The remote end sends data\n:1234567890
module -> mcu: +WFDATA=4,10,1234567890
note right
    module outputs
    the received data
end note
mcu -> module: AT+WFSEND=4,3,abc
note left
    module sends data
    to the remote end
end note
module -> mcu: OK
nu --> udp: abc
UDP Application Description
1.Set the Wi-Fi mode. If you are already in the current mode, you can skip this step
Send:     <<AT+ROLE=1
Response: >>OK
2.Connect to AP
Response: >>OK
Send:     <<AT+LIP
Response: >>OK
4.Set module as UDP
Send:     <<AT+SOCK=UDP,4000
Response: >>OK
5.Start UDP Server
Send:     <<AT+WLANC=3
Response: >>OK
6.The PC and the module are connected to the same hotspot. On the PC, a network test tool is used to start UDP Client with the target IP 192.168.0.97 and the target port number 4000.
7.Receive data
Response: >>+WFDATA=4,10,1234567890
8.Send data
Send:     <<AT+WFSEND=4,3,abc
Response: >>OK
To use throughput mode, simply send AT+TPMODE=1 before setting the Wi-Fi mode.
SSL Client Application
SSL Client Application Flowchart
actor “ ” as person
participant "SSL Server" as server
note left
    Switch to STA mode
end note
module -> mcu: OK
note left
    Connect to AP
end note
module -> mcu: OK
note left
end note
note right
    Not connected to AP
end note
end
note right
    Connected to AP
end note
mcu -> module: AT+SOCK=\nSSL,9100,httpbin.org,443
note left
    Set module
    as SSL Client
end note
module -> mcu: OK
note left
    Start SSL Client
end note
module -> mcu: OK
module --> nu: The remote end\ninitiates a connection
mcu -> module: AT+SSLSEND=\n40,GET /get HTTP/1.1\\r\\n\nHost: httpbin.org\\r\\n\\r\\n
note left
    send GET request
end note
module --> nu: module send\nHTTPS request
server --> nu: Server response
note right
    module outputs
    the received data
end note
SSL Client Application Description
Send:     <<AT+ROLE=1
Response: >> OK
2.Connect to AP
Send:     <<AT+RAP=ssid,password
Response: >> OK
Send:     <<AT+LIP
Response: >>OK
4.Set the module as SSL client and configure the remote server and port number
Send:     <<AT+SOCK=SSL,9100,httpbin.org,443
Response: >>OK
5.The module initiates a connection to the remote end as an SSL client
Send:     <<AT+WLANC=3
Response: >> OK
6.Send relevant requests, such as GET requests
Send:     <<AT+SSLSEND=40,GET /get HTTP/1.1\\r\\nHost: httpbin.org\\r\\n\\r\\n
Response: >> OK
7.Receive data
Response: >>+SSLDATA=Specific data
MQTT Application
MQTT Application Flowchart
actor “ ” as person
participant "AliCloud" as cloud
module -> mcu:
note right
    Connected to AP
end note
mcu -> module: AT+BROKER=addr
note left
    Set BROKER address
end note
module -> mcu: OK
mcu -> module: AT+USERNAME=username
note left
    Set UserName
end note
module -> mcu: OK
mcu -> module: AT+MQTTPWD=password
note left
    Set PassWord
end note
module -> mcu: OK
mcu -> module: AT+CLIENTID=ID
note left
    Set ClientID
end note
module -> mcu: OK
mcu -> module: AT+SUBTPC=tpoic,qos
note left
    Subscribe to topics
end note
module -> mcu: OK
mcu -> module: AT+WLANC=4
note left
    Module initiated
    connection
end note
module -> mcu: OK
module --> nu: Start connection
nu --> cloud: Connect to MQTT
cloud --> nu: Data sent from the\ncloud :1234567890
note right
    module outputs
    the received data
end note
note left
    module sends data
    to the cloud
end note
module -> mcu: OK
nu -> cloud: abc
MQTT Application Description
Send:     <<AT+ROLE=1
Response: >>OK
2.Connect to AP
Response: >> OK
Send:     <<AT+LIP
Response: >>OK
4.Set the BROKER address
Send:     <<AT+BROKER=gpssensor.ddns.net
Response: >>OK
5.Set User Name
Send:     <<AT+USERNAME=admin
Response: >>OK
6.Set Password
Send:     <<AT+MQTTPWD=12345678
Response: >>OK
7.Subscribe to topics
Send:     <<AT+SUBTPC=user/get,0
Response: >> OK
8.Connect to MQTT
Send:     <<AT+WLANC=4
Response: >> OK
9.Receive the data sent by the cloud platform
1234567890
10.Send data to the cloud platform
Send:     <<AT+MQTTPUB=user/post,0,3,abc
Response: >>OK
